Question about Sanyo PLC XP55 Multimedia Projector
Sanyo PLC-XP55 flashing lines
Sanyo PLC-XP55 has horizontal flashing lines in vertical columns.
SOURCE: Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Posted on Jul 07, 2008
projdoc
  • 2237 Answers
SOURCE: I just replaced the lamp on my Sanyo PLC-XP55
did you get the bulb from sanyo, or from another company that sells aftermarket bulbs? some of those are cheaply made and malfunction shortly after if they work at all. find your reciept, take it back and get a new one.
Posted on Jul 22, 2009
projdoc
  • 2237 Answers
SOURCE: sanyo plc sw20a dose not work with my laptop what
you need to activate the external monitor port on your laptop.
Posted on Nov 09, 2009
  • 150 Answers
SOURCE: projetor sanyo plc xp55, starts uplights up and
Check if you can see any dust clogging the outlets- use a brush and vacumm cleaner to clean every air vent around the case. there should be a few. There is usually a user replaceable air filter on one of the vents- un clip it and vaccum both sides of it. If it is too dirty clean it with soap and water squeeze it out and leave it to dry before re-installing. Projectors generate a lot of heat and conversely they are very sensetive to blocked air vents.
Hope this helps
Good Luck!
Posted on Jan 17, 2010
agent91
  • 2100 Answers
SOURCE: I have a Sanyo PLC-XP46/L projector and it has a
A common problem for these projectors, the light gets bent around 3 different color filters inside there, for some reason the blue one gets burned out the fastest. It always makes a halo, we found it cheaper to replace the unit than fix it, They wanted $1,000 to fix it, all it is is a filter, but they don't tell you that. You can find your exact machine on ebay for parts, but chances are it will have the same problem. I have the same machine here, I fixed it myself, It isn't perfect, but it is a lot better than it was. I took a glass panel from a cell phone, it fits perfect, and it stopped the halo, the glass is bullet proof and high heat proof, the way I discovered this, I shred old cell phones for parts and and computers for parts, I was in the process of shredding the projector, I found a cell phone screen in the ashes of our burn pile, untouched, not a scratch, so,, I put it to use, you can try it. It is cheaper than a $1,000 repair job. If you need more info on this, write a reply, I'll be happy to try and help.
Posted on Dec 05, 2010
How do I fix an image being cutoff on the right side?
There could be a few reasons that this is happening, you should try changing the resolution on your computer, some of these models have an optimal resolution that it has to be on or sometimes it works if you lower the resolution.
May 30, 2014 | Sanyo PLC XP55 Multimedia Projector
Tv has horizontal line in middle of screen,sanyo ds25390
hi if only a horizontal line across with no video anymore, you have bad either vertical ic or no dc supply b+( vertical ic ) or no output dc coming from the ic. if it is not totally a horizontal white line and you can see a video you must check leak or bulged capacitors at the vertical section near the vertical ic. hope this can help good luck.
Oct 02, 2012 | Televison & Video
Sanyo lcd projector has horizontal scrolling lines in its picture. Is this different than a lamp problem? Electrical? All else works fine. Thank you. Sanyo PLC-5600n lcd video projector. Not a tv.
This is caused by the processor and not by the lamp. As you might know, these projectors display colors by blanking out the light with lcd pixels. Most folks don't know that any display devices such as displays on cameras, laptop displays, etc. use an amazing amount of original technology that powered CRT TVs. (Yes, even vertical hold, although done electronically today, is there.) You'll just have to send this one in for service.
Feb 26, 2010 | Sanyo Televison & Video
Projetor sanyo plc xp55, starts uplights up and then shuts down, what can be the problem? the indicators blinks showing warning temperature regards Edwine.
Hope this helps
Good Luck!
Jan 15, 2010 | Sanyo PLC-XP55L Multimedia Projector
Red vertical lines from top to bottom. Red lines,white lines in a uniform pattern
Try to change your VGA cable if the problem occur your A/V board was deffective.
Oct 23, 2009 | Sanyo PLC-XU73 Multimedia Projector
How do i replace the lamp
remove the lamp door, remove the old lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 15, 2009 | Sanyo PLC-XP55 Multimedia Projector
I just replaced the lamp on my Sanyo PLC-XP55 projector and reset the lamp counter but now it won't turn on. When I press the power button, it goes into a cooling mode for 90 seconds and then never turns...
Jul 22, 2009 | Sanyo PLC-XP55 Multimedia Projector
Vertical line in center have replaced vertical output ic
If the line is vertical then the problem is no horizontal deflection. The vertical chip is probably fine.
Check connections around yoke (thats the connector with at least four wires that goes up to the coils around the neck of the tube)
Maybe that TV has two horizontal output transistors. One for deflection and one for high voltage? Check both of them. Look for bad solder joints!!!
May 21, 2009 | Sanyo DS31520 31" TV
Sanyo PLC-XP55 "new" both temp and ready lights flash
One of the common problems on this and the 56 model is the exhaust cooling fan, the reason being that due to the heat given off from the lamp assembly the bearings dry up, even if they dont fail but go stiff, this also causes problems because inside the fan it is fitted like most of them now with a rotataion speed sensor and the system control monitors the pulse reference.If this changes and is not upto speed to keep the lamp cool enough the internal heat sensor detects this and the unit locks up into protection mode to protect the lamp assembly from getting too hot or even exploding.Kind regards John Williams www.jvsvisual.com
May 10, 2009 | Sanyo PLC-XP55L Multimedia Projector
If the line is "vertical" then the vertical circuit sounds OK. The problem would be in the horizontal deflection.
Check yoke connection and solder around horz defl circuit.
If the line is horizontal then I would suspect the vertical IC.
Apr 02, 2009 | Sanyo DS31520 31" TV
Sanyo PLC XP55 Multimedia Projector Logo
47 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
