Question about Toshiba 27A30 27" TV
Toshiba 27A30 that blows Fuse
I have a Toshiba 27A30 that stopped working (no pic or sound). When I opened it up to look for any obvious problems I noticed a blown fuse (black inside, like their is a short). I replaced the fuse and it blew again,it happened around the time of a lighting storm. Any suggestions?
    New Friend:
  • 163 Answers
Hey this one was posted agust 6 do I geting crazy or what? agust 7 agust 6 the same day?
Posted on Aug 07, 2006
    President:
  • 3,130 Answers
Jeff, If your not a technician please dont mess with the set as you can get seriuoly hurt by experimenting. And replacing a fuse that is black is only going to blow again and possibly cause more problems and damage the set more then it already is. Your problem is a shorted B+ rectifier or a capacitor or voltage regulator IC. If you don,t know what this is, or you don't know how to solder, as well as unsolder, Please seek out a pro to assit you with this repair. Good Luck
Posted on Aug 06, 2006
Bonaire Vulcan controller cct board 10 amp fuse keeps blowing
Obviously a direct short. Take pic, remove all wires, replace fuse. Wire by wire, turning power back on each time until fuse pops. When it does, there's your problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 02, 2017 | Vulcan Heating & Cooling
The machine stopped working and tripped the fuse box i changed the fuse still not working
Something electrical has blown in the machine causing the fuse to blow. After replacing the fuse , the machine isn't going because whatever blew is now "open circuit" Have a look for obvious blow outs on any of the switches, control boards , all other electrical components and the wiring. look for telltale black marks where something has "blown" on the cabinet or around the components.
Mar 20, 2017 | Washing Machines
HI. My Yamaha D80 while playing gave a burned smell and than sound quit. Rest works. I opened rearcover and notice 3rd fuse in the back was blown. Changed it. Blew again. So I stopped fidling around.
If the fuse blows and a smell of burning is present then its obvious there i a fault somewhere ahead of the fuse, the fuse is a protection device.
Oct 08, 2016 | Yamaha Cars & Trucks
Flat screen toshiba tv black screenbut a sound
hello, usually in that case, the cause to the failure, is the inverter board. but first you have to chek the 24v that should be supplied to the inverter. if the voltage is ok. then you should replace the inverter board
May 20, 2011 | Toshiba 27A30 27" TV
WHERE CAN I PURCHASE A SOUND MODULE PART #MVUS325 AND SBX1768-01 FOR MY STANDARD 27' TOSHIBA TV. THERE IS NO SOUND AFTER THE TV RUNS FOR 5 MINUTES. PLEASE ADVISE WHERE WHICH STORE HAS THIS...
I found it at:
Encompass & HBF Electronics . This part is quickly falling off the radar and many places list it as NLA (no longer available), meaning they are no longer being produced. When they're gone - they're gone. Buy one if you want it while you can.
I hope this helps and good luck. Please rate my reply. Thank you.
Apr 13, 2011 | Toshiba 27A30 27" TV
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
My universal remote stopped working, I bought another one and it doesn't work either, I mean it doesn't work with my set, it seems I programmed it correctly but when I try to change the channel it doesn't...
It was the TV set! I googled remote control problems and went on one of the websites......The answer was quite simple, unplug the TV for a few minutes and let it reset itself. I did and it did! I guess it's no different than a cell phone or computer sometimes!
Sep 16, 2009 | Toshiba 27A30 27" TV
Fan problem
The fan is clogged an needs to be cleaned if you know how to open the laptop you can move the strip that houses the keyboard ans remove the key board from there you can see the fan that is on the CPU stick a tooth pic in the fan soo that it does not move and blow it clean with compressed air. if not take it to you local computer guy and he can clean it for you.
May 09, 2009 | Toshiba Satellite A215-S4747 Notebook
Constant horn blowing
Very possibly the horn relay. This is located in the left junction block ( fuse panel) on the left side of dash. Open driver door and you will see a panel cover on the end of dash. On the cover it should list the position of the relay which I believe is on the right of fuse panel. If you try the horn and it sticks on again, try tapping the relay, if stops then that is the problem.
Mar 21, 2009 | 1999 Dodge Intrepid
Toshiba 27A30 27" TV Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
