Question about Husqvarna Chain Saw Models 371, 372xp
How to replace gas line on 372 xp chainsaw
Taking gas line off and installing new one
I have a husqvarna 375xp chainsaw and I can't find any information on this chainsaw. Can someone please tell me how and where to find the information.
would say limited production edition
if its age is around 2013 they company started a new production plant
possible something in the carby tweeked ,longer bar ?
is it painted something other than orange ?
husqvarna didnt change their saws designs radically
even the chains and bars from most husqvarnas will fit
this user manual will cover your chain saw
365 SPECIAL 372 XP 372 XPG
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_EUenAPen/HUSO2010_EUenAPen__1153180-26.pdf
May 06, 2016 | Husqvarna Garden
I installed a new after market gas tank on mi 365 huski when i start it, it runs at full throttle, with and without the throttle cable attached
Recheck your assembly...Something is either has the carburetor throttle plate held open or you have an intake air leak. Nothing to do with the tank other assembly problem.
Dec 15, 2014 | Husqvarna 362 365 371 372 Aftermarket...
Help husqvarna 372 chainsaw will not run
check with a husq.dealer,they had some crummy carbs that may need replaced not rebuilt
Mar 06, 2014 | Husqvarna Garden
Replacefual lines
Just take apart the air cleaner and any other covers around the gas tank and carb. you will see the lines, remove one and notice how attached, if you can re-use clamp good, if not count how many needed, take line to ACE, Auto Zone, Discount Auto you get the picture, ask for and give them gas line and also ask for clamps needed.
That's it.... any questions feel free to ask...
Nov 28, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need help in replacing a gas line on a Stihl chainsaw model ms250c. The line is cracked and leaking bad.
Best way i can help is to fix it for u. But if u want to try here goes. Pull off air cleaner housing, Fuel line runs from left of carb to under carb, remove. install new line. Looks easy, sounds easy, very tight fit.
Aug 24, 2011 | Stihl Garden
When saw is running it dies unless i undo the vented gas cap then the saw will keep going is there any other way on other than the gas cap for it to vent or help breath? on a 372 xp
The vent on the 372 is not in the cat, it is situated on the right hand rear side of the fuel tank, the early vent was a black pipe pressed into the tank with a white ( vion ) plug in it, this can be pulled out by screwing a self tapping screw into the middle of it and pulling out with a pair of pliers, the later breather is in the same place but consist of a green valve pressed into the tank, it then has a black pipe conected to it which comes up into the crankcase and sits onto a nipple under the air filter, this can be pulled out with a pair of pliers and replaced, the later breather is very prone to blocking, due to CE law and gas escape from fuel tanks the breather is very fine.
Jan 25, 2011 | Husqvarna Operator's Manual 365 372xp ...
Husqvarna 372 xp gas tank not venting has a new gas cap did not work
I looked at a 2007 IPL, your saw has a separate fuel tank vent. Husky is terrible about providing a nomenclature and you may need help from your local Husky dealer to identify components.
Find your "Illustrated parts lists" here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Nov 14, 2009 | Husqvarna Chain Saw 20" Bar
Need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Jun 30, 2009 | Garden
Chainsaw kills when I press the throttle
My 372 xp did that and when I talked to the repair shop they even showed me. There is a fiberglass gasket that is used to mount the carburetor to the engine. I have no idea on how this happens, but I saw it with my own eyes. The gasket had actually folded over. They replaced it with a rubber one and have had no problem since. The saw was hard to start, would run as long as I didn't try to cut anything and when I did it would open up and then die. I could be giving wrong information, but that sounds exactly like the problem I was having.
Oct 08, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw Models 371, 372xp Logo
35 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
