Question about Onkyo TX-SR505 Receiver
I suddenly have no sound in my tx-sr505. Any suggestions on how to fix? Is there a way to reset the system?
2 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: Hum in Onkyo TX-SR505
Try to check the cables connectors maybe loose or cold solder this a common problem also,or buy a branded cables if it hum again.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 07, 2009
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
How to connect android movie box (Mx3) to TX-SR505 receiver
The TX-SR505 does not support Video Streaming, Thanks, JT
Dec 19, 2015 | Onkyo TX-SR505 Receiver
I have an Onkyo TX SR505 receiver which for some reason, while watching TV or listening to music, there will be a click heard in the speakers and the sound will be gone. I'll shut off the receiver and turn...
It's probably self-protecting from heat build-up.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 19, 2011 | Onkyo TX-SR505 Receiver
How do I hook up my Onkyo receiver to my dish network box?
Take the cables from the receiver to the tv and connect it to your Onkyo where it says "in", then take another cable and run it from your Onkyo receiver where it says "out" and connect it directly to the tv. Make sure you cycle the inputs on your receiver and tv, so you get sound and video.
Daniel Busa
DISH Network Customer Service
Jan 05, 2011 | Onkyo TX-SR505 Receiver
The Display on our Onkyo TXSR505 HAS STOPPED WORKING.
that would be you display processor ,the display panel or chip would have to be replaced ,not worth it i had kenwood that did cost more than it is worth
May 19, 2009 | Onkyo TX-SR505 Receiver
TX-SR504 receiver won't turn on
Had same on an ONKYO TX-505 given to me for repair - eventually found a broken track on top circuit board that came from a transistor that control the main power on relay - looked like it was burnt off for a section of about 1.2mm
Repaired the track and has worked ever since
good luck WTech/Townsville
Mar 18, 2009 | Onkyo TX-SR505 Receiver
I know that this is not Cheap But, If you want this to go away you need to Upgrade the A/V Cables to Monster Cables and it will Fix this Problem!
Dec 30, 2008 | Onkyo TX-SR505 Receiver
Loss of video signal from Onkyo TX SR 875
Go to hardware set up and turn off the hdmi audio output,sounds daft but it should work,also make sure the B speakers are not on as this puts the menu up the left.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Onkyo TX-SR503 Receiver
Do all speakers need to have the same impedance? (Protect mode)
Amplifiers sometimes like to have "balanced loads" on them, and this may be the case with your unit, meaning yes, all the impedances should match.
Judging by the impedance numbers you provided, you should be all set. You really want to avoid having something like 2 ohms on the left side and 8 ohms on the right side - grossly imbalanced. I don't see any problems with what you're going to run.
Mar 24, 2008 | Onkyo TX-SR505 Receiver
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
Onkyo TX-SR505 Receiver Logo
26 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
