Question about Whirlpool Washing Machines
Will a Whirlpool LAB2700MQ Pedestal mount correctly on a wfw94hexw..the 94 calls for xhp155xw but I have a pair of the LAB's and want to re-use
WFW94HEXW calls for a 15.5 Pedestal but it is to high with washer to fit under cabintes and I already own LAB2700MQ Pedestals from my WFW9451XW..both are Duet models..is there a prblem with the 4 attaching screws matching it appears the weight of each washer is about the same?
4 Suggested Answers
  • 619 Answers
SOURCE: Whirlpool Duet GHW9150P, Screws for Pedestals
You can go near hardware if nothing stock you may go to washing machine junk shop you can select any part as you wish.
Posted on Jan 05, 2008
  • 1028 Answers
SOURCE: kenmore pedestal for the front loading elite washer and dryer
some pedistals have a screw on drawer just behind front on end of rail newer ones have a small black lever on each side ..pull drawer completely out lever is about midway at end of inner rail pull lever 1 up other down drawer will pull off rail reinstall by sliding rails back together and pusing all the way in
Posted on Jun 11, 2008
  • 12 Answers
SOURCE: washer vibrates and walks across the floor
Theres a few things you can do to stop it from walking.
but the best way i know is to use washer anchors.
Whirlpool part# 155P3 $22.95
Im going to assume that you have eaither the wfw8300 or wfw8400
the main differences is the suspention system in them. the 8300 uses a 5 point system that work but really you should only use the washer on solid flooring like concrete. the 8400 uses a 6 point with better shocks.
if you have this washer on a main floor with basment underneith it you might want to check the floor. grab a glass of water when it starts to shake and walk and put it on the floor, if the water is jumping then the floor is the problem.
eaither way the anchor kit i have listed above will stop your issues with it moving and walking.
Posted on Feb 07, 2009
Whirlpool wfw94hexw clean pump
You aren't going to like it but you need to disassemble the machine to get to the clean out. If you want instruction still please let me know.
Jan 27, 2015 | Whirlpool Washing Machines
Will LAB2700LQo pedestal fit my Kenmore model 110-47532602 or 1108752601
Even though the Sears brand is made by Whirlpool, the 110 series is an exclusive line. IT is not likely to fit. You will have to measure the base and mounting holes on the pedestal and the machine.
Jun 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
WFW94HEXW door won't unlock and Door Lock isn't lit
if you machine is warranty you must call to the whirlpool, and get the assistance via online chat. However you must wait about 180 seconds since you did the command STOP, and stop the motor, fi the water level is higher must be drain before the latch door unlock.
2) if do not obey press and hold END OF CYCLE, wait about 10seconds
3) reset the machine unplugged from wall by 45 minutes, and then plug again, and turn on and unlock the door
God bless you
Jun 21, 2012 | Washing Machines
Need a base for Hitachi P501H401
You could visit the Hitachi consumer website or call them.
You could also Google the model number with "pedestal stand" "mounting base" etc as there are some generic bases sold--also might have a look (long shot) on EBAY for one.
May 26, 2012 | Hitachi P50H401 50 in. Plasma HDTV
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
I bought a used panasonic TH-50PZ85U plasma TV that was wall mounted. I need a pedestal base. Called Panasonic 3 days ago and the have to "research it". Can you help? km
My ex-husband threw away the pedestal stand for the Polaroid Polaroid FXM-3211C TV DVD Combo which I now have. I need a pedestal stand....do you know where I can find one?
Jul 14, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the five screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Front loading washer on pedastal "shimmies" out of place at times. How do we keep it in place?
take it off the pedastel.... very bad design trust me
beyond that make sure the machine is very tightly mounted on to the pedestal
next jam wooded shingles between both on the twos sides and the back
it ususally takes 6 pairs of two you must tighten the gap between the units
this only works about 95 percet of the time
GOOD LUCK
Oct 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool pedestal w/ Kenmore Elite HE3 washer
no - the base is a different size.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 19, 2009 | Kenmore 15.5 in. Pedestal
Whirlpool WHP1000SQ 10" Pedestal this came with no instruction where can i get on line instruction
if you want to put the pedstal on unit..lay unit on back.pull draw out of pedestal ,than lay pedestal on back then put the bolts or screws in though pedestal ,,and stand ...
Dec 24, 2008 | Whirlpool WHP1000SQ 10" Pedestal In White
Washing Machines Logo
542 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
