Question about Apple iPod MA446LL/A MP3 Player
It shuts down wen i turn it on
Wat do i need to do to stop it from doing this
  • Apple Master
  • 2,794 Answers
Try rebooting the Ipod first by pressing the center button and holding down on the menu button.  This will reboot your ipod.
If it continues, try restoring you ipod back to factory settings using the restore program in Itunes.
Posted on Oct 23, 2008
Wat do you do when your chrysler 300 1999 keeps cuttin off compelety
Check your oil stick and make sure oil is up to the line on the stick.
Nov 07, 2017 | 1999 Chrysler 300M
I have a 97 Buick lesabre it'll die while driving the temp, battery, and oil pressure lights all come on it usually takes the car up to an hour to start. After stopped oil pressure will go to 20-25 but...
this issue sounds like u have a bad ignition control module,located directly under ur coilpak. thats wat they do wen they get hot aftr driving a while, shut off while driving(u must b loosing spark to ur plugs)an restarting wen cooled off. one way to check this for urself would b to purchase a spark checker at autozone or pepboys fairly inexpensive, an wen ur car dies, open the hood remove one sparkplug wire install tester between plug an wire, or wire an a good ground an have someone crank engine while u look at the tester bulb,if it lights up an pulses uspark is good,if it doesnt lite up at all while cranking engine ur spark is gone an thats ur problem possibly crank a sensor or the ignition module we mentioned earlier. try mounting the spark checker before the engine dies so u know wat a good spark will look like on that checker..... hope this helps good luck
May 01, 2011 | 1997 Buick LeSabre
Whenever i connect my cam to my lappy it gets shut down,it was never happened before wen i was using my cam,but now it shows some message like " some serious problem occured with ur hardware usb...
As your message suggested, you have a hardware fault which means your camera is possibly faulty.
I would book it into a repair shop and get it fixed.
Hope that helps.
Jan 23, 2011 | HP Compaq 6720s Laptop
When i am driving down the hwy at 60mph and in 5th gea it will cut off. If im slowng down in neutral it will cut off. It idols low in a stopped position. And it rattles. And sometimes when im driving the...
ok if you are runing on the fwy and let go the gas pedal the only air is coming in from the idle valve and on neutral the same ting what about wen you start the car first the rpm is high 1400 or 1500 then going down wen it get hot that car had two valves the cold idle valve and electric valve the electric valve control the regular idle wen the car is hot after the cold valve is closed
Dec 15, 2010 | 1992 Honda Accord
My 2002 jeep grand cherokee limited is reading low oil pressure but wen i accelerate it goes to middle pressure but then down to low wen i stop wat can be the problem?
Oil pump or other issues
Cam bearings,etc
Bad sending unit
I would put a mechanical oil pressure gauge on it,to verify oil pressure.
Certainly stop driving it ,until you find and repair
Nov 09, 2010 | 2002 Jeep Grand Cherokee
Word
shut down your computer
Nov 04, 2008 | Microsoft Office Professional 2007 Full...
YPK5 Stops
connect it to the computer and charge 4 round bout 30 min n take it out and hold on wen it comes up it should work again dats wat i did wen dat happened
Aug 31, 2008 | Samsung YP-K5 MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
29 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
