Question about Hoover PE235 Front Load Washer
Light comes on but machine doesn't start
Hi, I hope someone can help us. We have a Hoover PE235 which has just thrown a dicky fit (16 months old). It hasn't made any strange noises or smells but now when we press the on button, the light comes on but it doesn't fill with water or try to start. I've checked the water pipes and they both work (used a bucket), and the outflow pipe isn't kinked. Nothing is stuck in the door. I undid the filter to check if it was blocked which it wasn't. The only thing is that we had 4-5 off/on power cuts lasting 10 seconds last week, BUT the washer wasn't on at the time. Could this have done something? If anyone has advice, I'd appreciate knowledge on whether the fix is something I can do myself rather than pay a plumber. Many thanks in advance, CAHJ
    New Friend:
  • 163 Answers
Re: Light comes on but machine doesn't start
Well lets see, you have one of two or both, the water level switch or the timer, if the machine dont recive a good level of water(depend on the seting) it dosent start washing, but if the water level switch dont receive curent from the timer, it wont work, so you gona need a tech any way....good luck
Posted on Aug 07, 2006
0 characters
3 Points
Not spinning clothes come out wet
hello make sure spin hold button is not press in if there is 1 on this machine any other spin problems can be caused by module board this is at the back of the washer
Sep 12, 2010 | Hoover PE235 Front Load Washer
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
PE235 would not spin or empty. Now it wont cycle either
Check the filter at the bottom of the machine ,right hand side behind the plastic cover along the bottom. You may find a blockage in there.
Aug 06, 2009 | Hoover PE235 Front Load Washer
Sounds like you have a blockage in the filter or the motor brushes have worn down.
May 24, 2009 | Hoover PE235 Front Load Washer
Hoover washing machine front loader, has power, have reprogrammed, but still won't start. Door lock light won't come on. For the last few washes before it quit altogether, the time lapse between pressing...
Hi brennanjodi
I think your door interlock needs replacing. Turn off the power undo the front of the door gasket and that will get you to the lock mechanism. They're about £20 to replace.
May 14, 2009 | Hoover PE235 Front Load Washer
Washing machine
i had the problem of my brand new washing machine not taking the conditioner and the customer service advisor rightly guessed that i was using concentrated liquid and advised me to dilute it with warm water then put it in the drawer because sometimes the liquid is too thick for the machine to take.try this!!!!! regarding the powder why not put it directly in the machine or buy tablets and do the same with those
Dec 18, 2007 | Hoover PE235 Front Load Washer
Hoover pe235
Contact Hoover, they should be able to supply you with a new dial for not a lot of money. Warranty won't apply as it wasn't their fault. Good luck.
Dec 01, 2007 | Hoover PE235 Front Load Washer
Timer just spins round
yes it is the timer,i had the same thing happened to me on a hoover,i was told that the fault was when you turn the timer to a programme to do this slowly and gently and if you go pass a programme not to turn it back but to go forward again until you get to the right programme..hope this helps.all the a new timer may cost about £80 to £100.
Nov 19, 2007 | Hoover PE235 Front Load Washer
Hoover PE235
stock is the dangerous condition for mechanic parts, knock the water in take with a plier not to strong but strongly do this when the humming sound, check for cloged hoses too..good luck
Aug 10, 2006 | Hoover PE235 Front Load Washer
Hoover PE235 Front Load Washer Logo
245 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
