Question about Garden
Vng 3-1100 manual for Landa pressure washer
Pressure washer will not ignite. also no water pressure
4 Suggested Answers
  • 97 Answers
SOURCE: landa pressure washer manuals
send them an email at info@landa.com or contact them directly at 800-526-3248 for more info specific to your model which was not listed above. hope this helps you
Posted on Aug 10, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have an older Landa Pressure Washer. The burner
Check for 12V at the igniter connector with the unit running. If you have 12V and no igniter it may be stuck or bad. Thrun the unit off and read continuity across the DISCONNECTED igniter plug / terminals to the igniter. No resistance = open igniter.
If all of the above checks out your going to have to look at the fuel pressure switch to see if it closes and passes 12V to the igniter.
Before you give up... Check the fuse.
Landa's website is www.landa.com
You will have to select a local dealer for parts.
Thanks for using FixYa!
Kelly
Posted on Mar 11, 2010
LandaNW
  • 45 Answers
SOURCE: i have a landa hmp-4-3500 heated pressure washer
Landa does not have a model HMP so I am not sure which machine you have. If you can provide a full model and serial off of the model tag on the machine I can provide you with a digital copy of the manual you are looking for.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
Posted on Feb 14, 2011
How do i fix a honda landa 3500 pressure washer, when the water doesn't come out when started?
Check out the trigger mechanism. Water should come out at any time, even when you do not have the unit started.
Aug 22, 2016 | Honda Landa PG 3500 PSI Pressure Washer
What type of pump oil does the landa pressure washer use
to get this answer it is simple , google landa pressure washers then look for your model number and that shall tell you the exact oil you need
Oct 08, 2014 | Garden
Need wiring diagram for the burner on. a Landa 5-3500 pressure washer
If you can provide the full model and serial from the model tag on the machine I would be happy to send you a wiring diagram. The model tag is normally located on either the frame of the equipment or on the side of the electrical panel. Depending you your model it should look something like the following.
Model: PGHW5-35324ESerial: P0108-890345
We are the original Landa factory in Portland, Oregon and have digital copies of user manuals, breakdowns and wiring diagrams for every machine that Landa has ever produced. If you have any questions please feel free to contact me using the information below.
Sincerely,Aron KerrLanda Northwest, Inc.aron.kerr@landanw.comwww.landanw.com800.247.8103
Apr 16, 2012 | Garden
My hot water is not working i have power to relay that is new but it will not send power to my on off switch
I am a little confused by your question because a PG is a cold water pressure washer. In most mobile hot water machines there will not be a relay. My best guess is that you are talking about a GFCI that is not sending voltage to the On/Off/Burner cam switch. To check this you will need to verify that voltage is actually passing through the GFI. If you can clarify with a model and serial for your machine, I will be able to give you better trouble shooting instructions.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Dec 31, 2010 | Honda Landa PG 3500 PSI Pressure Washer
Looking for owners manual for Landa PC4-2000 pressure washer
We are the original Landa store in Portland, OR and have every Landa manual available both in digital and hard copies. If you can provide a serial number and email address I would be happy to send one of these out to you right away. You can reach me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Oct 27, 2010 | Garden
When chemical injector is attached, it works fine. When I put one of the power tips on, I do not get any pressure.
When using the chemical injector your machine is only having to operate under low pressure. This means that your pump only has to transfer water and does not have to compress it. When you insert a pressure nozzle you cause the pump to have resistance and therefore it has to compress the water to make pressure. If you pump seals or valves are worn the pump cannot build this pressure. You need to either rebuild your pump yourself or have it looked at by a service center. If you have any other questions or need parts or service please feel free to contact me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Sep 23, 2010 | Honda Landa PG 3500 PSI Pressure Washer
I have a landa hmp-4-3500 heated pressure washer and i am problems with the water heater. where can i find a trouble shooting guide for this machine
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
May 19, 2010 | Honda Landa PG 3500 PSI Pressure Washer
I have an older Landa Pressure Washer. The burner is not working. Once I get the machine running and water flowing to the pressure washer, with the wand pressed, I flip the burner on switch....and...
Kelly
Mar 10, 2010 | Garden
I need to buy a pressure washer for residential/commercial work
Were I to pick from one of those three, I would pick the Landa. The most reliable pumps are Hotsy and since Karcher bought Landa and Hotsy, those three brands now have Hotsy pumps, though it doesn't say it on the machines.
Jan 01, 2010 | Honda Pressure Washer PSI 3000
Landa pressure washer manuals
Aug 09, 2009 | Heavy Duty Garden
Garden Logo
200 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
