Question about Watches
TAG HEUER CG1111-0 instructions?
Where can I download a manual for setting and operation of this watch?
ThaMp3Doctor
  • 8596 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
escapement
  • 2334 Answers
SOURCE: I can't seem to set the time on my used tag heuer watch
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Don't forget to rate, please.
Posted on Jan 10, 2009
  • 93 Answers
SOURCE: Tag Heuer WK1110 Date Changing Problem
This could be caused by a couple of things. To fix this would require a qualified watchmaker to repair. The watch will need to be taken apart and the dial and hands will need to be removed to repair this problem.
Normally when we see this problem one of the wheels needs replacing. This can be caused by manually changing the date near midnight.
Let us know if we can help more.
Ken
Yellowstone Watch Inc.
Posted on Oct 05, 2009
rootbeer001
  • 352 Answers
SOURCE: Tag Heuer watch
The knob is a screw-cap seal. When closed (screwed in) it closes the chamber to prevent water from entering the watch.
You will need to unscrew it. It should snap out. In this position, you can wind the watch. Pull the knob out one click, and you can adjust the date. Pull the knob another one more click, and you can adjust the time.
Push the knob back in. In order to seal the watch back up, you will need to push the knob in while turning the knob. You will know you did it correctly when the knob will not turn any further.
Good luck.
Posted on Mar 25, 2010
mcdevito75
  • 1970 Answers
SOURCE: My tag heuer wk 1111-0 has a serial # mb 9169 ;
mcdevito75 here, The number on the movement itself is the number you need, Look for any small watch repair shop in your area for an estimated age, or you can contact Tag Heur online, try tag Huer watch.com
Posted on Jul 07, 2010
I need an instruction manual for a Tag Heuer 50 Chronograph Aquaracer mens watch
Tag Heuer recognizes manuals by watch caliber number, not the watch model. Browse through my Tips and Tricks. There are few Tag Heuer watch manuals. Check out if this can help you.
Feb 24, 2011 | Watches
I don't know how to set the date properly on my Tag Heuer formula 1 watch. Is there a time of the day that I should do it?
If you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1110.BA0850 , you will see a menu on the right of the screen.
Clcik on "user manual" to download the manual for your watch.
There are no instructions about setting the date apart from saying the date changes at midnight but you can advance the date by winding it past midnight. If you want to advance it more than one day, wind it back and then forward past midnight again. Repeat as many times as required until you reach the date you need.
How far back you need to wind the watch you will have to find by eaperimenting and observing when the date changes. You might hear a soft "click" when winding it backward, you can the wind it forward again.
Feb 01, 2011 | Tag Heuer Formula One
I need to know how to use my cl1112 Tag Heuer
Copy "ww2.tagheuer.com/_documents/manuals/EI2246_en.pdf"" into your search engine and it will take you to a generic instruction manual for TAG watches.
This manual includes instructions for operation of your watch.
Mar 01, 2010 | Watches
Tag Heuer Formula 1 with alarm WAH111A.RWV3350
You can find the instructions on the Tag wed site (www.tagheuer.com), select "watches" then "formula 1"
then "man" and then the model of your watch.
On the right of the page is a small menu,select "user manual"
Feb 09, 2010 | Watches
My alarm does not sound on my Tag Heuer Kirium F1?
Have you a copy of the manual?
If you have, then you will see that it can be turned off (last page), is this likely to be the case?
If you need a copy, go to their web site "tagheuer.com", select "watches", then "tag heuer formula 1", then "man", followed by "Tag Heuer F1 chronometer" and finally you will see on the right a menu, select "user manual".
This seems to be a generic manual that cover both the chronometer and alarm version of the watch.
If these are not the correct instructions for your watch, opposite the "user manual" menu is a search box, put your watch model in this and there should be a user manual with it.
If not look at a similar watch for a generic manual.
Jan 27, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
I cant seem to find my instruction booklet. where can i get some info on my CAC1111
Go to the Tag web site "www.tagheuer.com/the-collection/tag-heuer-formula-1"
Select "men"
Select your watch and on the right you will see a menu,
select user manual and download.
Jan 15, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I HAVE A TAG HEUER AQUARACER ELECTRIC WATCH (BATTERY OPERATED) THAT HAS AN ALARM FUNCTION THAT I CANNOT SHUT OFF. IT GOES OFF EVERY DAY. HOW CAN I STOP THIS?
I presume you no longer have the instructions, so I explored the Tag web site and they do not appear to offer an option to download instructions for your watch.
The only thing I can suggest is that you go to your nearest dealer and ask for help. You can find out where your nearest dealer is by going to the TAG web site "tagheuer.com". select one of the watches and on the right of the screen you will find a menu which includes "find your nearest retailer", who will be able to help.
Jan 12, 2010 | Tag Heuer 2000 Aquaracer Chronograph...
Need instruction booklet for Tag Heuer Classic Chronograph 2000
PDF Manuals at Normal 0 0 1 2 14 1 1 17 11.1282 0 0 0 www.tagheuer.com
Do a search for Tag Heurer manuals
Mar 29, 2009 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Just Got a tag professional ( Previously Owned)
Hard to tell without knowing what model or caliber number (usually on back). Generally, if you pull the crown (winding knob) out all the way you can set the time. Push it ONE click in, you can set the date. Check with the manufacturers website for a book of instructions you can download.
Jun 24, 2007 | Tag Heuer 2000 WK1110.BA0317 Wristwatch
Watches Logo
362 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
