Question about Electrical Supplies
My Champion 5250 watt generator starts but produces no power
  • 2976 Answers
SOURCE: My generator starts but not give 220 volts power
Check the voltage regulator and any fuses or breakers.
Posted on Jul 02, 2009
  • 5603 Answers
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Posted on Aug 11, 2009
SOURCE: My Troy-bilt generator will not generate watts
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
Posted on Sep 30, 2009
sal_kh_sab
  • 98 Answers
SOURCE: I own a coleman powermate 1000 watt generator. the
try checking the AVR card...or wireing....
if all of them r fine...chek the brushes
Posted on Oct 11, 2009
  • 4 Answers
SOURCE: I have a porter cable 5250 generator that bounces off the governo
there 2 linkages that conect that would be the problem. you have on conected to the throttle switch that runs to the govener than on that govener os another linkage hooks up to it and runs to the carborator that ajusts the flow. if you don't have both linkages than you need to order 1.
Posted on Oct 25, 2009
Champion generator manual
May need to have the field flashed. There are numerous videos on youtube showing you how to do this.
Aug 24, 2014 | Champion 3500 Watt Generator Weekender...
This gen won't start , good fuel, carb good get's air & fuel spark plug new. any ideas
if it has air fuel and spark then check the compression. if it has all 4 of those then it will be a timing issue but I am willing to bet you are missing 1 of the 4.
Sep 28, 2013 | Champion Fulfillment Champion 2000 Watt...
Need help with diagnosing generator not producing power
may be a bad breaker or a shorted wiring problem. not generating any power, I would ck. the brushes inside the generator.
May 19, 2013 | Briggs & Stratton Power Products 5,550...
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
The coil rope broke I would like to know how i can repair it. Generator 5500 watt champion.
If I understand correctly, you have a pull-start generator.
The rope to the pull-start broke.
This happened to us out on the job one day.
Our equipment might be different than yours. Our pull-start assembly is held with 4 bolts. Simply remover those bolts and lift off the cover ... carefully. The rope is attached to something I will call a pulley. The rope wraps around the pulley several times.
Do not lift out the pulley that the rope attaches to >> or the spring that re-winds the rope will come un-sprung (at least it did on our machine). If the spring comes unwound, then you got another job, and have to put the spring back also. Your machine might be different.
Keep pulley in place. Remove rope. Get another rope with same diameter and length and put it in.
Oct 18, 2010 | Champion International Champion Power...
PF 2500 watt generator... Need plug and oil
30wt oil, probably a Champion RN4C plug. Could give link to a manual if part / model number of generator was provided.
May 17, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
My 5250 watt Power Back generator will not start, and their is no spark at the spark plug.
Have you check the engine oil level?If it is down on oil you won't get spark because of the oil level switch shutting the ignition down to protect it's self.
Jan 22, 2010 | Groove Tubes Power Back 5,250-Watt...
Generator rus fine but does not produce power
check the brushes at the armature,armature should be shiney,if not take emory cloth and clean the armature,see if that helps.
Jul 06, 2009 | Hobart Welders Champion 500433A Factory...
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Electrical Supplies Logo
90 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
