SOURCE: what does a code f51 stand for on a kenmore oasis
F-51 ERROR CODE IS DEALING WITH THE SPIN CYCLE. THE CONTROL DOES NOT DETECT IT SPINNING.THE RPS SENSOR ON THE BOTTOM OF THE UNIT NEEDS TO BE TAKEN OFF AND PUT BACK ON ABOUT 10 TIMES. SOUNDS WEIRD BUT USUALLY FIXES IT. THEY DO HAVE A KIT ALSO FOR THE RPS TO BE REPLACED. UNPLUGGING FOR A FEW HOURS IS A TEMP FIX.
SOURCE: why is my kenmore elite (top loader) oasis washer
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
SOURCE: du error code on a kenmore elite oasis he what
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Hello, I have a
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: just inherited a kenmore elite oasis dryer model 110 77092600
searspartsdirect.com - and enter your model #.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
