Question about Coleman Powermate Premium Plus 6250W Portable Generator
Powermate PM0496500.02 No voltage output
I replaced the automatic voltage regulator and brushes. But no voltage output.
    President:
  • Coleman Master
  • 1,388 Answers
Here is a simple test to check field and other wiring. With engine off apply 12v ac 1 amp to 110v outlet plug on generator. This will energize the field windings and should cause the armature to produce dc voltage at the brushes and produce a nice magnet. If there is a short in the field or broken wire or shorted capacitor there will be no dc reading at the brushes. . This test is the opposite of what actually occurs when the engine is running. That is the armature produces a magnet fed thru the windings, regulator and brushes. If dc voltage is present at the burshes, remove 12v ac and start engine to check for output. enjoy
Posted on Dec 01, 2008
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Powermate 6250 PM0545008 Voltage Output is at 129V, Is this safe for my house hold appliances? Is there a way to adjust the voltage?
    It isn't really a good idea to use a portable on "modern home elctronics" the way the regulate the voltage is not a s tight as a digital AVR found on permanent home generators. While this voltage is not uncommon, I would not recommend it
    Jan 15, 2012 | Coleman Powermate Powermate 5000W...
    High voltage rpm power generator output
    Not sure what you mean "high voltage rpm power generator out", however many people have asked how to adjust the engine for proper voltage output. On generators with~out a voltage regulator, I adjust the engine RPM by using a digital voltage meter that has a Hz setting. Adjust the governor untill the meter displays 60 Hz. With the geneator producing 60 cycles, I know that the engine is turning 3600 rpm (the engine produces max hp when it is turning 3600 rpm). At this point, read the voltage output to verify that the range is between 115 ~ 120. On generators with a voltage regulator, verify/adjust that generator is producing 60 cycles then adjust voltage by turning screw at the regulator (some regulators are sealed with potting compound and can not be adjusted). If your power demands are not that great and you appliance can operate at 50 cycles, adjust governor as needed. Lowering to 50 cycles will also reduce output voltage. Good luck
    Oct 10, 2011 | Coleman Powermate Powermate 5000W...
    No ac output, all circuits have continuity,no broken wires etc. capacitor appears to be alright nothing appears to be cooked.
    I think you have a problem with the Automatic Voltage Regulator. I have ordered one from the New Company that purchased Powermate. It solved my problem.
    Dec 23, 2010 | Coleman Powermate Premium Plus 6250W...
    Ust 3000 generator-only idles-no voltage output
    chek brushes...if they seemed ok then replace AVR card
    Sep 05, 2009 | Coleman Powermate Powermate 5000W...
    Powermate 5500 no Power on plugs, shorted stator symptoms?
    Stator resistances should be around .5 ohms. This may look like a short to you. Unhook the regulator from the field brushes and put 12 volts on the field winding. you should get output to partially light a bulb..maybe 60 volts. Remember to use 12 volts dc on the fields and don't reverse the polarity.
    If there is output then the avr(voltage regulator) is probably bad. If there is no voltage then check the resistance on the brush contacts. through the bushes and field. Maybe around 25 ohms. Your generator manual can give the exact ranges. No resistance then clean the brushes and slip rings and check again. No resistance...take reading on the slip rings. No resistance...open field...bad rotor. Good luck....keep posting until problem is resolved.
    Jul 01, 2009 | Coleman Powermate Premium Plus 6250W...
    Generator went out. no power at all
    You need to check the resistance of the rotor, should be over 5 ohms and under 20 ohms. The voltage going to the brushes is DC voltage, not output voltage. You should see at least 10 to 60 volts dc at the brushes. If there is no dc voltage at the brushes then your voltage regulation circuit is bad or your stator is not providing the voltage to your voltage regulator. Also, make sure your rings are cleaned and your brushes have a good length and that they sit right on the rings. Clean the rings with 150 to 200 grit emory cloth until you see the copper shine.
    Apr 14, 2009 | Coleman Powermate Premium Plus 6250W...
    No charge
    You'll need to test to see if you are getting voltage from the brushes. This is a live test so, using something like alligator clips or such on the metal bracket of the brushes for your volt meter is a good idea. Simply start your generator with the volt meter leads attached to the the brush holders or exposed electrical connection to the brushes and see if they are producing electricity (120vac or greater). No voltage then it's your brushes, field, or stator. If they are good check the output of the voltage regulator. If it to does not kick down any voltage above 120 then it's your problem.
    Note most cheap generators do not have a voltage regulator. All generators depend on the correct engine rpm to achieve normal voltage. 3600 rpm is the correct speed on a two pole generator to produce 110 to 125vac and 60hz (normally found on gas generators). 1800 rpm is the correct speed for four pole generators (normally found on diesel generators). You may set your rpms slightly higher to ensure that it's maintained underload ie 3750 for gas. Diesels usually have very good governors and don't need to be set higher.
    Mar 29, 2009 | Coleman Powermate Powermate 5000W...
    Brushless powermate (Black Max) Brand New Unit but never put out power
    I looked at your parts blow up and noticed that you generator has a brush pack and a voltage regulator. Here are a couple of tips that may help you determine which part is at fault. Obtain a 12 - 16 volt ac power supply of about 1 amp and same voltage DC power supply. I find these at a thrift store and are used to power phones or door bell etc usually about 2 to 3 dollars each. This size power supply is relatively harmless and will not shock you or damage your generator. Remove the brush pack and set aside. You are going to apply 12-16v AC voltage into the 115v plug of your generator. You should hear a very slight hum in the stator if the winding is not open or shorted. Assuming that the 115v winding is ok, there should be voltage at the commutator rings and the armature should actually be making a magnet force. You can turn the armature slightly and actually vary the voltage at the rings. If you are getting voltage at the rings then winding and armature are progably ok. Remove the AC power supply and replace the brush pack. Next use the 12-16v DC 1 amp power supply (paying attention to polarity) to replace the voltage regulator. Disconnect the voltage regulator from the brushes and use the DC power supply to power the armature thru the brush pack and start the engine. You should get some low voltage at the 115v outlet and more important some ac voltage at the leads that power the voltage regulator. If no output at the leads to regulator then winding is open or short, if ac is present then regulator is most likely fault. Good luck, hope this helps, enjoy.
    Dec 19, 2008 | Coleman Powermate 7,000 Watt 13 Hp...
    Coleman Powermate Premium Plus 6250W Portable Generator Logo
    753 people viewed this question
    Top Coleman Electrical Supplies Experts
    John Trevino
    Phil Walker
    Phil Walker
    Tim Garcia
    Tim Garcia
    Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
