Question about LG enV VX9900 Cellular Phone
My enV i have two enVs that recieved water damage. both of them barely got wet worked for a few housrs then stopped working. i really dont wanna go buy another one. can they be fixed any way??
No the same thing is happening with my sister's phone. she dropped her's in a puddle and a toilet and now it wont charge and her screen turned red/orange. you can try airing your phone out but that may not work. the env is a horrible phone. i had four or five of them, get a different phone as soona as you can!!
Posted on Oct 25, 2008
Touch screen on my env touch will not work
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Apr 02, 2010 | LG enV Touch VX11000 Cell Phone
Hi. Have an env. Have it in a silicone case. It just fell on the drive - in a puddle which did not cover the phone. Immediately picked it up and removed the case. It really was not wet at all. I took my...
the screens have probably been damaged, i would try taking it to verizon so they can make sure and so that your phone doesnt get anymore problems from the puddle.
Dec 02, 2009 | LG enV VX9900 Cellular Phone
Flashing Verizon Logo
it's possible your battery is mot putting out enough to run your phone. if you didn't drop it or get it wet.
Try replacing the battery and see if that handles your problem, I suspect it will
May 30, 2009 | LG enV VX9900 Cellular Phone
Water damage
Its likely not the screen but the vidio chip on the board
Apr 19, 2009 | LG enV VX9900 Cellular Phone
The people I call can't hear me on my LG Envy
You can tell if your phone has gotten wet by taking out the battery. There's a little sticker both on the phone and on your battery that is white with little red crosses on it. If it's faded and red, you have water damage. I recently had the same problem though, without any water damage. They told me that it was not a common problem.. but it's happened to me twice, on two different Env's. Soo... sounds like a common problem to me.
Nov 18, 2008 | LG enV VX9900 Cellular Phone
ENV (gen 1) blue screen and won't hold charge
i think you should talk to verizon about getting a new one. you really have to keep annoying them eventualy you should get your new phone!
Nov 15, 2008 | LG enV VX9900 Cellular Phone
My enV won't hold a charge
You said the new battery worked but wont charge in the phone. You had water damage to the phone before getting the new battery correct?
First remove any Mini S/D card in the phone, power it off and remove the battery. ( only do this if its out of warranty and nothing else works. ) Your need to take the phone apart and get some alcohol wipes and wipe down the circuit board and connectors and anything that may have had water on it, if you see any crude, try to rub it off, there may be water and crude built up on contacts from the water damage that may be shorting the phone. Also check the battery contacts for greas or crud on the contacts. Once you have wiped down everything the alcohole should evaporate and take any moisture with it. Leave it out for a day dis assembled so it can air dry completely.
Put phone back together and hook up the charger and see if it charges. wait to put the memory card back in as in case you screwed anything up, you dont want it to take out your memory card with it.
I have performed this task with many of my friends cell phone that have gone through washing machines or got moisture in it because they take there phones into a steamy shower and moisture ends up shorting it out.
If nothing else works and you want to try it, go for it.
remember theres 6 screws in back and 4 around the mainscreen that are covered with triangular sticky covers, then use a thin knife or something to pry from one of the corners, one it gets started you just have to pop it apart with your fingers. Everything snaps back together easily.
Be carefull on the side with the screens, you dont wanto to pop apart the front screen from the mainscreen as its a pain to keep together when putting it back, also dont get any dust or fingerprints on the screen as they will drive you nuts if you put it all back together and theres a greasy fingerprint under the plastic that protects the screen.
Good luck
Mar 21, 2008 | LG enV VX9900 Cellular Phone
EnV
Wet -- pinkish red
Not Wet red and white.
Dec 18, 2007 | LG enV VX9900 Cellular Phone
Hey
When my screen got wet, I took it to Verizon. If your water indicater doesn't show any water damage they will give you a free phone no charge.
The water indicater is located underneath the battery, Pop the battery off and if the little circle is red there is no water damage.
Hope this helps.
Nov 30, 2007 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
123 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
