Question about HP Officejet Pro L7680 All-In-One Printer
Hp officejet pro l7680
Printer started printing in mirror image. I can fix the settings and take mirror image off and it automatically defaults back. Also the printer has started printing in photo mode and I have to change the settings back to regular printing each time I print. How can I get the settings back to the original settings that allow me to print without stopping and fixing the settings each time?
  • 6 more comments
  • Anonymous Nov 21, 2008
    all of a sudden, my HP office jet pro prints in reverse though the "print screen" shows a normal page- when I hit "print" it comes out in mirror mode. HELP! thanks!
  • stacy945 Nov 22, 2008
    same problem as posted
  • bthomson2 Nov 25, 2008
    HP Officejet Pro L7680 on Windows Vista Ultimate - connected via USB
    Prints mirror image through computer connected directly or through the network. Unchecking the box for "mirror image" helps, but it must be done before every print. Not good in an office setting!! Any ideas?
    I have uninstalled and reinstalled the driver and printer to no avail. The driver then freezes my Outlook 2007. I have done an uninstall/reinstall on my office product as well.
  • kingstamina Nov 28, 2008
    Excatly the same mirror image printing problem. Drives me nuts!
  • Anonymous Nov 28, 2008
    I have the same problem with my Officejet Pro L7580. I need to change the mirror image setting every time I print. Irritating.
  • Anonymous Dec 22, 2008
    same issue.
  • nelsjl Jan 06, 2009
    same issue
  • sanford65 May 21, 2009
    I have the same problem, however, Vista denies me permission to turn the mirror setting off. So I can't change my printing preferences. Any solutions?
  • HP Master
  • 419 Answers
The solution above does work temporarily but does not deal with the default shortcut settings, particularly the "Two sided printing (duplex)" one.
I've posted a full solution here:
http://www.fixya.com/support/t1641997-mirror_image_printing
Posted on Feb 14, 2009
To solve this problem, you need to set the mirror image to 'off' under the advanced tab of the printing defaults and under the advanced tab of the printing preferences buttons. We had this problem for some time and since doing the above this has stopped.
Steve
Posted on Feb 09, 2009
SJAK00's solution is exactly right but here is more detail if you're like me and need step-by-step detail on how to find these tabs: Go to Control Panel and Open Printers and Faxes.
For the first setting change: Right click the printer you want to set the default printing preferences on. Click on Printing Preferences, then on the Advanced Tab the Printer Preferences will list Mirror Image, which probably says: "On"--click on this and choose "Off", then save the setting by pressing OK.
For the second setting change: Open the printer settings by double clicking on the computer in question. The printer screen (the one that shows the jobs in process) will come up and at the top click on Printer. Go again to Printing Preferences, and again switch the Mirror Image desigantion from "On" to "Off" and save it.
This worked for me. Jan
Posted on Feb 10, 2009
Text prints fine. However images are printed smeared. It looks like each image has a mirrored shadow. How can I fix this?
Fist set for default settings, calibrate color.. it will resolve the issue ..even its remin service involment must..
Sep 11, 2011 | HP Color LaserJet 2600n Printer
Suddenly print in mirror image
I'm almost positive that the printer setup is causing this problem. To fix this you will need to go to
Printer Properties... then
Finishing....
Under the header: ORIENTATION ..... UNCLICK the "MIRRIOR IMAGE"
Then make that format your default or it will continue to switch back to Mirror Image....
I hope this helps, if it does please click the thumbs up!
Jun 28, 2011 | HP Officejet Pro L7680 All-In-One Printer
Hp printer is printing mirror image backwards. How do I fix?
go to control panel>printer> right click properties> seach the tab thet shown the image printed is rotate or not and set it by default
Dec 03, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
HOW DO I DO MIRROR IMAGE PRINTING
go to start, printers and devices, double click on your default printer (the one with the check mark) click on adjust print options, click ok on the popup window, click on the advance tab and there you will see different options for your printing preferences. click on the plus next to printer features, you will see mirror image and it will say off next to it. Click on it and change it to on. click apply, ok and you'll be set! To turn it back off just use the same process but select off under mirror image printing.
hope that helps!
Oct 10, 2010 | ASUS Computers & Internet
When printing everything prints backwords.????????????
Go to Start printers and faxes. Right click on Hp printer. Go to properties. Go to advanced. Open the printing defaults tab.Open advanced tab.Look for Printer Features : Mirror Image. Set this to no
This should correct your problem.
Hope this helps
Please leave feedback
Nov 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer is printing job as a mirror image
I would have said Gotta be setting in your print dialogue box, but if the test page comes out as mirror image, must be
a setting on printer control somewhere
Apr 21, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
go into the properties setting for the printer, go to advanced tab, then to the prinint defaults button on that tab. When you click on that - if you go to the advanced tab within there, you will see "mirror image" and i bet it says "ON" - click on the word mirror and it opens up the ability to set this back to off. Hope that helps!
Mar 26, 2009 | HP Officejet Pro K5400n - - colour -...
Mirror Image printing
This is caused by an early driver version provided with the printer.
Download the latest version from the HP website, unplug your printer from your computer then uninstall your existing driver. Once that's successfully completely install the new driver version.
Unfortunately this doesn't always resolve the problem straight away so you may need to repeat this.
To check if you've resolved the problem:
- Go to START > Printers & Faxes
- Locate your L7780 printer
- right click and choose "printing preferences"
- choose the "Two-Sided (Duplex) printing" printing shortcut
- click on the "Advanced" tab
- look at the setting for "Mirror Image"... If you've succeeded this should now be set to "Off"... If it's "On" you still have a problem.
The problem itself is caused by some duff default settings which seem to stick whenever you've done anything that uses the "Two-Sided (Duplex) printing" Printing shortcut provided in the printing preferences.
In particular I've seen this crop up with PDF files...
The new driver does seem to resolve this but a further work around is to define a new duplex setting that has the correct "Advanced" settings and has "Mirror image" set to Off.
This solution also works for the K5400, L7580, L7680, etc...
Feb 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printing backwards
When you get the print window, click "Properties", then click on the "Advanced" tab. Look for a "Mirror Image" menu item. It should say "Off". If not, click on it and you should get a drop down box to change it to off.
Oct 15, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Printing a mirror image
try to print as T-Shirt transfer - the printer automatically mirrors the printout then
May 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
632 people viewed this question
Ben Johnson
