Question about Xerox DocuColor 12 Printer
Error Code - 9-343 on Doc 12
I am getting a system fault on my Doc 12. The code is 9-343. When I turn it on there is the sound of a clutch grinding. It grinds twice for 1 second each and then I get this error code. The sound comes from the left side odf the machine.
I am looking for help on this issue and someone who can service it in the Toronto Ontario area. Any help would be appreciated. Thank you
  • 848 Answers
It seems you have problem in sensor ...........
change the FD interlock......
Posted on Oct 23, 2008
  • 136 Answers
That means , second BTR is not in contact with transfer belt. Open front door and pull out paper transport and check that is everything OK with black roll and her assembly.Check sensors for dirt,and gears for damage.If You have used one ,replace it
  • 2,035 Answers
Try to unplug the unit for 30 min and then plug it back and check if your the same problem :
TO get service in your area please call:1-800-835-6100
Good luck...
  • 53 Answers
Try changing the FD interlock SW. Also check if the gears on the 2nd BTR are having good contact with the clutch. If still no difference, replace the 2nd BTR clutch
That indicates fault code 33 which is a faulty ignition coil
Fault code 12 - Crankshaft position sensor
Fault code 13 - Intake air pressure sensor
Fault code 14 - Intake air pressure sensor
Fault code 15 - Throttle position sensor
Fault code 16 - TPS
Fault code 19 - No signal from ignition to ecu
Fault code 22 - Intake air temp sensor
Fault code 28 - Engine temp sensor
Fault code 30 - Tip over sensor
Fault code 33 - Igniton coil
Fault code 39 - Fuel injector
Fault code 41 - Tip over sensor
Fault code 44 - Read write error ECU
Fault code 46 - Power supply error to FI system
Fault code 50 - Ecu malfunction
Jan 08, 2015 | 2009 Yamaha yBR125
When i pull the code up on my 1992 park avenue it blinks once then blinks twice. what does this code mean?
This is code 12 and it means "System Normal"
Here is the complete list of fault codes for your Buick
GM common codes for OBD1 (for vehicles made before 1995)
12 System normal
13 oxygen sensor circuit open
14 coolant sensor high resistance or shorted
15 coolant sensor circuit low or open
16 direct ignition system (DIS) fault in circuit
17 cam position sensor fault
18 crank or cam sensor error
19 crank sensor circuit fault
21 tps sensor out of range
22 tps sensor signal voltage low
23 intake air temp sensor out of range, low
24 vehicle speed (vss) sensor circuit fault
25 air temp sensor sensor out of range, high
26 quad-driver module (computer) circuit #1 fault
27 quad-driver module (computer) 2nd gear circuit
28 quad-driver module (computer) circuit #2 fault
29 quad driver module (computer) 4th gear circuit
31 cam position sensor fault
32 egr circuit fault
33 map sensor signal out of range, high
34 map sensor signal out of range, low
35 idle air control sensor circuit fault
36 ignition system circuit error
38 brake input circuit fault
39 clutch input circuit fault
41 cam sensor circuit fault, igntion control circuit fault
42 electronic spark timing (EST) circuit grounded
43 knock sensor
or electronic spark control circuit fault
44 oxygen sensor lean exhaust
45 oxygen sensor rich exhaust
46 pass-key II circuit or ps.pressure switch circuit fault
47 pcm-bcm data circuit
48 misfire diagnosis
51 calibration error, mem-cal, ecm or eeprom failure
52 engine oil temperature circuit, low temperature indicated
53 battery voltage error or egr or pass-key II circuit
54 egr system failure or fuel pump circuit low voltage
55 a/d converter error or pcm not grounded or lean fuel or frounded reference voltage
56 quad-driver module #2 circuit
57 boost control problem
58 vehicle anti-theft system fuel enable circuit
61 a/c system performance or degraded oxygen sensor signal
62 engine oil temperature high temperature indicated
63 oxygen sensor right side circuit open or map sensor out of range
64 oxygen sensor right side lean exhaust indicated
65 oxygen sensor right side rich exhaust indicated
66 a/c pressure sensor circuit low pressure
67 a/c pressure sensor circuit or a/c clutch circuit failure
68 a/c compressor relay circuit failure
69 a/c clutch circuit head pressure high
70 a/c refrigerant pressure circuit high
71 a/c evaporator temperature sensor circuit low
72 gear selector switch circuit
73 a/c evaporator temperature circuit high
75 digital egr #1 solenoid error
76 digital egr #2 solenoid error
77 digital egr #3 solenoid error
79 vehicle speed sensor (vss) circuit signal high
80 vehicle speed sensor (vss) circuit signal low
81 brake input circuit fault
82 ignition control (IC) 3X signal error
85 prom error
86 analog/digital ecm error
87 eeprom error
99 power management
May 05, 2011 | Buick Park Avenue Cars & Trucks
Fault code 00111 110 = 62. 1-2 inches of water in tub. Advance to spin and hit start. Gets a small vibrate sound, multiple times (10-15), then fc62, then beeps until I powered it off. Drain pump test ...
Hi just read your posting.The error code you indicated is called PUMP FAULT.The 2 things that cause this error code to appear are a faulty pump or a faulty control module.The manual says this fault is detected by excess electrical current going to the pump.But even if you test the ohms rating of the windings and it is about 33 ohms it could still be faulty due to the inductance of the pump being faulty.When I do a service call and get this fault I change the pump and if the fault is still there I change the control module.My best guess would be the pump but as I mentioned earlier it could be the control module.Please reply on how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
Sep 20, 2010 | Fisher and Paykel (IWL12)
I need to know what the code 18 and 41 means for 93 Buick Park Avenue Ultra with a 3.8 litre supercharged eng
When fixing codes start with first code first / it dos not always mean that the sensor is the fault ,it could be in the harness / the plug or the ground. and reference signal should be tested , but in this case you most likely could get away with replacing the cam sensor, that would be the Lest expensive and easiest to start with,to git to it you will have to remove the alternator hope this is help full, the other code suggest that it could be the crank sensor , that and the plug for it does fail quite often but first things first feel free to ask if you should have any further questions , Thank you ,
Mar 31, 2010 | 1993 Buick Park Avenue
Doc 12 System Fault ... Error 9-363
This means you have problems with either your Toner Ctg, Developer Unit or worst Drum Cartridge
I would start with Toner
do you remember which toner ctg you installed
or recently replaced ?
Jul 23, 2009 | Office Equipment & Supplies
99 Saturn SC1 ''Service engine soon'' light is on.
Did you get the code that triggered the SEL? If you know that, it will be easier to diagnose your problem. You can do it without a tool on the old saturns. Just need a paperclip. :
Use a paper clip to jumper Terminal A and B of the ALDL *Assembly Line Diagnostic Link* which is above your left knee.
Terminal A is an interal ground and is the top right terminal in the connector. Terminal B is directly adjacent and to the left of Terminal A.
Turn the ignition to ON.
All codes are 2 digits between 11 and 99. Codes are displayed on the SES light by flashing the light with short and long pauses to distinguish digits of one code from digits of another. The short pause is used between digits of the same code, long pauses are between codes. Also, each code is flashed three times before going to the next code.
For example, the sequence of code 12 will be: flash, pause, flash-flash, long pause, then repeat 2 times. If Code 12 is not displayed, the self-diagnostic pogram i snot functioning properly.
If only Code 12 is displayed, no system malfunctions have been stored.
Any existing system fault codes are displayed in order from low to high, except for Code 11.
On vehicles with an automatic transaxle and on which exist stored transaxle codes, Code 11 will be displayed last, then the SHIFT TO D2 light will begin flashing transaxle codes of flags.
When all engine codes have been displayed, Code 12 will flash again.
Diagnostic Codes
11. Transaxle Codes present
12. Diagnostic System Check
13. Oxygen sensor, circuit open or not ready
14. CTS circuit, out of range high
15. CTS circuit, out of range low
17. PCM fault, pullup resistor
19. 6x signal fault, no 6x signal between reference pulses
21. TPS circuit, out of range high
22. TPS circuit, out of range low
23. ATS circuit, out range low
24. VSS circuit, no signal
25. ATS circuit, out or range high
26. Quad Driver output fault
32. EGR system fault
33. MAP sensor circuit, out of range high
34. MAP sensor circuit, out of range low
35. IAC valve, rpm out of range
41A EST circuit open
41B EST circuit shorted
42A Bypass circuit grounded
42B Bypass circuit open
42C Bypass circuit shorted
41. EST bypass, open or shorted
42. EST bypass, open or shorted
43. ECS (knock sensor) circuit open or shorted
44. Oxygen sensor indicates system lean
45. Oxygen sensor indicates system rich
46. Power steering pressure switch circuit, open
49. Idle rpm out of limit high (vacuum leak)
51. PCM memory error
55. A/D converter error in PCM
81. ABS message fault (1993 vehicles with TCS)
82 PCM internal communication fault
Diagnostic Flags
27. Quick quad driver output fault (1993 only)
48. Reference imput intermittent or noisy
52. Battery voltage out of range
53. ESC knock present
54. Five volt reference ground
58. Battery voltage unstable
61. 6x signal fault
63. Option check sum error
67. Handwheel sensor circuit fault
71. Cooling system temperature high
72. Coolinng system temeprature low
73. CTS sensor unstable
74. CTS/transaxle temperatuer sensor ratio error
76. ATS sensor unstable
83. Low coolant (1993 only)
Feb 24, 2009 | 1993 Saturn SC1
Fuel 12/Fault 12 Error Message
check the mass airflow sensor circuit; thats what the owners manual says DTC code 12 pertains to, but to me it sounds like a fuel pump. i had the same problem, it would turn over, but not crank. make sure youre getting spark and everything else first because the fuel pump is located in the gas tank, and requires removing the entire tank to access it, which easily can turn into a 4-6 hour job.
Dec 05, 2008 | 1994 Jaguar XJ6
Doc 12 error code 9-343
i had similar problem a week ago running black only job on extra heavy card stock.
there is black toner built up. when you run black only copy with little toner use, it builds up toner in black developer and motor could not run.
always mix black and color jobs and run alternate, so there is no excesses in any color. or cheaper way how i did without paying color clicks.
i got rid of excess black in following manner.
took 11x17 white sheet, copied as negative (solid black) and ran 30-50 black copies, which drained all excess black and then continued with job.
hope it works for you or get professional help or you will lose motherboard and motor if you just follow instruction as it tells you on error screen... switch off and switch on. do not keep on repeating.
Oct 23, 2008 | Xerox DocuColor 12 Printer
Truck wont start
Is it getting fuel?
is it getting spark?
as for the is the code list for gm vehicles
Code: Meaning:
No Distributor pulses
Oxygen sensor
Coolant Temp sensor circuit
Throttle Position Sensor
Manifold Air temperature sensor
VSS (Vehicle Speed sensor)
EGR system
MAP sensor or MAF sensor depending on engine
Idle Air Control Valve
MAF Burn-off circuit
No Distributor pulses, cylinder select error
Electronic Spark Timing or Bypass fault
Electronic Spark Control fault
Lean exhaust
Rich exhaust
VATS system fault
PROM fault
CALPAK fault
System over-voltage
Fuel pump circuit
ECM fault
Oxygen sensor fault (degraded sensor)
Jul 17, 2008 | 1990 GMC Sierra
Xerox DC12 Error code 9-355
That is a magenta toner empty message, either the magenta is empty of there is an issue with the magenta toner dispencing.
May 07, 2008 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Printer Logo
368 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
