Question about Cycling
Need rear brake parts for dynacraft model 8562-81 mountain bike
  • 4 Answers
SOURCE: Schwinn S40 DSX part name
Forget new guide wheels. A new rear derailer is the real fix. You will need to order a new one by the number of gears on the rear gear cluster. How the derailer is mounted, Which way it moves when by the spring direction etc... By the way, get a higher quality one than the one you have got. If you go megawheel on the lower guide wheel; which I recommend, you might need a couple more segments in your chain. Yes, you need a new chain. If you wore out a part on you derailer, your chain is getting old. I recently bought a new rear derailure for my wife's bike for 29 bucks at a much better quality than the old one. It does not have problems of getting between gears, clicking etc... like the old one did new.
Posted on Jul 08, 2009
  • 1137 Answers
SOURCE: Dynacraft Slumber Party 20 inch girls bike
Make sure you follow the directions carefully. You might try leaving the flat washers out or substituting thinner ones. Worse case you will have to go to a bicycle shop and purchase a longer axle. Make sure you keep careful track of how you disassembled it and take pictures or make drawings. The hardest part with replacing an axle is getting the proper resistance on both sides so the bearings don't bind. Check www.sheldonbrown.com for some helpful articles.
Posted on Aug 03, 2009
  • 5 Answers
SOURCE: Mens Titan Pathfinder Mountain Bike
If the gears will no longer go back on the bike, I would recommend buying a new wheel (including a new rear hub). It is usually easier and more cost effective to buy a wheel than to replace the hub. To replace the hub (the part that is stripped on your bike) you would also have to remove and replace spokes, etc. Search online for the wheel size you need (probably 26" - you can check the tire size) or take to a reliable bicycle shop and they will gladly help you. Anyway, you need a new hub but probably better off getting a new wheel - much easier.
Posted on Aug 27, 2009
  • 670 Answers
SOURCE: Is there a way to download a users manual for my
Take this link to dynacraft and on "click here" to download free owners manual. Check for necessary pages, manual is 109 pages.
http://www.dynacraftbikes.com/owners_manual.php
Posted on Sep 05, 2009
  • 21 Answers
SOURCE: Men Mountain Bike (26"): How to adjust tention on the rear brakes...
Your bike likely has linear pull brakes so you will need to a. loosen the pinch bolt that holds the brake cable to the noodle (down at the wheel). You then pinch the brake in towards the rim with your hand until it's almost touching and then retighten the cable. You can then do some fine adjustment on how close the brake pads are the rim with the adjusting nuts up at the levers.
Posted on May 20, 2010
I have Next PX 6.0 Mountain Bike that has a missing connector bolt/nut that is located above paddle/crankshaft and connects front with back of this bike.I need to know the name and size of this part?
I don't know the name of the part, and it's going to be very difficult to ID the part over the Internet. That is a bike that sells for under $100, and therefore unusual OEM parts would be very hard to find. Take to a bike shop to see if they can suggest a fix.
NOTE: The bikes are distributed by Dynacraft, which has been the subject of suits and settlements due to serious fork and frame problems. Dynacraft BSC Inc
Dec 07, 2016 | Mountain Cycling
Need replacement gear shift cables
Only thing different between all cables for bike is the lead stopper at lever end. Tell bike shop cable is for gears and type, lever or twist grip,and type of bike(mountain/BMX etc)for length and you shouldnt have any probs,*ALT* take lever end of cable to varify lead piece is the same.
Your sheath on cable might be damaged-which caused cable to brake. Complete cable and sheath only cost about $3.
Spray a fair bit of WD40/RP7 or similar down sheath before inserting cable for smoother operation.
Jan 15, 2012 | Dynacraft Cycling
16 inch bicycle tire is flat. Need replacement, where to buy?
Call Dynacraft (bike maker) at 1-800-551-0032. My daughter's rear tire was flat and they sent out a new tube for free. She had the bike for only about 4 months. They also sent out a new rear tire as bearing/coaster brake assembly was make noises. The only problem is her original rim was purple and they sent out a silver colored rim as they don't have purple replacement part. I also had to install the tube and tire on the new rim. They only send replacement parts not assemblies.
Sep 16, 2010 | Dynacraft Girls 16" Barbie Bike
May 18, 2010 | Huffy Men Mountain Bike (26")
REAR HUB MAKE NOISE OPEND AND TENCHENER IS BLOWN HOW DO I GET A NEW ONE
I had a problem with the rear hub seizing up, clanking and screeching on
my Dynacraft Magna Imposter bicycle from the day I bought it at Target.
I called the company and they sent me a new rear wheel. It arrived by UPS
in 8 days and my bike has been fine ever since.
Great customer service from Dynacraft!
Jan 06, 2010 | Dynacraft Cycling
Bike Manual
http://www.huckjambikes.com/manuals/Dynacraft%20Manual%202008a.pdf
Dec 25, 2009 | Hawk Tony 's Huckjam Series Drop Mountain...
How do you adjust the hand brake? I can get them
The bolt that attaches the brake to the bike needs to be tightened/adjusted
Nov 23, 2009 | Dynacraft Girls 16" Barbie Bike
X-cross mountain biker-brakes
this is something you need to take up with your local bike shop
Apr 12, 2009 | Mountain Sram Pg 950 11-32 Cassette...
Cycling Logo
57 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
