Question about Brother SE-270D Computerized Sewing Machine
Carriage Is Jamming - Security Message on Screen
Hi- My machine will not embroider. It has been working fine, but now the carriage (that holds the bobbin) is "jamming" and sort of "popping up" causing the machine to give me the security feature message before even stitching. I noticed that the "spring" part (the silver part beside the carriage seems to be moving around too freely. It can come out of the machine only attached by wires. I am wondering if a screw to hold it in place has come out and it it knocking the carriage around? Never noticed it being so "free moving" before. Thanks for any help!
  • KaylaHope Oct 23, 2008
    I think I should have said "shuttle" instead of carriage :)...
  • KaylaHope Oct 27, 2008
    Thanks , but I don't think that is it. I've been embroidering for almost 4 years now, and I've never had this problem. The metal arm that has the spring on it is broken. If you have information on what that part is called or a diagram of the inside of my machine (Brother SE270D), I'd appreciate it. Thanks!
Well . What you can do is **** it.
Posted on Oct 27, 2008
    Problem Solver:
  • 5 Answers
Your problem is in the threading... too much slack in the thread causes bird nesting on the under side of fabric: re-thread with the pressure foot up... this will ensure thread is between tension disks, therefore eliminating slack, bird nesting and jamming. The security message is your machine stopping to keep you from creating functional problems with the machine. If you bought your machine from a dealer, call them and ask about classes.
  • lagresham Oct 27, 2008
    I would take your machine to an authorized dealer. Any good dealer should be able to fix the problem. If you go to brother's website www.brother-usa.com there should be a dealer locater . I would not try to fix the machine this could null your warranty.
I have a se400 brother machine and the lcd screen stuck on brightness also the carriage not moving . i am tuning on machine but nothing else works
Moving the carriage by hand will not hurt it. You may have the feed dogs up. Does it sew without the embroidery unit.
Nov 19, 2017 | Brother Sewing Machines
Embroidery unit
This can happen, click back to tools option check whether hoops selection is correct. If this is not the problem, off your machine then put on again. If message remain pull out the embroidery carriage & push in again. Hope it can work.
In jam situation, just exit from your embroidery option, fix the jam by moving the embroidery carriage, work on a different design and see if it work. Sometime a design may not work fully.
Sep 29, 2013 | Singer CE-100 Futura Computerized Sewing...
Elna 8600 - Carriage will not move backward or forward only left and right when I try to embroider
This could be a loose connection on the circuit board or it may be a bad board, either way it should go to a tech for repair.
May 04, 2010 | Elna Xplore 8600 Computerized Sewing...
My Janome 10000 stopped in middle of embroidering a design and the machine rebooted. it was making a bit of a whining sound as it was stitching just at the last..but now the hand wheel seems harder to...
Janmore10000 Stopped Embroidering thenstopped everything just shutting off.
If it is getting no power at all, it is probably a fuse. Thefuse is located in a little black box underneath the base of the machine, butit is NOT an easy job to take the box out, disassemble it, replace the fuse,and then reassemble the whole machine. But in your comment you mentioned that there is power tothe machine that means its not fuse problem.
It stopped embroidering in the middle of a project. the handwheel would notmove at all this means that it wasthread jam. Also check the carriage carriage if it does not move to the rightor left and gor stuck in one position or hardly moving a bit then it is out of calibration.
if your machine is outof calibration it will need to recaliberate . Something is like forcing theneedle through a thread jam would cause this. This is not an expensive repair.But a time consuming repair. Its advisable to get it done by service center,
click this linkdirectly to get the support center help
http://janome.com/index.cfm/ContactUs
This will help. Thanks please keep updated. please dorate the solution positively .thank you for using fixya.
Nov 29, 2009 | Janome Memory Craft 10000
Futura ce-200 "parked" in wrong position.
I think you might have damaged the embroidary arm.
Contact these people for some advice.
Gezina sewing machine
(012) 335 0636
Feb 27, 2009 | Singer CE-200 Quantum Futura Computerized...
Lower thread keeps jamming in bobbin compartment - urrgggg
Take the bobbin carriage out and clean it really good. Use the little brush that comes with your machine and brush everything. When m y machine jams up like that it usually means there is lint or thread caught in the bobbin carriage.
Jan 01, 2009 | Bernina Sewing Machines
Stepping motor error on embroidery machine
Hi again and welcome back to FixYa.
It is nice of you to remember. To your concern, possibilities are:
  • if the grinding noise is coming from the bobbin case area, then pls ensure that nothing is stuck/caught there, it would only take a small foreign object to trigger the problem; or
  • verify that the embroidery carriage in its parked/original position;
  • there would be a sensor/switch that tells the computer that the embroidery carriage is back. Pls check that if the carriage is back and see if you can check the sensor/switch;
  • worst case scenario is that the controller's circuit board is faulty. In some case, it could just be the wires or connection leading to the controller board.
Good luck and Thank you for using FixYa again. Happy Holidays.
Dec 07, 2008 | Sewing Machines
Embroidery arm
Turn off the machine, remove the carriage, check that nothing is hitting against the arm and try again.
Sewman7
May 18, 2008 | Brother SE-270D Computerized Sewing...
Janome mb4
Loud chirping noises indicate a need for lubrication or something is rubbing against your carriage.
sewman7
May 18, 2008 | Sewing Machines
Singer Quantum Futura CE-200 Problem
My machine did the same thing. I had several frustrated nights ans then it just started to work. Some suggestions that I had was that there may be dust where the units connect. Not sure what I did, but it worked.
Dec 27, 2007 | Singer CE-200 Quantum Futura Computerized...
Brother SE-270D Computerized Sewing Machine Logo
94 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
