Question about Retail Supplies
How do I change ink roller on a Sharp ER-2386S cash register?
  • 3 Answers
SOURCE: SHARP ER-A440
2. Master reset (All memory clear)
There are two possible methods to perform a master reset.
· MRS-1
Used to clear all memory contents and return machine back to its
initial settings and return keyboard back to default keyboard layout.
Procedure
1) Unplug the AC cord from the wall outlet.
2) Set the MODE switch to the (SRV¢) position.
3) Plug in the AC cord to the wall outlet.
4) While holding down JOURNAL FEED key, turn to (SRV) position
from (SRV¢) position.
· MRS-2
Used to clear all memory and keyboard contents.
This reset returns all programming back to defaults. The keyboard
must be entered by hand.
This reset is used if an application needs different keyboard layout
other than that supplied by a normal MRS-1.
Procedure
4) While holding down JOURNAL FEED key and RECEIPT FEED
key, turn to (SRV) position from (SRV¢) position.
5) Key position assignment:
After the execution of MRS-2, only the RECEIPT FEED and
JOURNAL FEED keys can remain effective on key assignment.
Any key can be assigned on any key position on the main keyboard
i found this on the manual at this site...
http://www.skan.com/Manuals/A440/ERA440-SRV.pdf
Posted on Jan 26, 2008
greg_margo
  • 1959 Answers
SOURCE: can't change the tax rate on a Sharp ER-2386 cash register
The amount that goes in the blank is the minimal amount that the tax can be applied. Put the number 1 in the blank to indicate all sales over $.01 will be taxed. Also, 8375 won't work. It's looking for a 5 digit number so if you're trying to indicate a 8 3/8% tax rate, it should be entered 83750. Post back if you have any questions.
Posted on Apr 13, 2009
ipodslinger
  • 688 Answers
SOURCE: My Cash Register Sharp ER-2386 show me just a 0
your mdl number doesn;t match anything sharp makes currently, but here is a link to sharps
manual downloads.
http://www.sharpusa.com/products/TypeDownloads/0,1087,201,00.html
apparently these cash registers have a software program for your pc that helps you program for your needs.
Posted on Jun 04, 2009
  • 22 Answers
SOURCE: how do I change the tax amount for Sharp XE-A101 cash register
9 => SBTL => Tax Number (1-4**) => @/TM => R => @/TM => Q => CA/AT/NS
"R": TAX RATE (0.0000% to 99.9999%) x10000
(Enter the rate in 6 digits. Leading Zeros may be ommited)
"Q": MINIMUM TAXABLE AMOUNT (0.01 to 99.99) x100
(Smallest amount for which tax must be collected)
**Up to 4 types of tax are programmable
Hope this helps!
Posted on Sep 10, 2009
flexion1
  • 737 Answers
SOURCE: sharp cash register (er-a470) won't turn on.
If the machine is dead, then you probably have a bad battery. It should be changed every 3 to 5 years by the dealer. If it has been left too long, then this is a common symptom and the machine loses all programming. Otherwise, you may have a faulty power supply or mode lock unit. It sounds like you need to see a dealer about it. ------------------------------------------------------------------------
If anyone is looking for a Sharp ER-A470 manual, see here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
Many more available at
Posted on Mar 28, 2010
Why is there a horrible grinding sound coming from the ink roller area?
#Tags how can i make my sharp xe a102 cash register work
159.203.8.28/.../how-can-i-make-my-sharp-xe-a102-cash-register-work
package of three sharp xe a107 cash register ink roller ... on in a few min. the car dies ยท Why is there grinding noise on driver's side as wheel is in motion? ... I have 05 honda pilot with a bad transmission what other type of transmission would fit ...
Oct 28, 2015 | Sharp ER-A320 Cash Register
Er-a320 nr100I need a ink roller for sharp
Hi. It's an Epson type printer and the ink roller code number is IR91. You can still get them from many office supply companies, or on the net.
Keep getting e for error when entering amounts er-2386s sharp cash register
- Repair and clean registry errors with Reginout.
- Update Drivers
- Defragmenter Startup Manager
Oct 28, 2013 | Computers & Internet
I have a Sharp Register ER 2782A Serial number 29000302 and I am looking for a Round ink pad and ribbon to replace the old one I have
Now that is an old machine. 1980 model. They were called endless ribbon and ink roller. I don't think you will find any Sharp dealer who can supply these now. If you want to keep using it, you will probably have to adapt one of the ink cartridges from the other models.If you need more information, C-tech still has all of the manuals for the ER-2782A here:http://the-checkout-tech.com/manuals/cashregisters/Sharp3.php
May 03, 2012 | Sharp XE-A402 Electronic Cash Register
How do you change the logo on a Sharp ER2386s cash register
You pull the stamp holder out of the back of the receipt side of the printer. Take it to a stamp maker and ask them to cut a new stamp with your details on it. They will normally supply you with special ink as well. Apply a few drops of ink to the stamp and re-fit to the printer. Done.----------------------------
If anyone needs a manual for a Sharp ER-2386s, C-tech has the user and programming manual here:http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-2386s_Instruction_manual.html
Mar 24, 2012 | Casio Parts Cash Register PC Desktop
Sharp cash register er 2386 Problem with screen
What do you see on the screen? Can you describe the problem a little more?
If anyone needs more information, the Sharp ER-2386s manual is here:http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-2386s_Instruction_manual.html
Oct 07, 2011 | Casio Parts Cash Register PC Desktop
My sharp cash register ER-A550S stop working
The letter H appears in the screen. The register will not respond. Any idea to what the Letter H means?
Apr 10, 2010 | Sharp XE-A402 Electronic Cash Register
Software for Sharp XE-A201 Cash Register
You need the PC Link software for your model.
All of these manuals can be downloaded at:
sharp ER-1017 Service
sharp ER-1072 Service
sharp ER-1073 Service
sharp ER-1074 Service
sharp ER-1075 Service
sharp ER-1076 User Service
sharp ER-1077 Service Programming
sharp ER-1077
sharp ER-1077
sharp ER-1772 Service
sharp ER-1772s Service
sharp ER-1871 Service
sharp ER-1872 Service
sharp ER-1873 User Service
sharp ER-1875 User Service
sharp ER-1910 User Service
sharp ER-1911 User Service Programming
sharp ER-1911s User Programming
sharp ER-1920 User Service
sharp ER-1921 User(R) Service Programming
sharp ER-1921s Programming
sharp ER-1970 User Service Programming
sharp ER-2000U Service
sharp ER-2100 User Service
sharp ER-2370 Service
sharp ER-2371 User(R) Service Programming(R)
sharp ER-2385 Service
sharp ER-2386 Service
sharp ER-2386s User
sharp ER-2395 Service
sharp ER-2396 Service
sharp ER-2720 Service
sharp ER-2722 Service
sharp ER-2722A User Service
sharp ER-2742 Service
sharp ER-2742A Service
sharp ER-2770 Service
sharp ER-2782 Service
sharp ER-2782A Service
sharp ER-2905 Service
sharp ER-2908 Service
sharp ER-2910 Service Programming
sharp ER-2970 User Service
sharp ER-2975 Service
sharp ER-2980 User Service
sharp ER-2980S Service
sharp ER-3100 User Service Programming
sharp ER-3110 User Service Programming
sharp ER-3115 Service Programming
sharp ER-3120 User Service Programming
sharp ER-3550 Service
sharp ER-3600 User Service
sharp ER-3630 User Service
sharp ER-3712 User Service
sharp ER-3721 Service
sharp ER-3731 Service
sharp ER-3732 User Service
sharp ER-4100 User Service Programming(R)
sharp ER-4110 User Service Programming(R)
sharp ER-4100S Service
sharp ER-4110S Service
sharp ER-4550 Service
sharp ER-4630 User Service
sharp ER-4633 Service
sharp ER-4700 User
sharp ER-6740 Service
sharp ER-8700 Not Available, do you want to swap?
sharp ER-A150 User Service Programming
sharp ER-A160 User Service Programming
sharp ER-A170 User(R) Service Programming
sharp ER-A180 User Service Programming
sharp ER-A220 User Service Programming
sharp ER-A227G Programming
sharp ER-A250 User Service Programming
sharp ER-A310 User Service Programming
sharp ER-A320 User Programming
sharp ER-A330 User Service Programming
sharp ER-A410 User Service Programming
sharp ER-A420 User Service Programming
sharp ER-A430 User Service Programming
sharp ER-A440 User Service Programming
sharp ER-A440S Programming
sharp ER-A450 User Programming
sharp ER-A450S User Service Programming
sharp ER-A450T User Service Programming
sharp ER-A460 User Service Programming
sharp ER-A470 User Service Programming
sharp ER-A490 User(R) Service Programming
sharp ER-A510 User Service Programming
sharp ER-A510s Service
sharp ER-A520 User Service Programming
sharp ER-A530 User Service Programming
sharp ER-A550 User Service Programming
sharp ER-A550s User(R) Service
sharp ER-A570 User Service Programming
sharp ER-A610 User Service Programming
sharp ER-A650 User Service Programming
sharp ER-A650S Programming
sharp ER-A670 Not Available, do you want to swap?
sharp ER-A670S Programming
sharp ER-A750 User Service Programming
sharp ER-A770 User Service Programming
sharp ER-A770II User
sharp ER-A770M User Service
sharp ER-A771 User Service Programming
sharp ER-A850 User
sharp ER-A880 Not Available, do you want to swap?
sharp UP-3300 User Service Programming
sharp UP-3300M Service
sharp UP-3301 User Service Programming
sharp UP-600 User Service Programming
sharp UP-700 User Service Programming
sharp UP-800F User
sharp UP-810F User
sharp UP-820N User Service
sharp UP-X300 User
sharp UP-X500 User Service
sharp XE-A101 User Service Programming
sharp XE-A102 User Programming
sharp XE-A106 User
sharp XE-A110 User Service Programming
sharp XE-A120 User Service Programming
sharp XE-A130 User Service Programming
sharp XE-A201 User Service Programming
sharp XE-A202 User Service Programming
sharp XE-A203 User Programming
sharp XE-A206 User
sharp XE-A20S User Programming
sharp XE-A212 User Service Programming
sharp XE-A213 User Programming
sharp XE-A301 User Service Programming
sharp XE-A302 User Programming
sharp XE-A303 ? Programming
sharp XE-A401 User Programming
sharp XE-A402 User
sharp XE-A406 User
sharp XE-A40S User Programming
sharp XE-A505 User Programming
Dec 30, 2009 | Sharp XE-A402 Electronic Cash Register
Retail Supplies Logo
63 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
