Question about Frigidaire Ovens
Were does the foil go on oven door glass replacement
The replacement glass comes with three strip's of foil that goes on the door before the glass is put on . Were does the foil strip's go?
  • 1314 Answers
SOURCE: tin foil stuck to bottom of oven
if not a lot of foil get that easy off thats made for self cleaning ovens soak it let it sit then wipe make sure you get the one that says safe for silf cleaning dont scrape soak then after wipping off run self clean
Posted on Dec 29, 2007
reg501
  • 413 Answers
SOURCE: Foil baked onto oven base.
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. Oven operation is not affected. The only option you have is to replace the panel or the entire oven liner...
Posted on Jun 07, 2008
  • 82 Answers
SOURCE: melted foil in oven
Hello. Unfortunately the only way I have fixed this is to change the entire oven cavity. This was on a Wolf oven. I have never seen a glass bottom oven but maybe you can replace just the bottom.
Posted on Dec 04, 2008
barkencoa
  • 3463 Answers
SOURCE: top oven door glass has smashed
Usually, u open the door as far as possible and at the lower end of the hinges you shoud find what look like 2 small catches, pull these up and latch them on to a hook or something similar on the main part of the hinges, this compresses the springs, and then lft up the door and pull towards u, this should release the door, and then change the glass, then offer the hinges into the slots, and pull the door back down, then release the catches.
Plz rate my solution.
Thanks.
Posted on Jan 01, 2009
  • 18 Answers
SOURCE: the inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Posted on Feb 18, 2010
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Tip
Range/Stove/ Oven Door Glass Replacement
I see many questions come up at Fixya.com about oven door glass that has broken and how to replace the glass. For many ovens it is a relatively simple task. It will take about an hour for most people, depending on the skill level, and the type of door.
To do this job you should have handy a screwdriver, usually a Philips head medium sized, a plastic tarp, especially if your glass in the door is already broken, and of course the new glass. It is also a good idea to measure the new piece of glass to make sure that it is close in size before taking the door apart.
For your safety, make sure that the power is turned off to the oven before starting this job also. The open the oven door and remove the screws on the inside face of the door. If the door can be remove easily you can remove it, but it is not necessary to do that. Make sure that you place the pieces of the door as they come off and the screws in a place to keep them organized for when you put everything back together.
For most ovens you will find the oven glass held in by tabs, similar to a picture frame. Pull the tabs back to release the glass. Carefully remove the old glass from the frame. If it is broken, be very careful not to cut yourself. Also contain the glass on the trap to make cleanup easier. For many newer ovens, you will have three layers of glass. Do the same process for each layer.
When the old glass is removed, then simply replace each layer of glass and press the tabs back in place for each one. Then replace the brackets or inside pieces of the door, and secure with the screws.
This is how easy it is to replace the glass for many of the ovens.
Another word about broken glass in ovens…..
Many of the people that have broken glass state that it broke after running the self-clean feature of their oven. For many of you this warning will be too late…but for those of you that see this before, be warned!
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Mar 22, 2010 | Ovens
How do i remove and replace the internal glass of the oven door for cleaning?
Most ovens have screws around the oven door. Remove them and the front will come offa. Be careful you don't bend any ears or catches.
After the front is off you will see a keeper that holds the glass in place. Re that and take the glass out.
Make sure you watch the way it comes apart.
Nov 17, 2011 | Ovens
The inner glass door on my zanussi oven has come
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Jan 17, 2009 | Smeg DO81CSS Electric Double Oven
How do I remove the glass on the inside of the oven door to clean between the two pieces of glass
We just replaced the inner glass last night. The door needs to be removed, then take the screws out that holds the inside panel on. I suggest writing notes of the steps that you take when you remove the panel and glass. Our model had three pieces of glass. Be careful replacing the door, we knocked the lock loose which in turn knocked the sensor for the light to come on. We had to take that part of the oven apart also to fix it. Hope this helps. I may not have done this if it wasn't for the broken glass.
Dec 30, 2008 | Whirlpool RBS305PDS Electric Single Oven
Melted foil in oven
try this take them out if the oven they just unplug in the back soak them in a de greaser with lemon juice really hot water let me know if this works
Dec 04, 2008 | Dacor MCS130 Millennia Electric Single...
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
63 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
