How do I remove the hard drive from a Sony PCV-E21L computer?
charcois
  • 763 Answers
SOURCE: Games run slow on Sony VOIA PCV-RX571
may i know *********** board is? try my advice here
http://www.fixya.com/support/r951432-befor_buying_new_video_card_must_read
cheers
CHARCOIS
Posted on Sep 01, 2008
20YrsCompExp
  • 227 Answers
SOURCE: Computer did not bootup after adding 2nd harddrive
Did you connect the drive to cable spot closest to the motherboard on the primary IDE channel? is it formatted? Did you try the drive on the Second IDE channel? Can your system support a 160 GIG drive?(if not try partitioning the drive.). Is the power and data cable connected properly?(the red line on the data cable should be closest to the power plug on the drive.)
Posted on Apr 11, 2009
sidlas
  • 95 Answers
SOURCE: I have a sony vaio pcv-rx470ds and when i try to
must configure jumpers on second hard drive as slave
Posted on Jun 13, 2009
  • 130 Answers
SOURCE: Installing 500 GB EIDE HD in a SONY PCV-RX560
what are the jumper setting on the hard drive. make sure the old one is the master and the new one the slave.
  • 20 Answers
SOURCE: Sony VAIO PCV-RX500 Cant get recovery cds to work
since she formatted the hard drive there is no drivers for your cd rom to work
1(888)476-6972
san diago rrc
16550 via esterillo
building 5
door two
san diego california 92127
Posted on Aug 21, 2009
Need 2nd hard drive for sony pcv-rz24g
You need a ATA-100 (EIDE) 3.5" hard drive. Then you need the jumper set to slave or cable select (if you have the two drives on one cable and the original drive as the master). See your manual for details on the procedure. You need to open the case, remove the cables from the original drive and lift the drive holder out of the case to insert the second drive. The manual is available here: http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVRZ24G (see page 44 (57 as the pdf reads) and on) . Then slide the case into place and connect the power and data cables to both drives. Then go to the drive management to format the new drive and prepare it for use.
For XP, go to My Computer, then Manage. Then Select Storage and Disk Management. Then select the new disc for formating.
I hope this helps.
Jan 30, 2011 | Sony VAIO Digital Studio PCV-RZ24G PC...
I need to go to a much larger & faster hard drive
Sony recommends to use the preinstalled Hard Drive as the Recovery Discs works with the specific Hard Drive. However, you can add additional Hard Drive to the Computer.
Please check the link below for more information.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C127565
Your computer is shipped with 80GB Ultra ATA/100 Hard Drive. you can use Hard Drive of size 80 to 500 GB for best functionality.
Jun 25, 2010 | Sony VAIO Digital Studio PCV-RX860 PC...
Replacing a hard drive on Sony PCV-RX550 with a Western Digital 320 gig. With the orig disc as primary master, the wd drive is recognized by the bios as secondary master. But when I remove the original...
if you want to connect two hard drive together then remove the jumper of the primary hard drive and don't touch the setting of the secondary drive then start the system.always make primary drive which have the os.
Jan 26, 2010 | Sony VAIO Digital Studio PCV-RX550 PC...
Jun 13, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
How to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
May 06, 2009 | Sony VAIO VGC-V617G PC Desktop
How can I remove the side cover on a Sony Vaio PCV RX470DS?
http://www.retrevo.com/support/Sony-PCV-RX470DS-Desktops-manual/id/751bh234/t/2/ u can find the manual here
Dec 25, 2008 | Sony VAIO Digital Studio PCV-RX550 PC...
1(888)476-6972
san diago rrc
16550 via esterillo
building 5
door two
Nov 05, 2008 | Sony VAIO PCV-RX500 PC Desktop
PCV-W20 Partition sizes
Have yout tried to recover without any partition defined? Try to execute with your hard drive clean.
Dec 17, 2007 | Sony VAIO PCV-W20 PC Desktop
Sony PCV-RS720G - DVD-Rom gone bad
Here is a link to instructions that detail how to replace a hard drive but it shows you how to open the case: javascript:moreinfowindow('http://www.iq.sony.com/srvs/DocsConnect/docget.asp?manualid=90411&DL=',600,560,10,10,'Manuals')
Jul 26, 2007 | Sony VAIO PCV-RS720G (027242658103) PC...
Computers & Internet Logo
269 people viewed this question
David Payne
David Payne
