Question about GE 46GW 948 46" Rear Projection Television
Menu going crazy on the screen!
The menu on my GE 46GW948 46" TV will not stop popping up on the screen. When it does pop up none of the control buttons on the bottom of the tv will control it. When the channel buttons, volumn buttons & the on and off buttons do work they seem to be one button off. I press the volumn up button to turn the darn thing off. After a few minutes, it works fine again but doesn't last very long. I've unplugged the set overnight hoping to reset it but nothing has helped. The menu just keeps popping up!
  • Anonymous Mar 29, 2014
    Turn tv on and it just keeps scrolling through the channels downwards, managed to get into the menu, (which it kept at bottom of list) and did an retune of it, nothing, turned it off for a bit still going. Any ideas at all??
    New Friend:
  • 163 Answers
It sound as the menu button is staked, is a easy job for a tech, but dificult one for regular people, better get a tech and let him know that you know the problem is the menu button, thas gonna help with the price off the repair...good luck
Posted on Aug 07, 2006
A black box randomly pops up on my tv screen constantly...
It part of the caption functions is on.Tries find in ur tv menu,goto captioning functions like CC1,2,3 and Text 1,2,3.Turn it all off.These radom black boxes and trying typing somethings,should stop.
Jul 20, 2010 | Olevia 237T 37 in. LCD TV
Menu pops up repeatedly and will not go away for more than 3 minutes. Controls on front of tv not functioning properly pressing channel up/down not only changes the selection but also immediately selects...
Had same issue, I was fed up and as a last resort i took the TV apart and simply un-soldered the menu button from the control board. I put the tv back together and its been working ever since. Like i said, its a quick fix and a last resort, but if its worth it to you to hold off from buying a new tv, this may just do the trick. Be aware that it may make the display text on your screen illegible and I did have one other problem about a month later when the tv input changed and the tv remote stopped functioning properly. i was not able to switch the tv back to my cable box input but a 6 dollar universal remote from walmart solved that.
hope this helps
May 15, 2010 | RCA MM36100 36" TV
Menus pops up
The menu button on the TV itself is bad and must be replaced ( or removed ). Alternatively the whole front button assembly can be disconnected. Just follow the wire back to the main chassis and unplug it.
Apr 09, 2009 | RCA P61927 61" Rear Projection Television
RCA HDTV MENU AND VOLUME CONTROL POPS ON AND OFF SCREEN.
My TV was doing the same thing. Someone told me to disconnect the front menu buttons and this worked for me. The board goes haywire. You have to take off the front black panel on the bottom first then the grey front panel where the controls are. Once you do this you will see where there is a plug from tv to the panel where the control buttons are. Just disconnect. You will only be able to use your remote for TV. Its a cheap and easy fix. Just lots of screws to get the panels off and on. Good luck!
Apr 09, 2009 | RCA HD52W58 52" TV
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Reseting lamp counter (LG)
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) Come back to this blog and post your HOURS on our site
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 30, 2008 | Televison & Video
Need to reset lamp life indicator on lg rear projection tv model no 525sz812-tb
9) To Check if it was a success
Jun 21, 2008 | LG Televison & Video
Can't get the Guide Plus screen to go away
Try these options
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
May 16, 2008 | RCA F27649 27" TV
Samsung remote control issues
It is defective, call Samsung.
Dec 24, 2007 | Samsung TV Remote Control
Open Questions:
See all GE 46GW 948 46" Rear Projection Television Questions
GE 46GW 948 46" Rear Projection Television Logo
225 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
