Question about Umax AlphaVista Flatbed Scanner
Ups is not starting in 5 to 6 trial
My ups is not starting even after 5 to 6 trial. in first trial its green and red light spark for a micro second and it not start. it heppens in all the trial. what i do?
  • 1 more comment
  • kanpur Nov 01, 2008
    sir i want to know where is the service center at kanpur and allahabad?
    where is the service centre so UMAX ups in allahabad and kanpur
    where is the service centre so UMAX ups in allahabad and kanpur.
  • 47 Answers
Well happy to help. i think its the problem with ur ups's battery.coz it might have been drained out or one of the cells in the battery has u can take it to a service centre and get the batter replaced.pleasure helping u.
Posted on Oct 24, 2008
What would be the cause of my Paslode fan not working batteries are good
First, check to make sure you have a flashing green light in the handle - if not start with the battery contacts / circuit board (Part #22 on the exploded diagram)
If you have a green light, I would look at the head switch -
1) remove the 4 bolts from the head
2) remove the 2 screws in the nose holding the cylinder to the handle assy
3) carefully remove cylinder by pulling nose out and down taking care not to bend your fan blades
4) On the handle assy you will find a metal tab with a small roller on it (Part #27 on the exploded diagram) - this is the actuator for the head switch, make sure it is not bent and that it actually works the switch inside.
5) If the actuator is OK, I would lean toward the head switch which is part of the circuit assy (part #22 on the exploded diagram) (It is possible you have a bad fan motor, but it is much more likely you would have a bad switch)
Let me know if you need further help
Jun 22, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Why would a red light be flashing instead of powering on?
The power supply keeps trying to start but can't.
Jun 22, 2014 | RCA Televison & Video
Looking for sequence of operation for a lennox mid efficient furnace
When there is a Call for heat, the control delays ignition until combustion air
Blower operation has been proved and pre-purge period
Has elapsed. It then opens the gas valve and generates a
Spark to ignite the burners. Trial for ignition lasts for 7 seconds.
At the same time, the control begins monitoring the
Flame sensor. If the flame current is too weak (less than 1
Micro amp) or if the burners do not ignite (within the 7 second
Ignition trial), the control will shut off spark and the combustion
Air blower and de-energize the gas valve. Flame
Current should be between 1 and 5 micro amps to keep the
Gas valve open.
The control will attempt to ignite the burners up to two more
Times. Each time the control restarts the ignition sequence,
It begins with a 45 second pre-purge. If flame is not sensed
After the third trial, the control locks out. Lockout means that
The control shuts off the gas valve, spark and combustion air
Blower for 60 minutes. At the end of 60 minutes the control
Completely resets and will attempt ignition up to three times.
The control can be manually reset before the end of 60 minutes
By momentarily turning off power to the unit.
here is a link to an operations manual
Nov 25, 2010 | Heating & Cooling
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
My nokia BH-215 is not pairing. The green light blinking continuously.
hello, clear setting or reset, to delete the pairing from the headset , press and hold the power key and the answer/end key (for about 5 seconds) until the red and green indicator lights start to alternate. to reset the headset if it stops functioning , even though it is charged connect the headset to charger while you press and hold the answer/end key , Ensure that your phone is on and the headset is and hold the power key (for about 5 seconds until the green indicator lights start flash quickly. activate the bluetooth feature on thr phone, and set to search for bluetooth devices. select the headset from the list of found devices . enter the passcode 0000 to pair the phone. hope it works
Oct 10, 2010 | Nokia Consumer Headset
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
there are fans inside tv need to make sure they are clean and free of dust
Nov 27, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Umax AlphaVista Flatbed Scanner Logo
66 people viewed this question
Top Umax Office Equipment & Supplies Experts
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
