Question about Minolta Office Equipment & Supplies
Minolta's DiALTA Color Series CF3102/2002 Service code 1220
  • Minolta Master
  • 6,168 Answers
Image control board not talking to a main control board, this mite take a while and mite quite costly if you can even fine the board if required to be replaced. First to reset open close front door, if the code comes back, you will have to begin by unplugging machine and removing each connector on each big printed circuit board check each connector on the boars for a bend pin the reseat each connector, next replace boards try site below, could try firm ware update via Konica Minolta Dealer ship they might have access to the secure server for firmware,
Used PCB Circuit Boards for Copiers PCB Assembly Circuit Board Repair
Posted on Dec 26, 2015
SOURCE: MINOLTA CF3102 PRINTER
This code is related to fusing pressure, which could mean fusing unit malfunction.
Put paper clip through a hole under LED cleaning pads inside the front door to reset.
Caution!!! Not recommend for the end user to reset fusing related codes since it could result in a fire.
Posted on Mar 09, 2008
  • 300 Answers
SOURCE: Hello, Our Minolta Dialta Colour Copier/Printer
C0208: PC Drum Charge Corona malfunction. The SCD signal is detected for a continuous 0.7-sec. period while the PC Drum Charge Corona is being energized.
Relevant Electrical Parts - Image Units C/M/Y/Bk, High Voltage Unit (PC Drum CH.) HV1 IO Board (PWB-IO)
Steps (in this order) - Check the Image unit contacts and correct
or clean as necessary.
Check the HV1 contacts and
correct or clean as necessary
Change Image Unit.
Change HV1.
Change PWB-IO
Posted on Aug 13, 2008
  • 87 Answers
SOURCE: minolta dialta trouble code c0650
C0650 .THIS CODE IS FOR SCAN MOTOR OR SCAN SENSOR PRBLEM.JUST CLEAN SENSOR OR CHECK SCAN MOTOR IN OPTICAL UNIT.MAY BE MOTOR HAS PROBLEM.BY MIAN JEE
Posted on Dec 18, 2008
  • 1602 Answers
SOURCE: Minolta DiAlta Di450 Error Code C-0072
I NEED THE ERROR NUMBER OR HOW MANY TIMES DOES THE BLINK WHEN YOU TURN ON THE COPIER.
MORE INFORMATION PLEASE ROD
Posted on Feb 13, 2009
SOURCE: c1300 error code
could u please tell me the codes of the errors of minolta dialta di 250 and how can i use them
Posted on Jun 28, 2009
How to remove coda c200
The charge corona wires and or the housing need to be replaced. the housing holds the wires which a very thin a carry a H V when operating during the copy/print cycle. Located above the drum the charge the drum. if not either of those you mite need to replace the H V board. Sir/Mam you are dealing with a legacy Minolta printer/copier. First Generation Color. You will have do some serious google.
Mite try this site as a start for parts and this site for service manual Currently Konica Minolta no longer holds the service manuals for this series of machines
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Service manuals electronic components datasheets and equipment schematics...
Apr 23, 2014 | Konica Minolta DiALTA CF910 Copier
Minolta dialta Di 351f error c0300
no such code in the Di351F service manual
Feb 05, 2014 | Konica Minolta DiALTA Di200 Copier
Minolta dialta di183 copier error code c06 50
C 0650 - Faulty scanner home position sensor.
Remove the glass and clean the home sensor.If the scanner moves smoothly remove foreign matter and other obstacles,clean the scanner rails,clean or change the scanner bushing.Place WD 40 oil on scanner bushings.
Dec 02, 2013 | Minolta DiALTA Di183 Copier
How do i change the code from 0 to 1 in code error ff c03 in minolta dialta 183
Looks like you have a problem that require machine in adjust mode that enter service mode them press stop start
Oct 29, 2013 | Minolta DiALTA Di183 Copier
C3710 error code for Minolta color copier Di200f/di251f/di351f ?
First Sir/Mam, Please let me explain the Di 200f series is not a color copier! What is the model the code C-3710 is not associated with the Di200f series.
Aug 29, 2013 | Konica Minolta Minolta Dialta Di200f...
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
Minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Nov 11, 2008 | Konica Minolta DiALTA Di200 Copier
154 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
