Question about Gigabyte GA-945GCMX-S2 Motherboard
Drivers conroe kentsfield fsb 1066 - Gigabyte GA-945GCMX-S2 Motherboard
2 Suggested Answers
md_ehsan_1
  • 255 Answers
SOURCE: i need gigabyte fsb 1066 motherboard drivers
download from this link
http://www.lostmydrivers.com/bios-and-system-update-drivers/gigabyte/gigabyte-ga-945gcmx-s2-bios-f1.html
Posted on Jun 30, 2009
I NEED ALL DRIVE FOR MY MOTHERBOARD conroe 865gv fsb 800
Download here:
http://www.msi.com/product/mb/K8MM-V.html#/?div=Driver&os=XP%2032
http://www.asrock.com/mb/Intel/ConRoe865GV/?cat=Download&os=XP
You just have to try it because of lack of information.
Good luck
Aug 05, 2012 | MSI K8MM-V Motherboard
I'm planning to upgrade my desktop and i want to start upgrading from cpu. My current motherboard is Asus P5S-MX SE and cpu is Intel Pentium Dual Core Processor E2160, 1.8Ghz. Can you give me a list of...
Oh boy, you're in the same boat i'm in with my dad's HP asus based OEM board. You're max choice in a regular core 2 duo is the E6700 @ 2.66ghz with a 1066 FSB (Front side bus). Reason being is likely identical to my situation. The board likely only supports a "conroe" core. It can't handle the "WOLFDALE", otherwise they would list higher ghz for an E6700. The E6700 is also available as a 3.2ghz with 1066mhz FSB, but its based on 45nm process, which requires different power regulation from the board. if you were to put in the wrong chip, you get nada. Not even POST errors from what i've read where others have tried and failed.
Unfortunately, E6700 @ 2.66ghz are a little rare, but they are on ebay for about 80-100 bucks, and various other places. Search for "E6700", but be careful to avoid the 3.2ghz's.
The only other choice for max is the Core 2 Extreme X6800 @ 2.93 ghz. This processor looks like its about double the cost to the E6700 though. That's a lot of extra money to get only .27 gain in ghz though, IMO, though there could be other reasons to go extreme, like availability. There might be more of them! The same logic applies here. Stay with the 65nm process, and 1066 FSB.
Here is the tech spec page for your board. Its shows all the supported processors: http://usa.asus.com/product.aspx?P_ID=fLSzpcTDJYT0rgS6&content=specifications
You might want to choose carefully on whether to upgrade this board's CPU. Might be time to scrap the whole board and get something with more FSB capabilities.
Dec 29, 2010 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Power switch Wire has dissconected from the motherboard
There will be a series of pin headers on the edge of the board. They are almost always labelled PWR but if you haven't disconnected all the others (HD indicator, speaker, etc) it should be obvious where it fits.
Oct 03, 2009 | Computers & Internet
I am tryin to upgrade my processor on my 4000783 gateway motherboard need to change my fsb speed and dont know how
You cannot change your fsb. You need to upgrade to a cpu with a fsb speed that your board can support. Once you install the new cpu your bios will set the fsb to the higher setting of your new cpu if your board supports it. If you have your board specs it will tell you something like supports fsb 1066/800. That would mean you could upgrade to a supported 1066 fsb cpu. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | Computers & Internet
1333 FSB processor ( E6850 ) on a 1066 FSB motherboard, DDR2 667 memory
Hi proenza. you're making good sence! You're D945GCL MB should be able to run 1066 FSB. Not 100% sure you're memory will keep FSB up to 1066.
Here's the trouble though. The Intel Core 2 Duo E6850 will not run on the Intel D945GCL motherboard because it is not supported. Look here at Intel's web site. Supported CPU's.
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=d945gcl
Intel E6850 specs sheet. http://www.dealtime.com/xPF-Intel-Intel-Core-2-Duo-E6850-Processor-3-0GHz-4MB-Cache-1333MHz-FSB-Conroe-Dual-Core-OEM-Socket-77
Intel E6700 spec sheet. http://www.dealtime.com/xPF-Intel-Core-2-Duo-E6700-2-67Ghz
This CPU is supported by the D945GCL MB.
Intel Core 2 Duo E4700 Processor BX80557E4700 - 2.60GHz.
$149.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3826343&CatId=2396
In order to get 1066MHz (CPU can run at), you'll also need the memory support at 800MHz. The D945GCL MB can only run DDR2-667MHz.
Many people buy a CPU to run MB's specs (1333MHz) just to find the same MB does not support DDR2-1066MHz or DDR2-800MHz. Motherboard Mfg's are lagging. DDR3-1333MHz is out there now to support the 1333 MHz CPU FSB.
http://www.lagoom.com/KINGSTON_1G_DDR3_1333MHZ_PC3-10667/KVR1333D3N9_1G/partinfo-id-580235.html
I hope this has helped you make a decision proenza.
Good Luck!
Mike
Jul 17, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Gigabyte GA-945GCMX-S2 Motherboard Logo
895 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
