Question about Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor
Vertical colored lines
When i turn on the monitor, it is covered in vertcal lines. It still loads to the opening screen but the lines are covering the entire screen and are yellow. I can barely see anything on the screen. This just happened after having the monitor work fine for 4 years. Any ideas?
  • kina Dec 19, 2007
    Same problem with vertical lines after working fine for 5 years. Problem sometimes clears after a long warm-up but usually doesn't. Ran all the checks I could find (monitor trouble shooting guide by Microsoft found on-line) but nothing helps. Also see horizontal lines around cursor.
I had the same problem with my monitor, saw only coloured vertical lines. I opened it, opened the back of the metal casing to get access to the circuits. There I found a loose connector. I reset it and it worked again!
Posted on Jan 23, 2008
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Why does my monitor have colored vertical lines?
Hi Shannon,
I don't have good news for you. Coloured vertical lines is a symptom of terminal failure of LCD screens. Most common in laptops, monitors, and TVs. Problem only gets worse with time with more lines appearing, then expanding to cover a whole side of the screen. 30 - 50% normally.
Jul 19, 2012 | Dell Inspiron 2200 Notebook
No picture just vertcal colored lines and sound
What is the exact model number to your Poloroid TV?
Jul 12, 2012 | Televison & Video
HOW DO i REMOVE 13 COLOURED VERTICAL LINES ON MY LAPTOP SCREEN
Your monitor has probibly suffered a power surge at some stage those vertical lines are (kind of) dead pixles.
What it actualy is is the controler chip in teh monitor is slightly cooked sending the wrong voltage to that row of pixles, hence you get teh wrong colors displayed and they can vary in strength depending on what your looking at at the time.
I am sorry to say that the only solution is a new screen most warrantys dont cover that type of problem, and you can only guess what i think about that attitude some companys take.
Aug 19, 2009 | Computers & Internet
Vertical lines
The monitor sounds like its going to die. The problem is because of the LCD Panel.
A monitor should have 2-3 boards, a logic board, an inverter, and a power supply
Lastly the LCD Panel which should consist of a crystal mirror, LCD Panel(has the circuitry and the brains for information/images that display), and backlights.
The LCD Panel is the problem. It needs to be replaced.
Yes it sucks, but usually LCD monitors last for so long, but in some cases they wear out by use and the thin circuitry that provides the power to create colors and images, begin to die. Im sorry. Its really the only solution unless you have the expensive equipment used to make the panels.
My recommendation is to replace it and it should work spankingly new.
I wish yuo luck. Please Rate.
Sep 18, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Vertical Lines On Display
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image shows correctly you have either a problem in the LCD screen or its connection cable.
Open the cover and check for loose or damaged cables, specially next to the hinges. The next thing to check is a new LCD screen. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
Jul 02, 2008 | Toshiba Satellite A45-S250 Notebook
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Mar 24, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor Logo
383 people viewed this question
Clive
Clive
Alun Cox
