Question about Numark ttUSB Turntable
Burning a CD
How do I join 2 sides of LP to burn as a CD?
    Genius:
  • 1,605 Answers
What are you using to copy the song????
are you copying the song from LP to PC and then to CD????
if so, copy all of the songs from the LP then move or copy all of the songs to the CD.
I don't know any other way to this.
Posted on Oct 23, 2008
  • 2,794 Answers
The best way to do it would be to record or rip the record into a media player program.  Create a playlist using the songs then burn the songs to cd.
Burning Hot and Burning propane tank empty in 2 to 3 uses
What does "and parts to burners" mean? it sounds like you have NG orifices on a LP appliance or the LP orifices are not properly drilled. I use my barbecue several times a week and exchange an LP cylinder about every 6 months. If you are using the grill twice and the cylinder is empty that is not a lot of burning, that is a leak.
to adjust the burner the first and most obvious place to look is to check the pressure on the regulator (LP is 11") and the orifices. Next are there adjustment screws inside the valve stems? if so light the barbecue so the flames are visible and insert a long flat-head screwdriver to adjust the set screw inside the valve stem. turn the valve to "low" and adjust it until the flames are just barely staying on. Leave the set screw in that position and turn the valve on high, close the lid. if you're over 400 degrees in 10 minutes you'll be fine. if not adjust the set screw up a quarter turn at a time.
Feb 24, 2014 | Barbeques Galore Grilling
My compaq dvd rom gd 5000 can play an cd but cannot play dvd player.what should i do?
try running the fix-tool provided by Microsoft on this web page
http://support.microsoft.com/gp/cd_dvd_drive_problems
If that fails then my suspicion is that either
1) the drive has failed
or more likely
2) because you don't have any DVD burning software, windows can't understand the blank DVD-RW disk. This basic packet-burning software installed with XP CANNOT write to DVD disks.
However there is a bit more to it than that - the Microsoft CD burning software (which is a cut down Roxio product) cannot co-exist with any other packet burning software (e.g. DLA, In-CD or simuilar) so if one of those is installed you have to DISABLE the MS CD burning capability on the drive settings tab. Even worse, Internet Explorer 8 is not compatible with DLA - which is included in quite a few CD/DVD suites including many of the later Roxio versions
My advice would be
1) un-install any CD or DVD burning software on the machine
2) disable the MS CD burning
3) run that Microsoft patch
4) Install some DVD burning software but DON'T install the packet writing software part of it
Note that after installing that patch you may also have to reinstall any DVD playing software
Dec 09, 2010 | Computers & Internet
Ca't read any cd, dvd anymore
or more likely
My advice would be
Nov 21, 2010 | LG (GDR8164B) Internal DVD Drive
Whenever I try to burn a cd in my DVD ram a message shows up saying it is not accessible, Incorrect function.? What do I do? ive tried to disable and enable the drive then reboot the sys., still the same...
or more likely
2) because you don't have any DVD burning software, windows can't understand the blank DVD-RW disk. Thas basic packet-burning software installed with XP CANNOT write to DVD disks.
My advice would be
Nov 07, 2010 | Computers & Internet
I have an acer aspire 6920, im having issues burning cd's. I have used 3 different programmes and have used 2 different brand of CD-R. My Drive is FWZMD H2NCTMV SCSI CdRom Device, but when in the burning...
Each CD burning program assigns the burning device by the Windows name.
Your system comes with a DVD-Super Multi double-layer drive.
So the CD burning software will burn CDs to the DVD drive.
Nov 19, 2009 | Acer Aspire 6920-6621 Notebook
How can i burn an audio disc that will play on a cd player and not just my pc?
Modern CD players usually can read all audio disk burned on any computer system.
If you have an older model however you may experience some problem with certain settings, follow instructions below:
1 Ensure that you burn on CD support, and not a DVD, many computer drive can manage the same way CD and DVD, and burn music on DVD, but the player won't read them.
2 Ensure that you are burning an Audio CD on the cd burning, if you will just burn your MP3 files onto a disk, an ordinary CD player won't read them, unless it has MP3 capabilities.
3 If you have an old system try burning at the minimum possible speed , systems built in 80s and early 90s where limited to low speed, some 80s CD drive could read only 2x or 4x.
4 If your system is old also chose close disk after burning option on burning software, this wont affect new cd players.
You also need a software to burn CD, if you do not have burning software , see choice on websites below:
The Best, Free Alternatives to Nero CD/DVD Burner
15 Free CD/DVD burning alternatives to Nero
6 Free Alternatives To Nero | Into Windows
Mar 05, 2009 | Audio Players & Recorders
Burning my finished project to dvd
Ive found it locks up on certain video clips. Removing the clips solves the problem - not ideal!
Sep 17, 2007 | CyberLink PowerProducer 2 for PC
Burning Smell
your projector must be inspected by qualified service technician to fix the real problem because electrical arcing maybe differnt things.
Aug 03, 2007 | LG LP XG2 Multimedia Projector
Playing the cd's produced on my jvc stereo system
If you took the same steps, then obviously, it should work the same. However, there are many factors that could cause it to not play. You can try a different CD-R burning program. Also, some stand alone CD players do not play CDR's. So make sure your CD player can handle this. Also make sure your not burning an MP3 CD or similar. Make sure you also close the disc when it is done, and leave a 2 second gap between each song. Lastly, try burning at a slower speed - such as 4x - believe it or not, burning at a higher speed does affect your CD's playing options, especially on older CD players. Hope this helps! - Justin DJPROAUDIO
Jun 07, 2007 | Crosley CR248 Turntable
Numark ttUSB Turntable Logo
110 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
