Question about Dyson DC11 All Floors Bagless Canister Cyclonic Vacuum
Not picking anything up
The brush spins but it not picking anything up and it sounds very loud. If I use another attachment it works fine it's just the brush attachment that is having the problem.
  • Official Brand Answer
  • 2,572 Answers
I'm sorry to hear you're having difficulties with your DC11. From your description of the issue, it sounds as if you may have a blockage in the turbinehead. To check for and remove any blockages, please follow the steps shown in our online support guide:
http://support.dyson.co.uk/support/dc11/dc11-all-floors/maintaining-your-dyson-machine/how-to-remove-a-blockage/from-the-turbine-head/turbine-head-maintenance
This should resolve the issue, but if you'd like any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Posted on Feb 24, 2012
chrispurs1
  • 372 Answers
SOURCE: Suction not working in upright
Hi.
You will have A blockage in either the wand or hose, completely remove them from machine the hose unclips at the bottom back of machine,
Now switch machine on with this removed if machine sounds ok then remove the blockage from hose or wand.
If machine still poor suction & noisey with hose & wand removed check the (U) shaped inspection port for blockages.
Let me know how you get on.
http://dysonmanuals.llc.nu/index.htm
Posted on May 18, 2008
SUPERMAN_B_1
  • 294 Answers
SOURCE: the brush on my Dyson DC-14 wont spin
hello, have you checked to make sure you have nothing wraped around the brushes ? also it sounds like your belt needs to be replaced.
Posted on Mar 31, 2009
pocketspy
  • 20 Answers
SOURCE: Sweeper Brush doesn't turn.
Could be that too much hair, string, or long fibers have been collecting around the roller. Remove it and clean it off. Also check the duct behind roller that goes up into the connection hose. Ther most likely is some sort of blockage.
Posted on Nov 20, 2009
Vac Belts
  • 701 Answers
SOURCE: i have a dyson - bought it 3 yrs. ago and the
Don't worry it's probably just that the belt has broken or stretched. Your actually supposed to change them yearly. So if its been three years thats probably the case. Here is a link to the belt you need and a manual with instrutions:
Dyson DC07 Belt and Manual
Posted on Nov 29, 2009
  • 6 Answers
SOURCE: the roller brush is no
Possibly, the belt is broken or stretched out. Whatever the case may be, you will likely have to take it to the shop to get it fixed. Or at least if they didn't change the design of this model since I bought mine you will. They did something really stupid with this model. It's almost impossible to change the belt. You literally have to take most of the machine apart and then you need a took called a belt puller that you have to order online. Massive pain. Bite the bullet and take it to a shop. They'll probably charge you an arm and a leg but it's probably worth it with such an expensive vac.
Maybe get the estimate before they do any actual work. Just ask them to give you a price on what they think it will cost.
Posted on Aug 16, 2010
Bissell heavy duty 9x cyclonic vacuum cleaner has loud noise when brush roller is turned on
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Feb 19, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
Carpet washer brushes stopped spinning
Unplug it, turn it over and there should be some thing stuck in the roller brush.
Mar 14, 2014 | VAX Appliances Vacuums
HV9010P ROLLER BRUSH DOESN'T MOVE
That is probably the belt. Open up the bottom screws and take a look. The cat or dog hair usually gets stuck in the ends of the rollers and stops the belt from effectively pushing the roller. You may find that the belt is still on the drive and the roller. If you do just clean out the roller.
Jan 22, 2013 | Black & Decker AV1200 DustBuster Handheld...
Why would my dyson dc 17 brush motor be extremely loud, but sound normal when brush is not spinning?
could be the bearings on the end of brushbar need replacing,or it may be the clutch needs setting , lower the handle down to the floor then up again do this about three time to reset clutch....
Nov 13, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
My vacuum isn't cleaning/suctioning very well. The hose attachment will work and pick up debris but the main part of the vacuum (where the brush is) doesn't pick up. The brush only spins but there...
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
Jul 09, 2011 | Panasonic MC-V7582 Bagless Upright Vacuum
My vacuum was great when I first got it a few months ago, now it won't pick anything up off of the floor. The removable hose works fine, but the main vacuum isn't working at all. I checked the hoses for...
you could have a clog at the begining of the suction port above brush roll check that and make sure the brush roll is spinning if not it wont pick up anything
Feb 16, 2011 | Eureka 3276AZ Pet Lover Bagless Upright...
My Dyson Animal has good suction and works fine for actually picking up dirt, but when I use the vacuum with the roller, I hear a grinding/rumbling noise. Its only when I use the vacuum with the brush...
Trace the path of the suction into the tank and see if there is anything loose or ingested. Also, remove the brush and clean as best you can. Perhaps there is something caught in it. Lubricate where it makes sense with some WD40.
Oct 04, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My hoover windtunnel is not picking anything up all of a sudden. Also the roller underneith is not spinning. I've replaced filters and the attachment part is working fine, just when it's in the upright...
The belt that drives the brush roll has broken. That's why it doesn't pick up and why it doesn't pull itself forwards. Check the User Manual (download from Hoover website if necessary) for information on replacing the belt. Good luck!
Feb 05, 2010 | Hoover U6630-900 WindTunnel Bagless...
Vacuum cleaner does not pick up dirt
check belt.if making a loud noise then you might want to check the impeller
Oct 16, 2009 | Vacuums
Dyson DC11 All Floors Bagless Canister Cyclonic Vacuum Logo
118 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
