Question about Ample Audio A 410X Car Audio Amplifier
Ample Audio A 410X Car Audio Amplifier manual
2 Suggested Answers
SPL Freak
  • 63 Answers
SOURCE: the protection light keeps coming on on my ample
Most of the time. If the protection light is on that means your protected. Not that there is something wrong. So if it is working then your fine.
Posted on Mar 06, 2010
Tip
Kicker KX2500 Manual Download
Download Kicker KX2500 Car Audio Amplifier Installation Manual
Have you misplaced your Kicker KX2500 Car Audio Amplifier Owners Manual?
Would you like a digital, searchable, pdf version of the Kicker KX2500 Car Audio Amplifier Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 20, 2010 | Kicker KX2500.1 Car Audio Amplifier
Tip
Car Amplifier Installation
Mounting your Amplifier The mounting position of your amplifier will have a great effect on its ability to dissipate the heat generated during normal operation. It has an ample heat sink for heat dissipation, and also designed with a thermal shut-down protection circuit ( most amplifiers) making it reasonably tolerant of mounting variations. Any configuration with allows moving air to be directed over the cooling fins will improve heat dissipation dramatically, DO NOT enclose the amplifier in a small box or cover it so that air cannot flow around the heat sink fins. Temperature in car trunks have been measured as high as 175 F ( 80 C) in the summer time, since the thermal shut down point for most amplifiers is 185 F (85 C), it's easy to see that it must be mounted for maximum cooling capability. To achieve maximum advantage of convection air flow in an enclosed trunk, mount the amplifier in a vertical position, on a vertical surface. Cooling requirements are considerably relaxed when mounting inside the passenger compartment since the driver will not often allow temperatures to reach a critical point. Floor mounting under the seat is usually satisfactory as long as there is at least 1 inch (2 cm) above the amplifier's fins for ventilation.
  1. Select a suitable location that is convenient for mounting, is accessible for wiring, and has ample room for circulation and cooling.
  2. Use the amplifier as a template to mark the mounting holes, remove the amplifier and drill as much holes as required , USE EXTREME CAUTION, INSPECT UNDERNEATH THE SURFACE BEFORE DRILLING.
  3. Secure the amplifier using the proper screws.
Please rate the tip if it helped you in anyway, thanks.
on Feb 21, 2010 | Car Audio & Video
I opened the back and i see burn mark across the electrical unit from bottom right to top right. What can I do to fix this?
There is nothing much that you can do unless you have access to the spares and technical knowlege to physically repair the amplifier. I would recomend that you take it in to a reputable repairer in your area for assistance
Aug 12, 2010 | Ample Audio A 226X Car Audio Amplifier
The protection light keeps coming on on my ample audio a 410x amp it was working and now its not whats the problem
Mar 02, 2010 | Ample Audio A 410X Car Audio Amplifier
How to hook up 3 4om dvc subs to ample 1100dx
do u want to know how to hook up your subs...from behind connect a wire red to black on both subs from there conect the remaining red and black to the amp in bridge mode do that and you will have 3-4 ohms of power..running through youre system
Feb 17, 2010 | Ample Audio A 1100DX Car Audio Amplifier
I have a ample 1100dx is it a good amp it has no reviews on this amp i have a kicker 12inch 750rms i will be running it at 2ohms but my amp is going to push it at 800rms will it work properly will this amp...
yes you will be okay. you will have a good amount of heaD ROOM witch you want. you may need to back off on the input gain just a tad bit. but it will sound real nice. good luck with it!
Jan 23, 2010 | Ample Audio A 1100DX Car Audio Amplifier
Protection light on my a1100dx ample amp help plz
check ground thats the problem when power light is on it means amp has power but a short is bein caused from a sub about to blow or a ground connection hope this helps
Apr 14, 2009 | Ample Audio A 1100DX Car Audio Amplifier
Ample Audio A 410X Car Audio Amplifier Logo
Top Ample Audio Car Audio & Video Experts
xxxxxx xxx
Are you an Ample Audio Car Audio and Video Expert? Answer questions, earn points and help others
