Danby DPAC8399 Air Conditioner Logo
Posted on Oct 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Danby DPAC 8099 Moisture Removal problem
My unit has performed well for a couple of years. It sits idle from summer to summer until I need it - I recently put it back into service and it seems to cool fine, but there is no moisture being removed. I ran it for a few hours thinking that might jump start it, but still nothing. Is there a filter or a procedure I can perform to get this aspect started again? Kurt I just picked this unit up on Craigslist and the dehumidifier isn't working. Any help would be greatly appreciated.
Anonymous
Level 2:
Scholar:
  • Expert 136 Answers
  • Posted on Oct 23, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
136
Questions
0
Helped
48123
Points
309
Open the front area of the unit with a proper screw driver and then apply hot air for sometime with a hair dryer or a blower on the circuit board area.to make the moisture dry if collected in the area.then apply the cold air with the help of a blower for sometimes to all the parts where you think dust can be collected.let the unit serviced , but still blow the air.
this will help.
for further assistance please feel free.
thanks.
Anonymous
Level 3:
Master:
  • Master 763 Answers
Anonymous
Master
Level 3:
Master:
Answers
763
Questions
Helped
220234
Points
1990
Better to send to repair service for cleaning the dirt and change some spare parts of your machine if it has a faulty parts. so that they can replace and provide with a correct procedure. hope that helps!
CHARCOIS
Anonymous
Level 3:
  • Master 849 Answers
Anonymous
Master
Level 3:
Answers
849
Questions
0
Helped
315382
Points
2014
Open the cover and put it in sun light for some, also clean the lense with tissue paper.
Need Instruction Manual for Danby DPAC 5011
Hi There,
I hope you are enjoying the summer! :)
The owners manual for the DPAC5011 can be downloaded from our website. See the link below
http://www.danby.com/en/CA/our_products/air_conditioners/dpac5011
Simply click on the "Specifications" tab and download the PDF.
If you have any further questions one of our service agents will be happy to help!
Thanks and have a great day!
1helpful
We have 2 Danby air conditioners. One is a Danby Designer, Model DPAC 10060 and the other is a Danby Silhouette Model DPAC 12006. The venting hoses have broken to pieces and we need to buy new ones that...
You can purchase similar hoses at most home improvement center. Take a section of the old hose with you to get the right diameter and use the existing fittings to attach them to the unint and the window exhaust. What you may find is a better quality hose/duct, than what came with the unit. You may have to buy more than you need in length, but then you'll have some left over, if you ever have to replace it again.
Hope this helped. Good luck.
I have a Danby Mod.# DPAC 10061 portable A\C, the
This sounds like it could be a power supply problem. It may be very simple. I think I would first just unplug the unit, open it up, look for the PS connectors, and check/wiggle them to make sure there is good contact.
I went to the Danby's website:
https://www.danby.com/
And I was unable to find any service or owner's manuals in PDF format. The site does however have a locator for service shops. Good Luck!
da Marty
Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
I have a Danby DPAC 8020-5 air con unit. Air con
is there a flashing light on the unit? If so it will correspond to a needed repair. check your manual to match the number of flashes to the warning it is giving you.
Danby dpac 7599 PC board fuse keeps blowing
Sounds like the Start capacitor might be shot.  I think  you need a professional to service it.
2answers
Leaking water; reservoirs empty
I have this too we had that problem as well, nothing we could do about it either..
i need a new hose and exaust kit you know anywhere to get that?
this unit is ancient
1helpful
2answers
If the dew point of the air in your place of operation is low you will not get moisture out of the air. Generally when the unit is first used it lowers the indoor humidity and you get a lot of moisture. Once things settle out the amount of moisture will decrease.
Top Danby Heating & Cooling Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
