Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Sensotronic dishwasher cylce runs too long
4 Suggested Answers
  • 62 Answers
SOURCE: Bosch Dishwasher SHU43C02UC
Unplug from mains for 5-10mins. Are you having any power difficultys? sometimes this can crash the controller.
if none of the above possible that its the controller
Posted on Jan 03, 2008
SOURCE: Bosch Sensotronic dishwasher will not drain
We also have this problem. Dishes smell like golf course irrigation water. Any suggestions on how to fix it? Do we call a repairman?
Posted on Apr 17, 2008
  • 21 Answers
SOURCE: Where do I put the Jet Dry in my Bosch Sensotronic?
ON SOAP CUP WITH DOOR OPEN LEFT HAND SIDE IT WILL HAVE A DOOR IT OPENS LIKE A TUPPER WARE BOWL FRONT TO BACK LEFT HAND SIDE OF SOAP CUP LIFT UP AND SLOWLY POUR 3 OZ OF JET DRY OVER DIAL INDICATOR MAKE SURE YOU POUR SLOWLY MAKE SURE YOU CLOSE THE DOOR CLOSE D/W AND REOPEN DOOR THIS BURPS THE DISPENSER. JET DRY IS NOT SOLUBLE IN WARM WATER SO IF YOU SPILL ANY TAKE A RAG AND CLEAN IT UP GOOD ONEC A MONTH YOU REFILL W/ 2 TO 3 OZ
dON
262-893-4840
Posted on Jul 20, 2009
How do i run a test / diagnostic mode for the bosch sge63e05uc (evolution series) dishwasher?
Are the instructions on how to run the diagnostic test listed in the manual? FYI, I couldn't run the test on my Bosch DW because it was just too broken. Over the years the dishwasher essentially fried its own circuit board with excessive heat, which I learned is a problem common to Bosch DW's. Bosch told me the lifespan of my model was 10 years; mine was 11 years old (but was repaired once or twice). I replaced it with a Miele; no problems yet after 4 1/2 months.
May 22, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
Have a shu 4322 dishwasher it fills with water and drains but the spray arms do not spray. have not tried anything yet.this dishwasher is not hooked up. it was given to me by a friend who replaced all his...
Welcome to FixYa.
There was indeed a recall involving the control replacement nearly two years ago now if I recall.
As for checking into the present issue ( it doesn`t sound like anything to do with the control based on your description ) it sounds like the pump impeller may have become stuck. Did the dishwasher sit idle or in storage unused for a period of time ?
I have a service bulletin I could send you via email regarding remedying that issue of stuck impeller if you contact me at macmarkus@live.ca
I`d suggest you run the dishwasher through a diagnostic, but either procedure will require hooking it up.
To do this test/diagnostic on the SHU4322 series machine, it is as follows...
To start test program, press and hold both REGULAR WASH and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ "20" = version 0 without jumper).
When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone).
Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start button is pressed.
To start testing, press both the REGULAR WASH and RINSE & HOLD buttons a second time.
When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ "6" = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
2 = Heating fault
4 = Filling fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
i.e.
If water level switch has failed (opened), display will show fault code "4" and unit will continually fill and drain where testing won't be completed. If flow switch has failed (opened), display will show "0", water won't heat (to 150?F) and water won't stop circulating. If NTC probe has failed (opened), display will show fault code "8" immediately and testing will end shortly after water has started circulating.
What needs to be done to solve the problem will depend on the results/findings of the dianostic, so let me know what you find and we can go from there.
Either way keep me in the loop and I`ll assist you the best I can. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Oct 10, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My SHE4402UC/36 dishwasher malfunctioned all the lights were flashing and the machine was trying to drain. The guy came out and replace the control board. The dishwasher now read 199 on all cycles except...
well its not baloney but it is cheesey. normally changing the module is the cure but it has to be programmed correctly. bosch has a recall so check it out and see because the recall is free and the tech is suppose to know how to program it. go to thermedor .com and get the #. i am a old bosch tech.
Mar 11, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Where do I put the Jet Dry in my Bosch Sensotronic? I bought a house with this dishwasher but no manual. Many thanks!
dON
262-893-4840
May 19, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Doesn't cycle to open soap dispenser
RUN THE TEST PROGRAM TO DO THIS YOU WILL HAVE TO USE BOTH HANDS. Press and hold "Scrub Wash" &
"Delicate/Economy" buttons TOGETHER WHILE HOLDING THE 2 BUTTONS IN HIT THE POWER BUTTON RELEASE THE 2 BUTTONS AND HIT THE 2 BUTTONS AGAIN YOU SHOULD GET A 21 0R 23 CODE AND THE TEST PROGRAM WILL RUN IT WILL TAKE 45 MIN TO RUN BIT WHEN DONE IT WILL SHOW A CODE 1 OR 0 MEANS NOTHING BUT IF YOU GET A NY OTHER # OR LETTER IT CORRESPONDS TO A FAULT
DON
262-893-4840
May 02, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Jan 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Error code 2H.....or stops on last minute
I don't think you'll find it's the control board.
I think you'll find it's the heater box.
Not an easy job to do yourself unless of course you know what you are doing.
I would suggest you contact Bosch. One other possiblity is that the water inlet is blocked, although to be honest this is very rare.
Deep Diver
Dec 31, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Electronic controls don't count down properly
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
Nov 20, 2007 | Bosch SHU5315UC Dishwasher
I think I may have figured out a work around (by accident).  Start a cycle (any cycle), once it starts hold down Scrub Wash and Delicate/Economy at the same time for 3 seconds and the cycle will immediately finish (counting down quickly then to CL) and it will begin to drain.  I had to do this 3 times(draining more each time) but the end result was a completely empty bottom of the Dishwasher. To be honest I think this is the first time the thing has ever been completely empty!  I wish I was joking...
Garth
Nov 05, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Bosch 24 in. SHU53 Built-in Dishwasher Logo
27 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
