Question about Gateway 500XL PC Desktop
What's your problem? remove tower cover for gateway 500x pc
tbirdfan1
  • 3051 Answers
SOURCE: Gateway PC
the front cover first and the side cover needs to come off and then there should be screws behind the fromt cover that are holding in the power switch in place then remove all of the wires and please please dont forget where they go then remove the switch from the computer i would put the screws back into the computer so u dont loose them ok untill you are ready to put in the new switch i hope this is really heapfull for you keep me posted ok i am here to help best regards mike
Posted on Aug 26, 2008
byteguy
  • 2229 Answers
SOURCE: HOW DO I GET THE COVER OFF THE TOWER TO A GATEWAY PC
Try this link for your user documentation:
http://support.gateway.com/s/PC/310_Series/2900300/2900300ul.shtml
That should help.
Posted on Jan 30, 2009
tbirdfan1
  • 3051 Answers
SOURCE: I just wiped my parents pc and the drivers i
hELLO THERE:
if you have tried to use the drivers from the cd rom and this didnt help Please go to www.radarsync.com and use this free driver update utility. this is totally free to use this will automatically find the best drivers for the system and install them for you . ok please let me know how this goes and please rate this service for me.
best regards Michael Thomas
(usn retired)
Posted on Aug 04, 2009
  • 14 Answers
SOURCE: gateway 500x power short
your power supply may be dammged or set to the wrong voltave you can make sure it is the right one on the back of the power supply there should be a switch like button with a number
Posted on Oct 05, 2009
SOURCE: need mini tower cover
I am trying to reasemble my old Gateway Tower 500. I can remember where most of the things go but I can't find the Layout Diagram that came with it. Have you any idea as to where I might find one?
Posted on Aug 21, 2011
500x is really slow when online
possible to many start up programs possible virus ,trojan. ,malware clean pc well.
Mar 24, 2013 | Gateway 500XL PC Desktop
My gateway GT 5056 computer will not power on. I have checked the plug on both ends. There is no action when you depress the on button. We had a power failure yesterday and the computer will not come on.
Assuming there's no fuse in the mains plug or that you also checked it and its good, it sounds like the Power Supply Unit (PSU) in your pc tower has failed.
They're fairly easy to change, and if you're not too proud, fairly cheap second hand or from ebay.
The you'll need to disconnect everything, take the cover off you pc tower, the PSU is usually at the tom and back of the tower, the mains cable goes into the back of it.
Taking it out it fairly easy, there's usually just four screws which bolt to the back wall of the tower.
Then there's loads of connectors, Motherboard, possible ancillary to motherboard, one to each hard drive, one to each disk drive and one to the floppy drive.
All the connectors are key coded (Special shape and size) so you can't put them on the wrong device.
You'll need to get hold of a replacement, either the same power (no. of Watts - 250w, 350w) or better.
Putting the new one in is the reverse of taking the old one out.
Its straight forward, but give youself plenty of time and space to work in.
Oh ........ and give it a good dust out while the tower is open, helps stop the CPU overheating.
Apr 17, 2011 | Gateway GT5056 PC Desktop
How Do I remove the cover from a Gateway 500 series???
Like this Gateway SE?
http://support.gateway.com/s/PC/2800071/280007101.shtml
On the back of the computer remove the screw from the top middle.
Now remove the screw on each outside edge, down towards the bottom.
Hold the outside shell, or computer cover. Push the inside forward.
The computer cover comes off like a shell, or bonnet.
http://support.gateway.com/s/PC/2800050/280005003.shtml
If this is a reference to a Gateway 500X series, remove the thumb screw/s from the back of the computer, on the right side. (Right side as you are facing the back of the computer) Then slide this Side Panel towards the back of the computer.
Regards,
joecoolvette
Dec 19, 2010 | Gateway 500 X PC Desktop
Mouse gos off and I have to remove and replace it in usp I have a Gateway 500X pc with windows XP.
you should try replacing it on other USB ports and contact a vendor for your USB port
Apr 18, 2010 | Computers & Internet
Gateway 500x power short
Oct 05, 2009 | Gateway 500XL PC Desktop
I need to replace the power button on a Gateway E4000 mid size to
I think you will find this site useful in assisting you with removing the cover. I think you can scan directly to pg 107 for the "mid-tower" http://nzr.mvnu.edu/facilities/items/gatewaye4000manual.pdf
Mar 26, 2009 | Computers & Internet
That should help.
Jan 30, 2009 | Gateway 310S (2900621) PC Desktop
Gateway PC
Jul 08, 2008 | Gateway GT5220 PC Desktop
Need mini tower cover
Ebay has them for pretty cheap
Dec 07, 2007 | Gateway 505GR PC Desktop
Removing cover on gateway 300
This a tower right? I don't have a gateway but I have a dell and a compaq tower they come apart pretty much the same way. The left side panel slides out by pulling from the back. Some may have a screw or two you have to loosen or take out. Then you can either slide it by pulling from the back or there could be a latch that you slide to unlock it. Wow I can't believe it 60 bucks. Just keep messing with it you'll figure it out!
Oct 09, 2007 | Gateway 300 C PC Desktop
Gateway 500XL PC Desktop Logo
27 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
