Question about Protron PLTV-32 Television
Protron pltv-32cm turns on but cant be controlled
The only one function that can be controlled is power on.once turned on,cant turn off manually or remote .after one minute begins to change channels like autosearch but doesnt stop.it doesnt have a fixed pattern.i think it needs a reset.
5 Suggested Answers
SOURCE: searching for TV remote control code for PLTV-32
I spoke with their tech support in India and was told this tv will not work with a universal remote.
Posted on Dec 30, 2007
SOURCE: can only turn tv on manually
what kind of universal remote did you use? I am having the same problem. I use my dvd/vcr remote but i have to get up to adjust the volume.
Posted on Sep 03, 2008
SOURCE: Protron PLTV-20
Today I bought a ONE for ALL remote. I entered code 0019 and it worked. If this does not work, try 0030 1704 or 0056
Good luck DH
Posted on Dec 03, 2008
SOURCE: Protron PLTV-26 gets power but nothing else. No
i have a protron lcd menu light keeps flashing but tv wont come on any help would be appreciated.
Posted on Sep 14, 2009
moorah1
  • 181 Answers
SOURCE: need the rca remote code for a protron pltv-32
Afraid, you must purchase a new clicker. this is counterfeit brand, with no codes for universal remotes. If you can't get it at manufactures, check all available universal remotes at department stores for supporting this "brand". Sorry, didn't have any good experience of getting parts for "Protron".
Good luck,
Alex's TV Service,
Philadelphia,PA
215-806-5980.
Posted on Jan 22, 2010
Have protron pltv-32cm. model lt32c1m1. how do i shut off the v-chip block? i don't have the password.
Hello, there is a default password, if you source is in component 2 it can't be used here are some links to the pdf file pltv types.
V-Chip Lock When turned on, blocks access to mature television and movie content, based on the MPAA and TV PG ratings selected below, unless the viewer enters a password (set below). Set Password Sets the V-Chip password. To change the password, enter the current password followed by the new password. The factory-default password is '1234'.
PROTRON PLTV 32C User Manual Parental Controls
hope this can help.
Feb 21, 2015 | Protron PLTV-32 Television
Why does it take longer for the volume of my Protron pltv-32cm to go on each time we turn the tv on?
Proton 32, most plasma and lcd TV's have internal boards a few control the stability or video display these secondary boards are controlled by a main board. if your having sound or tv function issues the main board may be defective. is it worth fixing? that depends on the service center and what they are estimating it to cost. it is repairable by replacing the main board and that's if your screen itself is not the factor yet also consider the price for the repair vs. the price of a new set. you can get this part at auction sites or buy it online and repair it yourself or with a someone who understands electronics that would save you some cash. best regards..
Jun 14, 2014 | Protron PLTV-32 Television
I HAVE A PROTRON PLTV-32CM AND LAST WEEK IT JUST WENT OUT. NOW ALL IT DOES IS WHEN YOU CUT THE POWER ON IT JUST GOES AFTER ABOUT 3-4 SECONDS. I REMOVED THE BACK COVER AND ALL THE CAPISTORS LOOKS OK. WHAT...
Protron's mainboards like to fry and a replacement is difficult to find. Protron tvs are built with very cheap parts and don't follow manufacturing guildlines very well and are difficult to find parts for. I would start with the mainboard as the power supplys don't usually fail in these tvs.
Best of luck and please rate if this helped :)
Mar 11, 2011 | Protron PLTV-32 Television
CAN NOT FINDE PARTS
The coompany that produced this TV are out of business, so parts are not in any great supply. Try partsonline com
Thyanks for using fixya
Sep 22, 2009 | Protron PLTV-32 Television
Sep 06, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Digital or not????
You can get the owner's manual at;
http://www.bottomlinelcds.com/manuals/PLTV-32CM-owners-manual.pdf
You need a converter box.
Specifications
General
Dimensions
33.07"W × 25.83"H × 9.09"D
Weight 45.54lbs
Panel Type Active Matrix TFT LCD
Screen Size 32" widescreen (16:9)
Color Range 24 bits (16.7 million colors)
Max. Resolution 1366 × 768
Pixel Pitch 0.51075mm (H) × 0.51075mm (V)
Sync Range Horizontal: 30–80kHz
Vertical: 50–85Hz
Contrast Ratio 800:1
Brightness 500 cd/m2
Viewing Angle Vertical: +/–85°
Horizontal: +/–85°
Response Time 16ms typical
Inputs 2 × progressive scan component video (RCA)
3 × composite video (RCA)
1 × S-Video
6 × stereo audio (RCA)
1 × SVGA (15-pin D-Sub)
1 × stereo audio line in, 0 dBV nominal (1/8" TRS)
Outputs 1 x composite video (RCA)
1 × stereo audio (RCA)
1 × subwoofer (RCA)
1 × headphone (1/8" TRS)
Video Formats Supported SDTV: 480i
EDTV: 480p
HDTV: 720p, 1080i
TV Tuner NTSC-M, CATV, 181 channels
TV Audio Mono, Stereo, SAP
Parental Controls V-Chip (TV PG, MPAA)
Picture-In-Picture PIP, PBP
Closed Captioning CC1–4, TEXT1–4
Speakers 2 × 10W
Plug and Play Compliance VESA DDC1, DDC2B
Power Supply 100–240VAC, 50–60Hz
Power Consumption Operation: 232W
Standby: <3W
Storage Temperature 0 to 60°C
Operating Temperature 5 to 35°C
Apr 08, 2009 | Protron PLTV-32 Television
Needs New LCD Panel
I have a screen but need the vga card if you want to contact will sell for 300
Sep 05, 2008 | Protron PLTV-32 Television
PLTV-32CM THE REMOTE HAS NO CONTROL ON TV THE BUTTONS ON TOP OF TV WILL RUN THE TV THE BATTERY ARE GOOD
Remote not working...turned t v on with it and then it stopped working...where can I get replacement??
May 19, 2008 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
23 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
