Question about Sharp AL-2080 Pegasus Copier/Printer/Scanner
Sharp AL 2080 Copier
It is a brand new copier, never been used. The screen says L1 and will not allow you to do anything at all it just keeps blinking L1
  • Anonymous Mar 24, 2009
    Do you have the manual for this model; because I can not find the plastic knob underneath the scanner. I thank you in advance for all help and support on this matter.
  • pumbro30 May 21, 2009
    I have the same problem: the L1 light keeps blinking and I can't do anything.
There is a transparent plastic knob underneath the scanner unit that holds it in place while in its box. After installing you must turn clockwise this plastic to release the scanner mechanism. otherwise a L1 Error will appear on screen.
imaginguru
imaginguru@hotmail.com
Posted on Nov 08, 2008
Sharp fo 2080
C-Photo-C-photo-14 press print key
Jul 08, 2014 | Sharp AL-2080 Pegasus...
My sharp AL 1551 CS is getting a L1 error code before that it was getting a E7 code. The scanner will light up and shut right back down, then it shuts itself down again.
I have a tip posted here on Fixya that will help you diagnose and repair an L1 failure code on the Sharp AL series copier.
Here is the link:
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
If this works for you then please return here and give me positive feedback.
Thanks for using Fixya today.
Jul 13, 2010 | Sharp AL-1551CS Copier
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help
www.cyberscholar.com/sharp/resources/cop_man_soho_AL1642CS.pdf
http://www.service-docs.com/store/catalogue.php?cat=281&exp=0&resultpage=10 L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
My boss has a Sharp AL-1655CS Copy Machine and it makes this awful, screatching noise when I try to copy anything. Now the System Error Code L1-00 shows up. Not sure what to do.
Your problem on scanner unite.May be your copier is now lock position.
Solve:Unlock position.Left side under copy Board.Then solve your problem.Or study your copier user manual.
Jan 12, 2010 | Sharp AL-1655CS Copier
Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Oct 16, 2009 | Sharp AL 1631 Copier
Error code L1
Next exit paper have a key block scanner. Put knob in key out  for work well. Power off and power on. Good luck.
Jan 17, 2009 | Sharp AL-1551CS Copier
Printer will not prite anything you press anything and nothing happens it flashes L1
L1 means copy lamp problem or mirror drive problem. Check that area.
Jan 14, 2009 | Sharp AL-1642CS Copier
Error code L 1
probally little switch on "ceiling of where paper exits has been bumped locking lens, please rate as fixya or reply
Dec 27, 2007 | Sharp AL-1642CS Copier
Flashing L1 Display
clean the stripe band unther the glass
Dec 26, 2007 | Sharp AL 1631 Copier
Sharp AL-2080 Pegasus Copier/Printer/Scanner Logo
282 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
