Question about Dell Latitude C400 Notebook
Dell Bootup Problem
I have problem with Dell C400 machine. when i press power button, the power LED along with caps, num and scroll locks is turned on for 2 seconds. After that the laptop is turned off. i cannot hear any sound of hdd starting as well. No bios is displayed on the screen.
What can be viable solution for that?
  • Anonymous Dec 11, 2008
    I power up and the power led and cap led come on for about 3 seconds then unit shuts off no lcd or harddrive
    thank you
  • Anonymous Feb 28, 2009
    My C400 was doing that when I tried to change the RAM.
    Problem Solver:
  • 10 Answers
Reinstalll u r window with new partition and try keybord update
Posted on Oct 24, 2008
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
Press power button nothing comes up on screen, however, the num lock icon lights up and flashes, the caps lock icon also lights up. Dell Vostro 1510.
Copy and paste this link into your internet browser for the service manual for your laptop.
The star icon (*) means flashing LED, the bold circle means on, the circle within a circle means off.
The LED's that they are referring to are the NUM, CAPS and SCROLL.
It appears that you have a problem with your LCD. Try connecting an external monitor to your laptop. If you get a display then your LCD display panel needs to be replaced. If no display then your motherboard needs to be replaced.
Apr 19, 2011 | Dell Vostro 1510 Laptop
The lock key is on and that freezes my word document
I have a Dell Inspiron 6000 pv and I am not sure what you mean by the "lock" key. There are 2 lock keys on the computer: Number lock - which doubles as the Scroll lock when combined with the "Fn" key. Either of these can be toggled on or off. To enable or disable, simply press the key. If the lock for Caps or Num is on, the led just left of the power button will be lit.
On the Inspiron 6000, behavior for the NUM lock can be set in the system set-up. I am assuming the issue you are having has to do with how the lock is configured in the setup. Try adjusting the behavior to see if this helps fix your problem.
Apr 02, 2010 | Dell Inspiron 6000 Notebook
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
When I press the power button, caps lock, scroll lock, num lock, power led and hard disk led blink in every 5 seconds
they continue to blink every 5 seconds until you turn it off? It should blink all lights upon powering on but then remain off,
Aug 13, 2009 | Dell Latitude C600 Lcd LCD Display
Dell Inspiro 6400 not starting up
If the Num lock is lit constant, and the Caps Lock and Scroll Lock keys are flashing, the system is reporting a memory error. Power off the system, remove the battery, and follow the user manual from to reseat the memory module(s). If the error persists, you may need to replace the memory and/or the system board of the portable.
Mar 12, 2009 | Dell Latitude D600 Notebook
Dell Lattitude C840 Laptop
The 3 LED's (Num Lock, Caps Lock, Scroll Lock) are used by Dell to diagnose no-post issues such as yours. The only error code close to yours is [Num Lock ON, Caps Lock FLASHING, Scroll Lock ON]. This indicates a a memory error. Try reseating the memory modules. If you have 2 memory modules, insert one at a time to determine the faulty module.
Sep 21, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell D600 latitude will not power up
you can try to replace the motherboard, which is apparently totally UnHappy
Mar 16, 2008 | Dell Latitude D600 Notebook
Dell Latitude C400 Notebook Logo
117 people viewed this question
Alun Cox
