Question about Cortelco Lands Phones
How do i access my voicemail on my cortelco aries digital phone?
I need help accessing my voicemail a previous person put a password on my phone and I need to change it to be able to access my voicemail.
SOURCE: voicemail
From an admin phone, enter the voicemail. Then select More, Mgr, ChBox, then enter the ext# you need to reset the password on. Then choose Reset Password (Select Yes when the system asks you if want to reset the password). You can access the reset extension's voicemail by entering the default code.
Posted on Jan 10, 2008
  • 10 Answers
SOURCE: voicemail
Log into the voice mail server and you can reset the Voice mail for each account like it was a new account or you can delete the pass word on the account and then setup form the hand set. You do need to know the password to get into the voicemail server program. I believe as default it is NEC.
Posted on Nov 04, 2008
SOURCE: T7316E Voicemail issue
Reset the voicemail password.
Do so by first presing
Function 985 (to view the mailbox number the phone is using)
Function 983
Log: 1020000 (or 120000, 10020000 1st is for 2 digit extensions 2nd is for 4 digit extensions)
Left Button (MBOX)
Right Button (CHG)
Enter Extension
Left Button (RESET)
This should reset the passwod to 0000, the steps maybe a little bit off depending on the software version installed on the phone system, but something like that will fix the problem.
Posted on Dec 30, 2008
SOURCE: access voicemail from another line while away from home
The previous solution only works for older machines. I have the same Panasonic model and this works every time.
On your handset, hit the top center button(menu). Touch the arrow down button 7 times. Should say "Initial settings". Hit top right button on handset (display shows this is now the "select" key). Display now shows "Set Answering". Hit top right button again ( select key). Display now reads "Ring Count". Hit arrow down button 2 times. Display now reads "Remote Code". Hit select key again and enter your desired 2 digit remote code. Hit "Off" key. When you call the answering machine from the road, simply enter those same digits. Piece of cake. Enjoy.
Posted on Jan 10, 2009
SOURCE: Samsung iDCS 28D Voicemail Problems
If you have administrator access use the following steps to change the code:
Access the Administratin Main Menu and select 4 for mailbox programming.
Select the mailbox to program. Dial option code 1402. The current value will be played. To hear the current value press 1, to enter a new value press 2, to hear the range of valid values press 3. Press 2 to enter new value. Enter the access code for the mailbox. The value you entered is played back. Press1 to save or 2 to re-enter. Press 3 to exit without saving. Press # to exiit or hang up.
Posted on Aug 06, 2009
How to set up voicemail
  1. To access your voicemail, hold down the 1 button.
  2. When prompted, enter the temporary password (the last four digits of your wireless phone number).
  3. Follow the instructions to set up a new password and record your name and a personal greeting (or use the default message).
  4. You can check your voicemail from a landline.
How do I set up Voicemail on my Phone & Quick Messaging Phone ...
www.rogers.com/web/support/wireless/voicemail/903?setLanguage=en.
not sure if this helps you out,if not go to google and put info in there.
Nov 17, 2016 | Cell Phones
What my voicemail 4 digit passcodefor 2402620085
Your voicemail password is a 4 digit number that you enter when you want to listen to your voicemail messages from any other phone other than your mobile phone - this is called remote access. This voicemail password gives you the protection to know that only you can listen to your voicemails.
It is vital that your password is set to a random 4 digit password. To change your password, all you need to do is:
  1. Dial 173 from your mobile
  2. You will then be asked to pick a 4 digit number, and then press the # button
  3. If you are happy press press 2
Your password is all set up and you will be prompted to enter it whenever you want to listen to your voicemails through remote access.You will only need to use this password when accessing your voicemails from another phone. You will not need to use this password when accessing your voicemail from your own mobile phone - you simply dial 171 as normal
You can reset your voicemail pass code by dialing 611 or 1 800 331 0500
From the main menu, press3 (To get help with voicemail)
Press 2 to reset your voicemail pass word
Enter Billing Zip code
Customer will receive a text message to their wireless phone with their new voicemail password.
OR
You can log into your "My Account" from the www.cingular.com
From the My Phone page, click Reset Voice Mail Password.
Choose a wireless number from the dropdown menu and select Submit.
A text message is sent to the wireless phone with the new password.
Feb 24, 2012 | Cell Phones
How do I create a new password? I have a new phone. thanks.
For a new password for your account you have to call your provider they are the onlyone that can help you,if the password is for you voicemail if you don't have access they can help you to.If you have access to your voicemail,just follow the menu and select personal settings and then follow the instructions.
Good luck!!
Feb 23, 2011 | Cell Phones
Hi, I need help on resetting password on panasonic kx-t7731. Person who used this phone before set the password and left w/o letting me know. Please let me know if there is any way to access voicemail...
TVA and TVS systems have master passwords that the installer has. If you lost the password to 999, then your installer can probably come out and reset them. If you have lost the master password, Panasonic can restore that, but it's not easy.
If you happen to have the password for 998 and 999, you get there by pressing #6 *99x at the login. Put in your password and IIRC admin is option 5 or 6 in 999.
Carl
Sep 21, 2010 | Panasonic KX-T7731 Corded Phone
Changing user on voicemail
ill need to log into Manager and under that users tab, you can reset the password or delete the mailbox.
Jun 22, 2010 | Avaya 5400 Series 5410 Phone
Setting up your voicemail
I bought and Uniden Dect 6.0 phone and the other day I had a voicemail msg but I can't retreive it how can I do that the book doesn't show how to set up for voicemail
Nov 15, 2009 | Lands Phones
Need to reset my voicemail password without original password
To reset password on any tel set go to main set and press feature 983 this gets you in to programming you need a password and default password is normly
120000 for 2 digit locals and 1020000 for 3 digit locals etc.enter this password and press ok go in to
mbox type in mailbox press change , press reset password. hope this works
Sep 17, 2009 | NorStar T7208 Corded Phone
Need to access voicemail with no password-panasonic KX-T230 phone
Find the password to mailbox 999 or call a Panasonic dealer.
Carl
Jun 16, 2009 | Panasonic Lands Phones
Access voicemail from Nortel T7208
Have you set up the voicemail before?
OK, from your set;
-> dial FEATURE 9 8 1 (this is the code to get you to the voicemail)
-> then your passcode, if you never set up the voicemail, the temporary password is 0 0 0 0 (four - zero's).
-> if this is a new installed voicemail, the telephone system will tell you al that you need to initiate the voicemail box.
Jul 29, 2008 | Nortel Business Series Terminal T7208 -...
Lands Phones Logo
132 people viewed this question
Top Cortelco Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Cortelco Lands Phone Expert? Answer questions, earn points and help others
