Question about Aiwa XC-35M 5-Disc CD Changer
The lazer unit won't raise up.
When I insert a disc and close the disc drawer the lazer unit seems to be jamming. And the disc won't play in any of the five slots. I have checked the gear alinment and it is fine. What should I do?
    President:
  • 3,130 Answers
Have you checked to see if the units laser assy is returning to home and when its trying to read a disc, is the lens moving up and down , trying to focus? Have you tryed to clean the laser lens? If you have done all this then your units most likly going to need a laser assy or a servo alighnment. If it has to go into A shop for repair, Im afraid it may not be worth it. GOOD lUCK
Posted on Aug 06, 2006
  • wertypenn Jul 30, 2011
    Thanks this may be the answer i am looking for
What does U1 mean when it appears on the pioneer cld v860 display window and the disc won't play?
It sounds like buy your details, That i will compliment you on, Are to the point not like some other people asking questions on hear, That the lazer is shot, End not reading the info off of the disc any more, It is verry costly to have it repaired, Just look for a different one, I have got good used ones for friends of mine for $7 to $30 at the most, From thrift stores or privately, Hope this helps you out.
Nov 11, 2012 | Audio Players & Recorders
Pwr. on but won't play cd,
The lazer is not reading the info off the disc any more, It is costly to have them (Replaced) $180 to $250.
Nov 01, 2012 | Yamaha CDC-655 CD Player
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
DVD won't play
get yourself a lazer cleaner and run that, it should work after that.
Apr 10, 2009 | Televison & Video
When putting music disc into slide close drawer comes up on screen loading then comes up no disc when there is a disc already in thanks
Unit is not recognizing disk because of defective or dusty lazer pickup. It may also have defective disk motor. Have serviced
Aug 14, 2008 | Audio Players & Recorders
SAMSUNG SV-DVD440 Combo
how old is the player, it sounds like the lazer has gone down if it reads cds and not dvds
Feb 09, 2008 | Samsung SV-DVD440 DVD Player/VCR
Koss KD365 DVD - Says No Disc
Make sure the disc is spinning. This might sound crazy but try turning the whole player upside down and see if it plays.
Jan 02, 2008 | Koss KD365 DVD Player
Won't play recorded cd's
Try this link. It offers resistor changes which are designed to fix your problem of inability to play any CD R. on that model Nakamichi. jacknz0 http://home.cogeco.ca/~niteowl/Nak_MF51.jpg
Dec 31, 2007 | Nakamichi MF-51 5-Disc CD Changer
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Aiwa XC-35M 5-Disc CD Changer Logo
204 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
