Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Water backing up into kitchen sinks
I'm thinking clog, but don't know where to start looking. My husband is not a "fix-it" kind of guy so I thought maybe I could give it a shot. I'd ask parents and in-laws, but they don't believe in dishwashers!!...hahaha
I turned off the washer after I lifted the cover off the valve located on the sink edge and had Old Faithful in my kitchen! The water remained in both sides of the double sink for maybe 1/2 hour-45 minutes and then drained away by itself.
Please help!!!
Thanks
Michelle
  • 148 Answers
Assuming your dishwasher drains into the trap coming down from the sink, you would need to check the S trap located there.
Posted on Nov 11, 2008
Why does the unit come on for 1 or 2 seconds when I shut the cold water off in the kitchen
It may just be something it does when you happen to turn on the sink. I don't think there is a problem with the water heater coming on when you use cold water. It may just be heating the water back because the water is much colder than normal. You could talk to an HVAC guy and see what kinds of things they can do to help the situation. SERVICES Marv Plumbing Bellingham WA
Apr 10, 2015 | Rinnai RL75iP Interior, 7.5 GPM, Liquid...
Tip
Backed Up Kitchen Double Sink Fix with Garbage Disposal- Quick and Simple Fix
Here's how to fix a backed-up double sink (running water down one side/sink causing dirty water to well up out of the drain on the other side, with slow or no emptying). Note that this quick-and-easy tip only works if you have a functioning garbage disposal.
What you will need: a stopper, and possibly a clean toilet plunger (the cup-shaped kind that stands on its own, not the kind that is bulb-shaped)
Stopper up the side in which the water is rising up out of the drain. Make sure you hold down the stopper as well; if you don't, the stopper will shoot up on a geyser of dirty water when you perform the next step. Once you have the stopper in place and are holding it down, run water on the other side/sink and turn on the garbage disposal. Once you have done that for a reasonable amount of time, shut off the garbage disposal and water, and unstopper* the other side. Run water on both sides to make sure everything is draining properly. Doing this should save you the hassle of taking the pipes apart or plunging one side repeatedly to clear the clog.
*Note: If the stopper is stuck, place the plunger so it completely covers the opening the stopper is stuck in and give it two good plunges. The plunger should create a vacuum that will suck out the stopper, and is more effective than you trying to pry or pull on it. Do this ONLY after you have shut off the garbage disposal and water.
What is happening is that there is a clog in your pipes. When water goes down one side, it hits the clog somewhere in the pipes, has nowhere to go, and gets pushed back up the pipe leading to the other side of the double sink. By stopping up the side without the garbage disposal, you are creating a barrier preventing the water from coming back up. At the same time, the garbage disposal running on the other side is forcing the water down. Since the water now cannot escape up the stoppered side, it has nowhere to go but down, forcing the clog out with it.
on Jun 28, 2014 | Home
Shower in basement is backed up. Wondering if it's because a floor drain is covered up.
sounds more like the drain line is clogged between the shower and the main stack, and shares venting and drain with your kitchen sink. Have a plumber run a drain snake down from your kitchen drain (after the 'P' trap ) to clear the line. A covered over floor drain should have no effect on the back-up.
Oct 31, 2014 | Plumbing
Foul Odor & Occasional Leak
Looks like you were suffering thru the same thing we have in our house - did you ever get a solution to this? I was wondering if some of your vent pipes were cracked or partially clogged, especially where you had that plumbing access hole in the wall. Hope you've got this fixed already, since plumbing companies usually charge about $350 to run those smoke tests to find and pinpoint problems, and it doesn't always work. Buzzie
Feb 07, 2014 | Plumbing
My Bosch dishwasher SHU43C won't fill. husband used plunger in kitchen sink many times throughout the day. we didnt realize the water was being forced back down the dishwasher drain valve and filling the...
You need to clean that contaminated out of the dishwasher and clean the water level float and the screen at the bottom of the washer tub.
Jul 13, 2017 | Dishwashers
Odor coming from disposer
Hello, Tell your husband to wash his feet some place else, OK. it needs to be cleaned. Don't put you hand in it, OK. On the top in sink remove the rubber flapper and clean it with soap water and vingear. Put about four large cups of ice and tuirn on the disposer. The ice clean out any stuff that in the chopping blades. Mix up a sink of water, soda and a little clorex in the disposer sink then let the sink drain and turn on the gargage disposer then let it run while water is running into it. Do a cleaning procedure once or two a month. couple of lemons, Clorex, baking Soad, this stuff will work great. It will make you disposer smell like fresh spring day but tell you husband to keep his feet out of the kitchen sinks. GB...stewbison
Sep 24, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Kitchen sink clogged up , ran a roto rooter that you buy at the stores through the outside access and nothing happened. did the plunger thing on the sink and again its still backed up. I thought that...
Check the traps on the sink for clog and maybe if it has a turn in the wall it may be clooged .
You can disassemble the drain under sink and try and auger there.
Or if you can get acces to an air tank you can make up a fitting to screw on drain under sink and put air on it to try and free blockage.
May 06, 2010 | Plumbing
Clogged Sink, Disposal On Takes Water Down, Off, Spurts Back Up
I agree it definitly is not your garbage disposal. You could try to use a liquid drain cleaner, but in my experience those do not work all that well, especially on the type of problem that you are having. If in fact you can not take apart your P-trap, (it shouldn't be a S trap), you should look for some type of a clean out cover under the sink or in the basement (if you have one). If there is another fixture down line, or for that matter up line, are you having problems there? It is possible that you have a clogged pipe under the sink. Unfortunatly if you can not disassemble, you (or a hired prof) will have to cut under the sink to find the problem. Hope this helps
Sep 30, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Dishwasher water keeps backing up into kitchen sink then taking a long time to drain from sink
Yes, your sink drain needs cleaning -- it's clogged. Pour some bleach into the sink drains and let it sit for a couple of hours. Flush out with boiling hot water.
If this improves the situation but not completely solving the drain problem, try it again.
If that doesn't solve the problem, remove the P-traps on the sink drains under the sink and clean them out.
If that doesn't work, let me know -- we'll try something else.
May 05, 2009 | Dishwashers
Foul odor coming from kitchen sink/dishwasher area????
Hi Jenny - I had a terrible smell coming from under my sink, and I too thought it was a dishwasher/garbage disposal drainage issue. I used vinegar, baking soda, bleach and hot water on a daily basis. When I cut out the wallboard from under the sink and the smell got even worse, however, there was no sign of any water leaks or evidence of a dead animals. Come to find out, when I had a "friend" cut out a pass through from my kitchen (above the sink) into the den, he cut the pvc exhaust pipe and didn't re-route it nor cap allowing the fumes to escape outside via the attic. Thus, the fumes had no place to go other than down. The smell confused me because I thought it was rotten food or most likely a dead mouse trapped between the wall. The smell was actually causing me to get headaches. It's been almost 24 hours that this was repaired and I already can "smell" the difference. I hope this helps! Good luck.
Mar 30, 2009 | Tappan MDB531RF Dishwasher
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
96 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
