Question about Nikon D70s Body Only Digital Camera
What does fEE mean on a Nikon d70?
I turn the camera on and get the r09 error message. But it also Flashes fEE above when I press the shutter button. How can I get this camera to work.
  • 19 Answers
SOURCE: Nikon D70 Err
The "ERR" code usually refers to an aperture problem. For example, if a lens with an aperture ring (Sigma is a favourite) used for earlier cameras is used, the aperture has to be set to its smallest (usually f/22 or "A" for automatic).
As you are using an 18-200, I assume it's the Nikkor VR. Callinto a camera store and ask them to check with a different lens. It may be the VR lens is faulty.
Posted on Apr 05, 2008
SOURCE: nikon d40
I had exactly the same problem, i tried everything,battery out, sd card out , lens off etc...nothing worked.Completely by chance and irritation i repeatedly pressed the shutter butten over and over
( without the lens attached ) till it didn't react at all.On my LCD i got a normal menu so i put the lens on and bingo it was fixed, still works fine.I think maybe the shutter was out of alignment.
Hope this works for you.
Olly
Posted on Jun 01, 2008
  • 9 Answers
SOURCE: Nikon D70 Shutter Problem
I have a Nikon D70 which failed completely but exhibited similar symptoms.
I was fortunate in that I had taken out 3 years free warranty at the point of purchase and therefore saved the £90 (sterling) repair cost.
Nikon cameras are designed to be robust and should give a lifetime's service. Most should give 150,000 shutter actuations.
There is a piece of free software available on the Web that will tell you how many actuations were recorded on your recent photos.
Unfortunately, in the fast moving world of digital cameras, the value of a 2nd user older camera is very low.
You need to decide if you were outgrowing this camera body and want to replace it with something better or whether you would be lost without it. My repair took more than 1 month and I was not able to take any photos during his time.
I hope this helps.
Posted on Feb 07, 2009
  • 14 Answers
SOURCE: nikon d40x camera not working
The camera has a bad shutter or a bad sequence plate motor .
If you need help further contact
Berrie Smith Camera Repair
Posted on Apr 11, 2009
  • 291 Answers
SOURCE: Nikon D80, how do you turn off the r09, r11 and/or
The r09, r11 or r17 just tells you how many pictures you can shoot before the internal memory buffer is full. It's not an error message, and I don't think there's any way to turn it off.
Posted on Oct 02, 2009
Why are the letters fEE on my screen when I push the shutter button, and the shutter will not work ?
https://support.nikonusa.com/app/answers/detail/a_id/2605/~/what-does-the-fee-or-f---error-message-displayed-on-an-slr-camera-mean%3F
May 22, 2014 | Nikon D7000 Digital Camera
After some shots an ERR message appeared on LCD, I could not make more picture. The error message in the counter field (when half pressing) the shutter is r09. I tried to take in and back the battery, the...
"ERR" doesn't indicate any specific error, but usually tends to be something only a technician can fix. Sometimes, you can make it go away by fully pressing the shutter release, but chances are that it will reappear at some point. Take it to a reputable camera shop, or send it to Nikon if you're still under warranty.
(The "r09" message is not an error, but an indicator of how many images you can take-nine in this case-before the camera has to pause for processing. This usually applies to burst-mode photography, and varies depending on how fast your CF card can transfer images.)
May 15, 2011 | Nikon D80 Digital Camera
Nikon D70 is freezing up. I have no idea what I may have done but when I push the button to take a picture nothing happens and r09 flashes
r09 is just the camera estimate od how many shots you have left on your memory card. For the other, Use fully charged battery , Turm ca,era on and re,ove battery while at same time holding shutter for a[[rox 3- seconds. Re[lace battery, then turn camera off.on. If that does not do it, turn camera on and press reset button on bottom of camera (page 200, I believe, in tghe users manual
Jan 29, 2011 | Nikon D70 Digital Camera
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
My d 80 gives an err message on the lcd and r 09 is flashing on it, the shutter just clicks and makes the sound but no picture taken, i am frustrated please help
The r09 just tells you how many pictures you can shoot before the internal memory buffer is full. It's not an error message2_bing.gif. If the camera isn't taking a picture, then it's something unrelated to the R09 message. If the shutter clicks, then it probably IS taking a picture.
Jan 14, 2010 | Nikon D80 Digital Camera with 18-200mm...
Nikon D80, how do you turn off the r09, r11 and/or r17 alert (depending which Image Quality setting I have the camera set to)? I have sent the camera back to Nikon twice and twice it has come back with the...
Sep 29, 2009 | Nikon D80 Digital Camera with 18-135mm...
Our Nikon d1x won't take a picture. It gives me an FEE type of error and the battery flashes.
The blinking FEE message means the aperture ring is not set to minimum aperture (highest number). Turn the aperture ring to the highest number, and then find the aperture lock -- either a little slider or a button you press and turn. That will keep it from accidentally changing again.
Dec 31, 2008 | Nikon D1X Digital Camera
Error message on D70 freezing camera operations
I got this info from Nikon for D70...
When you see Err on the control panel, LCD monitor or viewfinder of your digital camera it refers to a camera malfunction. Try the following:
  1. Remove all accessories from the camera.
  2. Install a freshly charged battery into the camera.
  3. If your Nikon camera offers resets such as the two-button reset or a hardware reset please follow those instructions provided in the product manual.
If these steps do not resolve the Err message we recommend having a Nikon Authorized Repair Technician evaluate the Nikon camera.
Hope this be useful for you to resolve problem.
Oct 07, 2008 | Nikon D70s Digital Camera
Nikon D70 Flashing
ERR is i think an error message generated when the camera can not read the cf card ? have you had an problems with corrupted images ?
Sep 24, 2008 | Nikon D70 Body Only Digital Camera
Nikon D70s Body Only Digital Camera Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
