Question about Panasonic CT-27G14 27" TV
Panasonic TX-29AD2DPM Serial no LE-7511621
Hi i think the Tube has gone i have a thin line across the Screen wondered how much it would cost to get fixed as i like the T V. Cheers Colin
  • Anonymous Mar 14, 2008
    Panasonic TX-29AD2DP B Serial Number LF-6411012 CHASSIS EURO 2S
    1. For over a few years, when I switch on and off the TV, a bright white horizontal line appears on the screen;
    2. A few days ago, the TV has NO Picture and NO sound except the screen has black & white patterns / ghosting as if there is no aerial. I checked to see that our communal aerial has not affected anyone else hence, fault not due to aerial.
    Can you please advise what could be the fault with my TV?
    THANKS
    New Friend:
  • 163 Answers
97% of the times is a desolder vertical Ic, vertical cold solder are a comun defect of these model, most be a cheap repair but only if you find the correct person to do it...good luck
Posted on Aug 06, 2006
    President:
  • 3,130 Answers
No Colin, Its not the Tube. The problem is a vertical sweep falure. it could be just a driver/output IC or could also have a problem In the sweep power supply where The voltage that supplys the B+ going to the vertical IC could also be defective. Its not a repair a user should attempt to do as it's soldered into place and you can get hurt if not experienced with these types of TV repairs. As to the cost It depense on how much you like the set and if you can find an honest repair person to do an honest job? Good Luck
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Very thin black vertical line moving across tv screen left to right on tv
The screen voltage to the picture tube is more than normal. Adjust it by the help of screen pot-meter integrated with Line Output Transformer. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 05, 2012 | Panasonic CT-20SL14 20" TV
Lines across the top of screen
If this is a picture tube set (not a thin screen), then you have a bad electrolytic capacitor in the vertical circuit. Just about all picture tube sets that I've worked on that get lines at the top was caused by a bad or leaky cap and is a common problem w/ most sets. There's a very slim chance it could be the vertical ic but normally when it goes bad you will have nothing but a thin white line running across the center of the screen from left to right. If it's just a capacitor, the part would only cost a couple of dollars at most, however there's no way I can tell you exactly which one to change w/ out looking in the set. A repair shop would probably get between $30-$50 to fix it. If you can give me the model number of the tv, I can see if I can you some more info.
Jul 28, 2010 | Sylvania Televison & Video
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Panasonic PT-47X54J Not working
I can't tell you how to fix this set, but I can tell you that its not a "lamp" issue as this doesn't have a lamp. Its a 3 picture tube projection TV. the three tubes are in a red green blue format, and average about $175 for each one, not including the labor to install them. your problem, may not be the tube, but just a power supply problem, but there is a chance it is.
Nov 21, 2008 | Panasonic PT-47X54 47" Rear Projection...
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Tube TV - one thin horizontal line of bright light
Vertical defection failure. Common failure. Pretty easy to repair ($50-75?). However, my general rule of thumb is not to waste any more money on TVs over 10 years old. Too much other stuff in there ready to fail as well.
Jan 24, 2008 | Televison & Video
PT-47WX, Blue streaks across the screen?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
Sep 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Panasonic CT-27G14 27" TV Logo
114 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
