Question about Epson Office Equipment & Supplies
Model 230 a stylus 777 - color problem - paper will not feed into printer call for i copy -- get more than called for - not always NOTE --- LAST PROBLEM -- ORIGINAL PRINTER 10 yrs.ago - CORRECTION ---- TALKED TO LONG BEACH -- LONG BEACH SENT NEW PRINTER RETURNED PROBLEM PRINTER IN EPSON BOX RECEIVED NEED YOUR SUPPORT ------------------ THANKS C.N
Arius
  • 446 Answers
SOURCE: epson stylus photo R 230 series
unless the head come to a halt during initialization process, upon turning on your printer there is no way you will be able to print, please check for any obstruction on the printer head, the grinding sound is an indicator that the head is trying to reach its position and was having trouble. or it could be a damaged belt that you need to replaced
Posted on Jul 14, 2008
Basti
  • 1447 Answers
SOURCE: not feeding correctly
Hi-
Chances are that part may not be replaceable, but try contacting compassmicro because that is one of epson's part distributor, others vancebaldwin.
hope this helps
Posted on Aug 24, 2008
Maliron
  • 12 Answers
SOURCE: printer got wet. usb device (printer) unknown to
First of all, sorry to hear it, I know how frustrating it can be!
Printers are typically DC powered devices and as such they are fairly tolerant to getting wet and will often work just fine, as long as you allow them to dry completely before trying to apply power and use the device again.
How long did you let the printer sit before trying to power it again?
If the device was not completely dry before plugging it in again, there is a strong chance it has be ruined beyond any simple repair.
How old is the printer?
If the printer is more than 2 years old, it is often easier to simply buy a new one. The printer you paid 200$ for 2 years ago will likely be a baseline model for $50~$100 now with the same quality.
Posted on Mar 26, 2009
  • 47 Answers
SOURCE: epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Posted on May 15, 2009
1alexh
  • 484 Answers
SOURCE: Ref EPSON STYLUS 680 printer paper feed problems
Have you checked to see whether the sensors are not blocked by excessive paper dust? Do you know whether the printer is set to pull in a specific type or weight of paper?
Oftentimes, if you have printed on a heavy weight type of paper, or on a glossy type of paper for printing photos, when you next try to print,you forgot that the printer had been set for a different kind of paper ... one which requires the printers transport rollers to grab a heavier, or shinier type of paper, and now, when you try to print on regular paper, the printer;s rollers are simply not able to grab that kind of paper. so no matter of any types of paper or times they try to fix it, if they do not set it using the printer's 'properties' software button, they will not get it done right, and the printer will simply slip or slide but not grab the paper correctly.
Do it from within the printer's control panel and you will have a much better chance of having it work right.
Try that and see if it doesn't solve your problem.
-a.
Posted on Nov 06, 2009
Tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
on Sep 17, 2008 | Epson RX620 All-In-One InkJet Photo...
When printing photos on glossy Kodak paper the error message " paper jam reload" appears.
Some printers are not able to or having difficulty feeding glossy photo papers at 230 gsm and above, try using photo papers below 230 gsm.
Jan 13, 2010 | Epson Stylus Multifunction Printer/...
When I insert the 4x6 paper portrait it won't advance it to print.
You are probably using a glossy paper or photo paper 230gsm or above, some printers are having a hard time feeding with those kind of papers, try using lower than 230 gsm.
Jan 11, 2010 | Epson Stylus Photo R320 InkJet Printer
No ink output from Epson Stylus Color 777
I don't have an answer for you but I have the exact same problem.
I have an Epson Stylus Color 777 and I put in new cartridges (black and color) that I bought yesterday (03/05/10).
I pulled the tape off the cartridges and inserted them in their carriages. Everything works like usual except that no ink at all prints on the page. Comes out completely blank.
Nov 11, 2009 | Epson Stylus Color 777 InkJet Printer
Epson stylus color 880 printer has a paper jam. It printed color in area with no paper, so to get ink out, I fed in a paper towel. Now the towel is stuck and torn remnants cannot be reached from above. ...
OK this takes a bit of technique and bravery. You need a stiff piece of card such as the backing from an A4 notepad or similar. Turn the printer off and insert the card into the paper feed. You will need to align it with the pick-up roller and push it through quite hard to overcome the spring pressure. It will push out the bits of towel so open the cover and fish them out. Feed the card all the way through and out of the cover. Always try to remove paper jams in the direction of paper feed.
Hope this helps, please take a moment to rate this solution. Thanks.
Apr 02, 2009 | Epson Stylus 880 InkJet Color Printer
Epson Stylus COLOR 1520
There could be something wrong with the connections going to the ink jet cartridge in the printer.
Someone should take a look at it.
Jun 14, 2008 | Epson Stylus 1520 InkJet Color Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
