Question about Jura Capresso C1500 Espresso & Coffee Maker
Need service manual for Capresso C1500
I would like to be able to clean this machine without sending it back to Jura, need only a service manual
SOURCE: Jura Capresso c1500..........'Service 8'
I finally called Capresso, resigned to send mine in for service (I'm the same poster as above). Instead they walked me through how to clean a sensor on the inside of the machine, told me how to change the grinder settings to less fine, and made me promise to dry my beans from now on. Cleaning the sensor isn't too hard--you have to feel up behind a flap on the underbelly of the machine and wipe it off with dry clean paper towels. I recommend giving them a call--they were very helpful. Good luck!
Posted on Nov 04, 2007
SOURCE: Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
Posted on Dec 30, 2007
  • 13 Answers
SOURCE: Where can I find an Jura Capresso Impressa F9 replacement lid
The only sources I have been able to find are in Europe. They do not always wish to ship to the US however. In the US the dealers always want the repair, but seldome wish to sell parts outright. Try this website for parts.
Mike
www.juraprofi.de
Posted on Jul 05, 2009
  • 10 Answers
SOURCE: Need an "O" ring Jura Capresso C1000
ebay has them
Posted on Nov 22, 2009
SOURCE: Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
Posted on Dec 15, 2009
Water in disposed coffee container jura impressa z5
You may have to clean the unit using cleaning tablets, also there is a flap in the bay (remove the tray and use flashlight, sometimes it cakes up and moisture collects. Final thought is you may need to send it in to Capresso/Jura for service. Mike
Mar 08, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
Tray missing error
The "sensor" is most likely a micro-switch. When the tray is in it actuates the switch and closes a circuit indicating to the controller that the tray is in place. Sorry to tell you this but it will have to be disassembled to replace the switch if it has failed as the micro-switches are usually sealed items that are not normally cleaned.
Nov 11, 2013 | Jura Capresso C1500 Espresso & Coffee...
Need to dissassemble Jura Capresso C1500
I just opened up my Jura Capresso C1500 Machine. It's a little tricky, but here is how I did it. I gently pryed the front part of the top off. There is a tab connector in the very front of the oval in front center. Lift (or gently pry with a flat head screwdriver) straight up until it comes free. There are several other tabs that will lift straight up on both sides of the top. However, there are two tabs in the back (one on either side where you see the black pins protruding out the back top of the machine) that are encircled around the pins. The only way I could get those off was by gently prying until the tabs snapped off cleanly. I pryed the one on the right first, and it stayed intact except for breaking off the bottom of the circle; so it will actually still snap into place back over the pin. To free the left tab I simply lifted the lid up and down several times until it snapped off cleanly. There are so many other tabs that fit tightly into rectangle-shaped sockets that breaking the back two did not change my machine's appearance or function. Once the top was off, you can access a lot of its workings including the grinder, top water tube, spout, etc. I use dark beans that are slightly oily so I took off the bean compartment, silicone funnel ring, and attachments and cleaned them thoroughly with hot, soapy water. We found a pebble or two in our beans through the 8 years we have used it and I think they have done some damage on the grinder.
Dec 25, 2012 | Jura Capresso Coffee Makers & Espresso...
I removed all the water pipes and do not know how to put in place so as to work,who can help me please with some detailed pictures or find the exact order details such insurance.
Hello
Come over me by purchasing any of my services advertised in FixYa. I've the exploded view of your Jura Capresso Impress S7. I can't send it to you by this window as it does not allow me to send PDF files by it. If you purchase any one amoung my service, I can get a link to you provided by FixYa, by which I can send the diagram and instructions by it. OK.
Dec 09, 2011 | Jura Capresso Jura / Capresso IMPRESSA S7...
Capresso C1500 Scraper blade dropped out; nothing broken; how d I fit the piece back into the machine? Is there a schematic?
Hi Alan
Try Manual & Instruction Books On Line
The Books & manuals are more than likely on the manufacturers site.
They usually can be downloaded for currently available devices.
Search their support area for your specific model of device.
Try Google Search for a Manual or PDF File for the specific brand & model number.
Also check these Sites:
www.retrevo.com .... Manuals
www.office.manualsonline.com
Dec 02, 2011 | Jura Capresso C1500 Espresso & Coffee...
Service 8 on Capresso 1300
The gears inside are clogged with coffee grounds. The machine will need to be taken apart carefully, and the gears cleaned of the coffee. I just did mine a C3000, and you will have to be careful to remember how all the parts go back together. This takes a T15 hex key for the screws. Good luck.
Aug 30, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
Used to get the Service 8 with increasing frequency until it almost froze up. Luckily I figured out an easy solution and my 5 year old refurbished C1500 with over 4000 coffees runs like brand new. Here's how:
Take out the grounds tray and reach in to pull back the flap up above where the grounds fall. There is a piston and cylinder thingy behind the flap kind of like a car piston. Take a wad of wet paper towel and shove it up there to clean it out. Then use a dry towel to dry it. Now the secret solution: Take a can of spray pam and point it at the piston and cylinder with the flap pulled back. Give it a couple good shots. Now you just need to get the machine to work that in between the piston and cylinder walls by running the rinse cycle until it frees up. You may have to run it a few times then unplug and let it cool for a couple hours and run it again. The motor overheats if the piston is really stuck so you need to let it cool down. Apparently this is lubricated at the factory with a FDA approved food grease from Dow Corning that needs to be replenished but hey no one is going to die from a little vegetable oil. Some day if it even hints at happening again (It has been 3 months now) I know what to do. Cheers!
Oct 17, 2007 | Jura Capresso C1500 Espresso & Coffee...
Jura Capresso C1500 Espresso & Coffee Maker Logo
54 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
