Question about Polaris Garden
I need a vacuum diagram for an 03 polaris 330 sportsman pleaseg
Got it cheap but someone took all the vac lines off and couldnt get them back on. has compression. and fires on time but has no fuel getting to the cyl. i am an exp mech and have rebuilt the carb and checked all possible options. carb passed all seat seal test's with vac guage for leak down. now im dealing with vac line placement and minor elec problems. [ dog chewed wiring when in garage] dog gone, wife mad, wants it to be finished, being as it cost me my dog, please help. god bless you, Joseph...
  • 5 Answers
SOURCE: I have a Polaris 700 Sportsman. It runs but will
I would say the voltage regulator since it is not charging
Posted on Jun 28, 2009
  • 3 Answers
SOURCE: need a diagram to route fuel lines on a carb
my polaris outlaw 500 sarted cuting out last ride could not ecerate past 1/4 throtle and was back fireing so went to fix and wont run at all i have spark, plug is wet, changed fuel, seems to have compresion, when it turns over it tries to fire at times more like a hickup almost stops the sarter and a puff of smoke out the carb. im about to tare it down any ideas whats wrong ? bike was hard to start but ran ran perfect killed raptors with ease. bike was bored and built by some shop before i owned using ktm sleave and piston ? motor says nicols 520. didt over heat or make noises. have tried cleaning carb, jeting no luck please help
Posted on Jul 14, 2009
SOURCE: 2001 Polaris sportsman 500 magnum 4x4, speedo dont work
I'm not sure but it might be the sensor on the right front wheel disk
Posted on Sep 05, 2009
SOURCE: 2005 Polaris 700 sportsman 4x4 gets warm, looses power?
My Sportsman runs bad when heated up, but if you add fuel it runs fine again. I had a pick up that had an internal fuel pump like our Sportsman's and it did the exact same thing. It turned out being the fuel pump was worn out due to a plugged fuel filter. Forcing the pump to fail prematurely. I found I had bad fuel in my Sportsman and am going to replace the filter and the fuel pump. I also checked my plugs, MAF sensor, and Air filter, they were fine.
Posted on Sep 16, 2009
SOURCE: overheating polaris sportsman 700
you probly need a new heat sensor, its located on the bottom right of your rad, i had the same problem with my 700 the fan only worked when it was already over heating, i cut the wires flush at the sensor drilled a hole above the key switch and mounted a toggle switch, no more over heating,
Posted on Oct 24, 2009
1997 Polaris Sportsman 400. Need fuel system diagram listing filters. I have drained old gas, changed spark plug. Do I need to remove carb and clean? Help or suggestions are appreciated!! Thanks,
You might try to ask someone to help on the ATV web site below:
https://atvconnection.com/forums/polaris/330956-year-my-sportsman-400-4x4-1997-a.html
Feb 24, 2018 | Polaris ATV
Just bought this bike had no manuals with it I need to know about checking and changing oil
PDF]Sportsman 400 H.O. Sportsman 500 H.O. - Polaris
cdn.polarisindustries.com/polaris/.../parts-manuals/9923420r01_lo_res.p...
... parts and acces- sories, available through our online store at www.purepolaris.com. Have ... 2012 SPORTSMAN 400/500 HO Owner's Manual. P/N 9923420 ...
Polaris Sportsman 500 HO Owner's Manual - ManualsLib
www.manualslib.com > ... > Offroad Vehicle > Sportsman 500 H.O.
View and Download Polaris Sportsman 500 HO owner's manual online. PolarisIndustries All-Terrain Vehicles Owner's Manual. Sportsman 500 HO Offroad ...
2011 Sportsman 400/500 Service Manual - Polaris ATV Forum
www.polarisatvforums.com > ... > ATV Repair and Maintenance
Apr 11, 2011 - Indy Red 2011 Sportsman 500 H.O. -Polaris rear rack extender -Ricochet a-arm guards -Polaris fender bag -Koplin hand guards w/mirrors Owners, Service, and Parts Manuals
Sep 14, 2012
2005 Polaris 500 H.O. ATP service manual
Aug 12, 2011
Service manuals
Nov 29, 2010
Service Manual
Sep 23, 2010
More results from www.polarisatvforums.com
Dec 21, 2015 | Polaris 2011 Sportsman 500 H.O
2000 Sportsman 500. Where can I get a diagram of hub assembly?
Go to cheap cycle parts dot com - enter in Polaris ATV parts oem - then enter your year, make model and choose assembly - complete diagram
Nov 12, 2015 | Polaris ATV
2001 Sportsman 500. Where can I get a wiring diagram?
I'm attaching a picture that has 2 wiring diagrams side by side. The left side is the 2000 Polaris Sportsman 500 (Early) wiring diagram and the right side is the 2000 Polaris Sportsman 500 (Late). The Late wiring diagram for 2000 is more than likely either the same or extremely close to the 2001. And they may have just carried it over (the late wiring diagram). I've got a lot of hours on ATV's and Polaris especially - they stuck with what worked and didn't reinvent the wheel from one year to the next (usually). This may not be exact - but it should be extremely close. Hope this helps. Good Luck.
All The Best, Justin Lee
Nov 10, 2015 | Polaris ATV
Polaris 400 sportsman, having trouble in reverse, while trying to back up engine cuts in and out?
My trailblazer 330 has a button that has to be pressed down while going in reverse or the engine sputters, kind of a safety feture i think.
Dec 01, 2010 | Polaris ATV
I own a 2005 Polaris Sportsman 800 EFI. If I need
There is a retaining clip on the outter part of the strut, you take that out then push the bearing from the inside of the strut pushing the bearing in the direction of where you took the retaining clip out. The part # for the Bearing/axle tube/ hubstrut is 3060233-001 and you can find it along with a helpful diagram at www.bikebandit.com Hope this helps and hopefully I answered your question.
Mar 21, 2010 | Polaris ATV
I have a 1999 sportsman 500 4x4 that has now power
i have a polaris magnum 330 4x4 with the same problem mine still does it because i havent did anything but i think ive got water in my oil but in low gear it pulls fine
Jan 09, 2010 | Polaris ATV
03 Polaris sportsman 700 4x4 will not Disengage
I KNOW THAT IF YOU HAVENT CHANGED THE HUB OIL IN A WHILE THAT IT GETS DIRTY AND GETS STUCK IN 4-WHEEL
May 20, 2009 | Polaris ATV
Garden Logo
35 people viewed this question
Top Polaris Garden Experts
Paul Bade
john h
Are you a Polaris Garden Expert? Answer questions, earn points and help others
