Question about Nintendo DS Console
Blank Upper and Lower Screens
I have a DS lite that has power but nothing displays on either screen. I was wondering if there was a reset button located somewhere? Can anyone help? it will flash on and then flash off how do i fix it
  • jackandmatt Oct 31, 2008
    Same thing... we thought it was broken because it was dropped...
  • fawdr Apr 22, 2009
    my power light is green but both of my screns are still black
  • 37 Answers
Try plugging it into the charger and turning it on. If it still doesn't work, you probably broke the internatl port for the charger which is why it's turning on then back off right away because it's not able to charge anymore. If you stil have your warrenty, I would try to take it back.
Posted on Nov 09, 2008
Tip
My DS has power, but my screens are blank!
HELLO!!
I've seen countless amounts of Nintendo DSlites with this generic problem. If you have experience opening up electronics, you will find this to be a VERY easy fix. A fix that'll make you happy you didn't blow money on having a professional repair it. It doesn't take a professional to repair this. Continue reading :)
PROBLEM: A Nintedo DSLite that powers up, but doesn't display video. Here's what your situation should look like
  1. Nintendo DS has power. (power indicator light is either green or red.)
  2. Both screens (upper and lower) are both black/blank
What causes this problem?
- Your Wireless wifi board on your nintendo DS has gone bad.
How do we fix this problem?
- Simple, replace it :)
Here's what it looks like...
This is where it goes... (top left corner)
Easy Easy Fix...
If it helps, please let me know!
Great!
on Jan 01, 2010 | Nintendo DS Lite Console
Tip
When your screens blink.. What to do!
A lot of people have had the dreadful blinking of the screens. Whether it's only 1 screen blinking (upper or lower) , or both screens blinking..
I have a tip to help you diagnose the problem so you don't have to waste time trying to find out what's wrong with it, or waste money.
1.) IF YOUR UPPER LCD BLINKS
  • There is something wrong with your lower LCD and/or the connector on the board where the lower lcd connects to.
POTENTIAL SOLUTION
  • Open up your Nintendo DS lite system and clean the board with rubbing alcohol. Be sure to dry the board from excess liquid before re-assembling it. Use a FIRM brush. An regular toothbrush would not work as the bristles are not firm enough.
2.) IF YOUR LOWER LCD BLINKS
  • There is something wrong with your upper LCD and/or the connector on the board where the upper lcd connects to.
  • Follow the Potential Solution to #1
3.) IF BOTH SCREENS BLINK
  • 99.9% of the time, if both screens blink, your light is red. Which indicates your battery is low. Change the battery. If your system isn't charing your batteries correctly and/or you're losing battery power unusually quick, replace the charger.
  • If that does not work, send your system in for repair, as the charging port needs to be cleaned.
on Dec 31, 2009 | Nintendo DS Lite Console
Nintendo ds lite screens blank, although green power light on
possible that the flex holding the lcd is broken.
Feb 16, 2010 | Nintendo DS Lite
NDS lite has the power(green lite flashes), but screens wont lit
When you switch the DS lite on you should notice that one of the screens flashes... if thats correct then the screen that doesn't flash is the one that will need replacing which, I would assume is the upper screen as judging by what you say has a damaged ribbon.
Regards,
SOD69
Feb 10, 2010 | Nintendo DS Lite Console
Ds lite battery wont charge i have charged it overnight but nothing the green light goes on but that is it
If the green light is turning on and the screens are staying blank it is a problem with he L2 fuse on the motherboard (located just below the power button).
This can be replaced if you are handy with a soldering iron. If not drop it to a local repair shop it can be fixed for about €20.
Aug 26, 2009 | Nintendo DS Lite Console
Nintendo DS lite; changed touch screen and it won't start
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
Mar 14, 2009 | Nintendo DS Lite
What is my solution for this problem I do not have an lcd display on either upper or lower screens. the screens light up but are both blank
When did it first happen? You shoud try with a friend's battery and charger to see if you get anything different. If you already tryied that and tried taking the battery out and back in then pretty much there is nothing else to do, than get in contact with Nintendo to maybe consider a warranty exchage, or for repairs if warranty is expired.
Mar 09, 2009 | Nintendo DS Lite Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
sounds like the connectors of the screens have loosened
Nov 19, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
198 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
