Question about Philips VPX210AT Dual Deck VCR
DVD/vhs combo We have a DVD/vhs combo machine. When we play a DVD, we get a red band at the top of the TV screen and a green band at the bottom of the screen and only the band in the middle is normal. It's not an old machine and worked fine on my Mum's old TV but this started when we moved the player to our house. The TV plays just fine on it's own, no red and green, perfect colour. We can't find anything on the remote menu to fix this, we can't find anything on the TV remote to fix it with either and think it must be the player because the TV is fine on it's own. It's impossible to watch anything because it's so annoying! The sound is fine and the tracking is fine.. Help! Thanks very much Philippa
    New Friend:
  • 163 Answers
How is the vhs? if is ok, then the problem is the dvd and theres nothing to do with remotes, all point to a bad chip(Ic) and you gona need a tech, if the problem is with the vhs too, then try with another set of cable from the set to the tv...good luck
Posted on Aug 06, 2006
Green tint on TV screen when playing DVD's or Videos 2nd problem and can't record anything
1: Hi i would recommend trying the recorder on a different tv to check if the problem continues. If the green tint is gone then its the tvs inputs. If it is still green then its the player or the cord. Try a different cord if the green tint is still there then the player has a problem.
2: Now for the VHS to DVD. There are general a lock out encoded on the VHS if it is a store bought movie. This is to protect the content on the VHS from piracy and that would case the DVD to be blank. The VHS to DVD are made for converting your home videos like family vacations and stuff you record your self and not for commercial movies like the ones you bye at the store. If you want to convert old VHS movies to DVD you would have to get another VHS player and another device in between the VHS player and the VHS to DVD recorder.
Mar 19, 2014 | Televison & Video
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Don't know how to copy video to DVD
blank disk to dvd tray....VHS in deck....PUSH PLAY ON VHS...and RECORD on DVD BURNER....if it is a burner...they weren't all burners....it has to say DVD WRITABLE or some thing in that mannern
May 10, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
No picture when connecting CRT TV to Panasonic DVD/VHS Combo
If you combo get activated the progresive scan function you never see the videio only sound you need to deactivate
Feb 14, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
FUNAI DVD/VCR COMBO
You need to replace all rubber bands inside the VHS.Vary difficult to find rubber band kit.If you use the TV in the heat, u must place a fan of some kind in the back blowing IN to cool the insides of TV. [AFTER U REPLACE rubber bands]
Jul 30, 2008 | Funai PY90VG DVD Player/VCR
The DVD will play and display, but the VHS will play but not display.
It could be that the output to TV from VHS only works through the composite cables (the red, white, yellow).
Dec 11, 2007 | Samsung DVD-V8600 DVD Player/VCR
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
Televison & Video Logo
118 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
