Question about Altec Lansing VS4121 Speaker
Speakers problem speaker sound cracks while opning any other software on my pc.
  • 734 Answers
Your cpu is running more progrems uninstall sum unused programs, to free your computer ram memory
Posted on Nov 12, 2008
Can a speaker system made for PC be used on standard Hifi or Smart TV?
cheap and easy fix for crummy HDTV speakers
TV sound to USB speakers
??? Speaker System needs software??? Uh, if a computer chip in a Smart TV needs software to recognize a computer speaker, you are going to have to get that information from someone besides me.
Jun 05, 2017 | Gateway Audio Players & Recorders
How do I fix my sound on the pc? speakers are cracking.
Sounds like the speaker cones are torn. They're made of a paper and break easily on load sound volume. open the speaker to check it.
Hope this helps.
Feb 23, 2015 | HP Computers & Internet
Sound problem
insert a headset into the jack if the sound comes thru it,if sound comes into the jack then check speakers and get the speakers changed.
if both the sound jack and the speakers does not work,check the sound ic on the mother board....
Nov 21, 2013 | Toshiba satellite c660
My dell dimension 3000 makes cracking sounds when i play music
Check your speakers first. Plug the cable from your speakers into a cell phone, ipod or some other music device that has headphone port. If the speakers are crackling then, then you know it's the speakers. If not, then it's a computer issue in which case you might want to contact Dell.
Mar 30, 2011 | Dell Dimension 3000 PC Desktop
Speakers crack and volume decreases. Wiggling the speaker wire where it plugs into the computer causes additional cracking noise.
Try to identify if all the speakers cracking sounds comes when wiggling the cable that connects them with the pc. In that case the easiest way is to replace this cable with a new one, like this.
If the problem isn't only at the cable post back.
Also in any case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 03, 2010 | Altec Lansing VS4121 Speaker
Volvo s.40 with HU605 audio unit. all works ok on console but only weak tinny audio from facia speakers, none from rear and door speakers. opne 8 way din socket on rear of unit got no plug in it.
Hello mireilledwar,
It sounds like the amplifier in the receiver is faulty. The sound you are getting sounds like just the highest frequencies reproduced by the tweeters. Lower frequencies reproduced by the woofers generally require more power output to drive the bigger speakers. There are two connectors on the back of the unit. Unless you have the optional CD changer, only one is used.
Hope this helps.
Aug 13, 2009 | Car Audio & Video
Can't get headphone jack on front of computer to work
The headphone jack up front may not be connected to the PC's integrated audio on the motherboard (or to the PC's sound card if you purchased one with the system instead. There'll be an audio cable running from the front of the computer to a port on the motherboard. If you look at this motherboard diagram for the Vostro 220 (not the 420 or 220s), it'll be the port numbered "15" that's the opne for the audio for the front panel. You don't need the speakers plugged on the back to have the headphones work, but having them plugged in will at least tell you if the sound is working or not.
Mar 27, 2009 | Dell Vostro 220 Desktop Computer
Distorted sound after installing software plus GigaPocket issues
Have you physically disabled the onboard sound in the BIOS? By doing this I think most of your other hardware/software would default to the only audio device (your SB).
Post back if you've already done this and I'll see what else I can dig up on your hardware and possible conflicts.
Mar 03, 2009 | Creative Labs Computers & Internet
LogitechX540 speakers hooked them up to our PC makes raspy sound
you might try putting in a new sound card to see if that dosent help. it should take care of the problem
Jan 11, 2009 | Logitech X-540 Multimedia Surround Sound...
A525 speakers giving cracking sound /disturbance
contact dell support and get the same replaced
Mar 27, 2008 | Dell A525 Computer Speakers
Altec Lansing VS4121 Speaker Logo
100 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
