Question about Watches
How do i make my merona womens expansion band watch smaller
Style#82927tc
vsndesigns
  • 5 Answers
SOURCE: Aquaswiss Trax watch band adjustment
VSNDESIGNS SAYS:
You should first try to adjust the band at the Clasp first. The clasp has three holes that you could easily move your band up or down into. If you need to remove one or more of the links, try the following.
http://www.fixya.com/support/t315141-adjust_band_aquaswiss_trax_watch
http://www.rgmarchitect.com
Posted on Feb 09, 2008
SOURCE: Band adjustment
I was able to take use a push pin (thumb tack) to get out the (split) pin. I put the thumb tack in the hole of the pin I wanted to remove, place the thumb tack upside down on our counter top and gently but firmly push the pin out. It only has to push out an 1/8 of an inch and then you can pull it the rest of the way. Thanks to the diagram that "guest" posted above - I copied and pasted: http://www.pmwf.com/Watches/WatchSchool/WS%2014%20How%20to%20Resize%20Common%20Bracelets/WS%2014%20How%20to%20Resize%20Bracelets.htm#Split%20pin%20bracelets in the browser and it showed me how the pins work in the wrist band. Didn't need all of the fancy tools. (:
Posted on Mar 18, 2008
escapement
  • 2334 Answers
SOURCE: how do I adjust band on a guess g95290g guess steel mens watch ?
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 16, 2009
SOURCE: can't set inner dial on merona watch
You just remove one of the links. I don't think there's a way to set the inner dials. I think it's just for show.
Posted on Dec 26, 2009
escapement
  • 2334 Answers
SOURCE: I'm trying to take out links on a gold Merona
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jan 08, 2010
How to make an expansion watch band smaller for A timex WR30M
I would need to see the watch band, even the same model may use different bands.
Sep 22, 2016 | Timex Watches
How can I start it to run
if brand new , there will be a small piece of plastic holding the winder knob out
pull it out and push the knob all the way in
that plastic stops battery connection so that the battery is not flat when sold
any other problems , take it to a jeweller
May 06, 2016 | Timex Womens T2M828 Classic Two-Tone...
REPLACEMENT BAND
UK service centre is 0121 436 1397
Jan 30, 2014 | Pulsar PXT832 Womens Two Tone Silver Dial...
Where to buy white polyurethane watch band
This band you will easily get on Amazon, Ebay, Etsy and Discountedwatches247 etc. The Discountedwatches247.com provides beautiful watches and watch bands in discounted price and lots of designs and colors available. You can purchase a cute ladies watch for function, causal watch or a stylish digital watch and many more. These Cheap watches are good quality watches with the latest design and style.
Jan 27, 2014 | Kenneth Cole Kc2461 New York WomenS Kc2461...
How do I make the watch band smaller?
to adjust the size of your wrist...eat chocolate!
most watches with linked wristbands require the links removing.(small pins to b e pushed out) the type with the chain links usually have a clamp to release to slide the clasp up the band. the instructions should be with the watch manual. or ask a jeweler to help.
please post pictures if need more help so i can see the design
Nov 09, 2011 | Calvin Klein Ck Small Minimal Golf...
How do you adjust the expansion band on the Citizen EW0700-98A watch?
these are hard to do. it needs to bend the tabs and pull out staples,then remove links and bend back, these are a pain in the ****. can be done by experanced guy. i can do them 10-15 dollars
Jun 17, 2011 | Citizen Expansion Band Eco Drive EW0702...
Need to replace my leather watch band on my goofy watch with an authentic disney band. it is leather with no characters on the band & underside is stamped with disney made in china. Need size &...
If you need an authentic Disney watch band, try asking at a Disney store. However, non-Disney watch bands will fit this watch and may be both better quality and less expensive. Almost any jewelry store, department/discount store jewelry counter, or shopping mall watch kiosk will be able to measure your watch and determine the right size band. Many women's watches in this general style use a 14mm or 16mm band, but you should measure your watch to make certain.
May 05, 2011 | Disney Goofy Brown Leather Strap #D075S007...
My timex indiglo watch's expansion band is too large. How can I remove links to make it smaller.
mcdevito75 here, Removeing the tiny pins to remove links is fairly easy, replaceing them is the hard part, for this you"d need a Link remover tool, Best Bet is to look for a small watch repair shop in your area, the $10--15.00 cost will equal your Time, effort and tool you"d need. Don"t forget to hold onto the links removed from the band in case you need them again.
Feb 09, 2011 | Timex Indiglo Expansion Watch
How do you adjust a merona watch band
this is all the info available. Try to contact them yourself:
Merona AG
Birmensdorferstrasse 83
CH-8003 Zürich
Tel +41 44 465 80 80
Fax +41 44 463 16 96
E-Mail mail@merona.com
May 19, 2010 | Watches
Watches Logo
87 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
