Question about Palm Treo 600 Handheld
My treo is doing hard reset automatically
After it fell on the ground and went dead, it automatically did hard reset after I connected it to the charger. Before I was able to properly use it again,it went dead again after 30 minutes. Please advise.
  • Anonymous Mar 04, 2009
    I droped my Palm treo 600 and it would not turn on at all, The SD card did fll out, but I dont think that's the case.
    What do I do Now?
After I did a hard reset, I put power to the phone and the screen came back blue with a red hair line and a green hair line from top to the bottem of the screen.
Posted on Mar 08, 2008
Try performing a battery reset..it will reset the internal radio and the charging circuitry..only problem here is that u need an AC charger to switch the phone back on. this will wipe out all data u may want to back it up before trying this option heres how to do it Battery Disconnect Reset Treo 600 only A battery disconnect reset is a last resort step you can take to cut battery power, wipe all data, and regress a Treo 600 to its factory-fresh state. It only works on a Treo 600 smartphone. Important: A battery disconnect reset will erase everything on your smartphone, and also reset the wireless radio and disconnect the internal battery. All your data will be removed, and your formats, preferences and other settings are restored to their factory default settings. Don't perform a battery disconnect reset unless you've backed up your data, or you're willing to lose everything. You won't be able to turn your Treo 600 back on until you connect it to a power adapter, so do not perform this type of reset without your Treo 600 charger and a power source. HotSync note: Some third-party applications change the way your handheld backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost. To perform a battery disconnect reset: 1. Disconnect your Treo 600 from the AC charger. 2. Hold down the K and Backspace keys simultaneously. (Note: for French AZERTY keyboard, press K and M; for other language overlays, please refer to the customer support for your region) 3. While continuing to hold down the K and Backspace keys, press the RESET button inside the hole on the back panel of your device (where's the reset hole?). 4. Finding it hard to do? Good. We made this type of reset very awkward to perform, so that it would not happen by accident when your Treo 600 is jostling around in a pocket or bag. Sorry for the inconvenience. You might want to ask a friend to lend a hand if you find it too difficult to do by yourself. 5. Continue holding down K and Backspace. The screen will flash white briefly, and then go black. Release K and Backspace after this happens. Your Treo will appear to be "dead" and the screen will not turn on. If you see any activity ? such as the screen turning back on ? the reset was performed incorrectly; try again 6. To revive your Treo 600, connect it to the AC charger and plug the charger into a socket. The screen will stay blank for several seconds (as long as half a minute), then it will turn on. The LED will glow solid red, indicating charging. 7. Finally, follow the steps for recovering after a hard reset (a battery disconnect reset is an extended type of hard reset).
Posted on Jan 03, 2007
Treo 650 suddenly went to a palmone boot up screen then to a palmone powered screen and just keeps repeating without fully going to the normal screen mode for the phone.
When the first screen flashes, as the bar is loading, hold up. Let go once the bar finishes. If that doesn't work you may need to hard reset. Just google how to give it a hard reset and remember that you will lose everything that isn't backed up if you do.
Feb 12, 2010 | Palm Treo 650 Smartphone
Palm Treo 700W Smartphone is stuck on speaker phone
Soft Reset
A Soft Reset stops all active (or open) programs and "reboots" the handheld. When the Treo powers back up, you'll start with all programs closed and the unit will be ready to use. The soft reset is intended to reset the Treo if it is malfunctioning or has become bogged down.
The Palm Treo 750 can be soft reset by quickly pressing and releasing the tiny red button beneath the miniSD memory card door:
diagram.jpg Hard Reset
A Hard Reset wipes the internal memory and returns the Treo to its factory specs, in effect returning the Treo 750 to the state it was in when you purchased it. All data entered, preferences set or software installed on the Treo after purchase will be lost after a hard reset and will have to transferred or reinstalled via ActiveSync / Windows Mobile Device Center.
power_button.jpg The Palm Treo 750 can be hard reset by pressing and holding the power button (seen left) while at the same time pressing and holding reset button beneath the miniSD memory card door. Press and hold the two buttons until the screen completely fades. When the screen returns, you'll be given the option to "Erase all data." Select Yes to complete the hard reset. The Treo will now be as it was when it left the factory and you can start fresh. You may have to perform a soft reset after the hard reset to get the unit to power on.
May 11, 2008 | Palm Treo 700w Smartphone
TREO 650 Phone won't work
I experienced the same problem while traveling this weekend. The green phone button and anything associated to the phone all of a sudden stopped working. No call out and none in. I hotsync'd and also did a "hard reset" except I said yes and then went in and hotsync'd again. Phone now works again and all data is back
May 04, 2008 | Palm Treo 650 Handheld
Treo 600 Completely Blue Screen
I's sorry to tell you your screen is dead. The screen is not displaying any information but the backlight is still functioning. This is the most expensive part of the phone as far as replacement parts and after-market parts. If you can fine one that is a reasonable price, you are very fortunate.
I have three screens like this at home. There are three layers to the screen, the backlight, the imager, and the digitizer. All three sandwiched together create the screen.
If the phone was on when you fished around the charge port, it is possible that you inadvertently caused a charge or grounded the charging/power circuit. You are fortunate that only the screen was damaged...if that's the only part that is damaged.
Apr 26, 2008 | Palm Treo 600 Handheld
Hard reset
hold K, return key, and press reset. reconnect charger to turn back on.
Apr 01, 2008 | Palm Treo 600 Handheld
Dead treo 600
plug in the battery charger, and it should start.
Mar 25, 2008 | Palm Treo 600 Handheld
MY TREO 650 KEEPS TRYING TO HOTSYNC(and its not connected to computer)
Did it actually reset when you did a hard reset ..or does it stay powered up?
Dec 31, 2007 | Palm Treo 680 Smartphone
PALM TREO 650
I would suggest a hard reset.  Be sure that all of your information is backed up prior to preforming these steps.
Please follow the hard reset instructions in the following publication.
(copy/paste this into your browser)
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(887)
Let me know if this works.
James
Oct 17, 2007 | Palm Treo 650 Handheld
Phone hangs when connected to charger
Sounds like a problem with the battery. Is it a problem to make a telephone call and do you have a humming noise?(gsm sound)?
Jan 03, 2007 | Palm Treo 600 Handheld
Palm Treo 600 Handheld Logo
351 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
