Question about Zenith IQC60H94W 60" Rear Projection Television
Zenith IQC60H94W 60 inch rear projection turns off
Hello, my TV turns off while watching TV or playing games.  When watching TV it happens every once in a while.  Video games it happens all the time.  High def TV all the time also.  After a few years of dealing with this I have noticed that the brightness effects how often it happens, at least with video games.
  • tke144red Oct 24, 2008
    any more detail on that?  What can i do to fix it?
  • 790 Answers
Hi
in this complaint you have defective power oscillation! thats why your TV On and Off
Thanks!
Posted on Oct 24, 2008
It outlines all objects in a red blurr
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2010 | Zenith IQC60H94W 60" Rear Projection...
My zenith model IQC60H94W tv has a black and white picture, all three lamps appear to be working but the picture is in black and white?
Some time i may be the simple thing and as dumb as you may feel. If you have kids or other that push buttons. Check the menu setting make sure the color setting is turned up 3/4-1/2. yes some times we dont thinks it can be that simple. let us know what you find.
Aug 30, 2010 | Zenith IQC60H94W 60" Rear Projection...
Picture and sound on my old zenith bigscreen flash on and off.
Sounds like a power problem to me. Possible shorting out inside the tv. If its old I would recommend discarding this tv. The price of repair costs are really high for TV's. You can probably upgrade to a flat panel for what the repair cost would cost you to repair this older tv.
Does it turn off and on as if you were pressing the power button? Or does it happen really fast? If its happening as if you were turning the tv off and then having to wait for it to come on again I would say its the power supply which is probably going to cost you hundreds in a repair shop. However you could possibly find a power supply for it on ebay buy searching for the model number and brand in the search area of ebay. Putting a power supply in a tv isn't really that hard, unless there is something in the way to get it in or out of tv. Usually it just involves unscrewing it from the chassis and unscrewing the hot wires and ground from the supply...then putting the new one in and screwing them back down.
Sep 03, 2009 | Zenith IQC60H94W 60" Rear Projection...
My Zenith tv plays well, then the picture starts jumping and then picture goes off. Repair man has had tv for almost 2 months and can't seem to find out what is wrong.
Check the Vertical output IC and the Solder connections on the Vertical deflection yokes. Bad solder on the yoke plug connectors will cause the same symptom, and the Vertical IC may just need to be resoldered as thats fairly common with that model.
Jun 18, 2009 | Zenith IQC60H94W 60" Rear Projection...
Will ps3 hurt philips projection hdtv
Everyone is right. The manuals for both projection TVs and video games specifically warn against playing video games on these sets. The result can be "pattern burn" from parts of the image that stay in one place for extended times. Once the face of a tube is burned by a bright image, it's visible all the time. If you intend to watch this TV, don't play games on it!
Mar 16, 2009 | Philips 60PP9202 60" Rear Projection...
How do you clean the mirror?
It's been a while since I faced one of these, but I believe the bezel around the screen pulls off to expose the screen mounting screws. As I recall it is held on by snap fasteners. It's also possible there is a snap-on trim strip between the screen bottom edge and the speaker grille. If that's the case, remove that to expose screws securing the bottom of the screen. Once they're out the screen swings up and off. Zenith used a couple of methods on different models.
Nov 27, 2008 | Zenith IQC60H94W 60" Rear Projection...
Zenith IQC60H94W 60" Rear Projection Television Logo
135 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
