Question about Jenn-Air JGR8775QD Gas Kitchen Range
Control panel for Jenn-air JGR8875qdw
Nothing on the control panel works, can't see the time or control any of the buttons to the oven. Gas works and lights on the stove part. Had a power outage in the house. So far only the stove wouldn't come back, tried the sabbath cancel which didn't work. Tried unpluging it a few times.
  • 26 Answers
SOURCE: Jenn-Air 48600 touch button problem
You probably need a new touch pad membrane
Posted on Jan 09, 2008
  • 242 Answers
SOURCE: How can a Jenn-Air down draft stove be vented out the roof ?
Yes , its much more labor intense but it can be done by venting it up through the wall then through the attic over to the side vents. Make sure to get flexable duct to pull up through the wall.
Posted on Apr 10, 2009
  • 725 Answers
SOURCE: F 1 code after using Jenn-Aire electric oven
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem.This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Sep 21, 2009
SOURCE: My Jenn Air gas stove stop keeps shutting off when
I had someone come in to look at the Range, I no longer require assistance.... Thanks for getting back.
Posted on Jan 05, 2010
  • 9472 Answers
SOURCE: I have a jenn-air electric down draft slide in
You will need to replace the control board (clock assembly) on your unit. I see this all the time with power surges and it takes the control board out. Your model is a discontinued one and the part may need to be a special order. Here is a link to the part, call the number that is on the page and I am sure they may get it for you.
Posted on Nov 08, 2011
Jenn air svd46800 oven not working
Good Afternoon,
The control boards in your appliance may have failed. There is a display board, part number 71001799 and relay board part number 12001693. Commonly we see transformers on these relay boards fail with power surges. Luckily, we do test and repair these parts. Remanufacturing these controls will save you the high cost of buying new, and each rebuild will come with a 2 year warranty-- which is three times longer than new. Email me if you have any questions!
Jun 05, 2017 | Jenn-Air Ovens
JJW8230DDB Jenn Air double oven. Black. Digital display. The only buttons working on the display are the Cancel buttons. Display still shows time, but I can not set the time (the clock button does not work...
When buttons are not working most of the time it is due to a short in the touch pad or the electronic control in a unit you would have to call for service if you did not know how to use a multimeter to perform ohms and continuity testing and measureing of both pieces. Usually though due to the button not working most of the time it is the touch pad though. If you have any further questions message me back Thanks again
Oct 16, 2011 | Jenn-Air JJW8230D Electric Double Oven
The electronic controls click out with in just a few minutes after starting the oven. The light does not go on and nothing works. This problem started within one week of install and use and have had the...
Unfortunately this seems to be a problem with several of the jenn air models. I have replaced quite a few and have also talked to thier tech line for servicers and they don't have anything else to offer other than replacing the control board. Each time I ran across one I found no other problems and I tested everything. If you replace 3 times you can usually get them to give you a new one.
Mar 18, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Aug 11, 2009 | Kitchen Ranges
I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Jul 24, 2009 | Jenn-Air JES9800A Electric Kitchen Range
No electrical power to ovens and control panel.
It appears that you have lost one half of your power. That is you no longer have 220 volts but do have 110, enouch to power the electronic ignition. I would check the circuit breaker first to see if it is sending power on both hot wires or just one.
Jul 17, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven control panel or display window does not light up anymore. Can't see what temperature oven is at or the time or anything else for that matter.
Could be a fuse or a bad control panel. Unplug the oven, take the panel off of the back and look for fuses. If none, call Maytag or supplier of Jenn-air oven controller for a replacement.
Jul 13, 2009 | Jenn-Air Ovens
Oven panel
First try unplugging or turning off the breaker and see what happens. If that fixes it your good to go if not you probably need a control board. Some of the boards have a fuse but no one changes it as it is soldered onto the control board.
Dec 19, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Open Questions:
Jenn-Air JGR8775QD Gas Kitchen Range Logo
121 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
