Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Xerox Workcentre C2424
I have an error code 04,018,48:2770 Can anyone tell me what this code is in relation to? Xerox are being typically unhelpful but then why waste an engineers time driving into the highlands for something I can fix, if I knew what it was. The machine is 18mo old and has barely done 10k yet and after suffering a power failure the was on and off like the a disco, it has come back with the error noted. I feel it is a sync problem with the drive train. I have checked the main systems with the info I have and they seem to line up fine. I do have an issue with the right side. There are a paid of gears fairly near the top that are definately out of sync. They were marked at one time where they met, and now they never reach that meeting point, I guess I need to know how to home the drive train. Can anyone help?
    President:
  • 2,072 Answers
Yeah, That is the process drive assembly.
You have to remove that motor, I think it's 4 torx screws and you have to move a couple of wires etc.
Once you do that, you can turn the upper and lower portions to align the holes in the clear plastic frame with the holes in the gears. I normally pin them with just some papre clips.
Then when installing the assembly back into the machine, make sure the arrows line up on the bottom of the frame and gear.
That should line that up and time it for you.That motor is responsible for driving the maintenance kit up and down to the prep and clean the drum. You may want to be sure your maintenance kit is not somehow binding and throwing that process drive out of timing.
A C2424 does not often have probmes with the maintenance kit binding, but it can occur.
That process drive timing has some problems staying stable.
Posted on Oct 23, 2008
  • Rick Kasper Oct 23, 2008
    I am hoping you havent blown the electronics module.
Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Dec 02, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Workcentre C2424 System Error
That sounds like a problem with what is called the process drive motor. It is the assembly that moves the maintenance kit up and down to clean the drum.
It is located on the front right side of the machine and has a multi gear assembly to it.
It can be mistimed, there are 2 holes and an arrow on the bottom that must be aligned.
For service, to save money. you can contact a service dealer or an ASP in your area that would charge you far less than Xerox. If you don;t know who those service providers are, just let me know what your zip code is and I can look up the nearest ones for you.
May 27, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcentre c2424 error code
One of two things most likely.
1. The wiper blade is stuck to the print head,or 2, The print head blosk has a lot of spill over ink built up in it.
That code is caused by the inability of the print head to move properly. Either left to right or pivot front to back to get into the print position.
You have to remove the covers to access the stainless steel print block. It is located about 2/3 of the way back on the lower left side of the frame. It is a one inch by one inch square block that may have a lot of buildup of spill over ink in it. If the wiper is stuck you have to remove the ink loader , where you add the ink sticks , to access the area between the print head and drum, It is a pink blade the is between the drum and print head, it wold be stuck to the print head not allowing it to move. Just carefully unstick it from the print head
Mar 27, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox c2424 Printer won't work
34 codes are related to the print head. Print head NVM or the print head itself. Most likely, I would say 95 percent chance of a print head failure.
Mar 01, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcentre c2424 error 37,008.4x
Most likely yes. That contains the power supply for that heater.
Oct 27, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox Workcentre c2424 Error Code "37,030.48"
Hi Ian_a_nicol:
error code # 37,030.48 means X-axis motor disconnect. The X-axis motor (second phase) is not drawing the expected power from the power supply. you can do the following to determin if the X-axis motor is bad.
1. Run the X-axis Drive test and if it passes
replace the electronics module, if not see #2.
2. Check the X-axis motor wiring for damage
or replace X-axis motor.
3. Call Xerox to have them come out and run the test and determin if it is the electronics module or the X-axis motor, but is one or the other.
pdouglasss
Oct 24, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
System error
7,0XX.6x Errors - Program Faults
a.
Reset NVRAM and retest.
Jul 02, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox C2424 problem (11,009:46 and 13,008.47)
The second fault is a result of the faulty electronics module. It is a print head heat related issue.
Question is, is the print head also faulty.
That electronics module is very expensive.
But the 11,009 specifically is a failure of the electronics module.
Have had those codes a couple of times.
Most likely the 50 volt source has failed, that maintains the print head heat.
A Drum Assembly thermal error has occurred. The following troubleshooting procedures apply to these errors:
arrwup.gif 13,008.47 The Drum Heater is too hot
Jan 30, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
108 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
